Question about Sony KV-27V55 27" TV
Volume is gone (except for a clicking noise)
The volume suddenly stopped working....yet i cant still change the channel as well as see the channel's appropriate show.However the volume (from the Sony TV Model KV-27V55 27") only make a "clicking" sound when the volume is turned all the way down and the up again. I have tried to turn 'on' and 'off' the mute, and the "clicking" doesnt happen. I have tried turning the Television off for 10 min. and still no change> Not even repeating the above steps (after turning the TV back on after the 10 min break), with no changes in Any RESULTS!
    Top Expert:
  • Sony Master
  • 75,178 Answers
Check whether the mute function is ON or not. If not, the muting section circuit inside has the fault.
Posted on Jan 23, 2013
SOURCE: Sony Wega KV-32FS100
I had the same problem and found out that it wasn't making a good connection inside the the Directv box.The box was changed and that solved the problem.
Posted on Feb 03, 2008
C-Dog
  • 84 Answers
SOURCE: Sony KV-27S42
If the screen won't come on then the diagnostic will never show. The 4 blinks is an error code. If the set is older than 12 years then it doesn't owe you anything, you got your money's worth out of it. Average life of any tv from that genre is 8-12 years. It's time for a new set, or take it in for an expensive repair ( pending parts availability).
C-Dog
Posted on Feb 10, 2008
welcomejee
  • 10594 Answers
SOURCE: KV-32FS16
5 times flash light shows that your TV has white balance error. If you have basic knowledge of electronics, then adjust G2 voltage of tv. hope problem will be solved.
Posted on May 31, 2008
  • 142 Answers
SOURCE: No Sound Issues
Hello!
Try the audio out. Run the audio to a receiver to see if the audio is there. If it is, then I'd leave it hooked up to the receiver and save yourself some money. If there is not any low level audio out then I'd fix the set. The only Sony set I've ever seen that was not worth fixing was a 32" model from the early 1990's that had bad picture tubes after only 5 years. I am a Sony factory trained tech. Good Luck!
barneyluc
Posted on Oct 13, 2008
sabreusa
  • 271 Answers
SOURCE: My remote worked fine, but suddenly won't work
Could be the IR receiver in the TV.
Make sure nothing is in front of the TV that would block the IR from receiving commands from the remote, I've seen customers put VHS tapes on the front of their TV that caused the remote to not to work.
Good luck
N Sabre
Posted on Nov 09, 2009
NAD C162 preamp quiescent noise level suddenly went up. Please help me diagnose?
If the noise is in both channels then you should look for something common to both channels. Capacitors are the likely cause, but some IC's might cause it. You say that the volume control doesn't effect it, if that is the pre-amp's volume control then the fault will be after that part.
Oct 26, 2017 | NAD Audio Players & Recorders
We had remote exchanged at sudden link, because we can't get the tv setup to work. The channels will change but volume won't work nor power. Any suggestions
None except use the TV remote to operate the functions, I have seen this before with add on devices like this.
Nov 03, 2016 | Televison & Video
Why won't my BC145XL scan
push manual on the scanner push manual again to see if the channel changes if so then push the scan button , if still no scan see if the volume is turned up. if not turn it up and see if you have any white noise , if you have what is called white noise turn the squelch till the noise is gone then press scan if it still does not scan you may have all the channels locked out and if so they need to be unlocked refer to the manual to know how to unlock channels then try again if that does not work scanner may need to be repaired
Jul 02, 2014 | Uniden BC350C Base Scanner
All of a sudden I cant change channels on my Pioneer Elite 150FD TV. I can just switch inputs and volume nothing else will work. Please help?
If you have good batteries, remove the back an under the rubber numbers if you feel a wet substance, wipe it off an reassemble. It should work, the silicone rubber has a tendency to excrete this stuff. It fixed mine
Mar 27, 2014 | JVC AV-32D305 32" TV
We have a combination TV/DVD player made by Bush. Model number DVD1401TV which has suddenly gone completely dead. Can't do anything with it at all. Won't turn on, doesn't make any noise. I have checked the...
the remote will not change channels..i have a 15'coby flat screen which was hooked up with a cable box..the cable remote changed channels...now that i put this t.v. in my daughters room without the cable box we cannot change channels on it...the remote it came with does not work..and a universal will not work..the universal works on all t.v's in the house except that one..
Oct 02, 2009 | Televison & Video
CAN'T CHANGE CHANNEL MANUALLY AND REMOTE DOESN'T WORK
Hi again,
Many thanks for the wonderful review and the rating.
Good luck and kind regards.
Thank you again for using FixYa.
Nov 07, 2008 | Sharp LC13B6US 13 in. EDTV-Ready LCD...
Why does my RCA TV cycle through channels on its own?
Hi there!
I think your remote may be at fault. Liquid spill or sweat from the hand accumelates on the inside over some time and then becomes sticky. Some of the buttons may be permanently activated. Then other functions won't work. Have someone check it for you or if familiar yourself. Regards, JUS004
Mar 12, 2008 | RCA TruFlat 27F520T 27" TV
Televison & Video Logo
82 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
