Question about HP DeskJet F4280 All In One Printer InkJet
My DeskJet F4280 will not print
I have a new computer, new printer and new QuickBooks program. The printer was working fine until I opened QuickBooks and got the following message: QuickBooks PDF Converter Activation Error 20. You cannot print directly to QuickBooks PDF Converter. Try using QuickBooks Save As PDF menu option. I am lost.
  • 32 Answers
There are three things that you can try.
1. Exit and restart QuickBooks - try printing again
If this doesn't work
2. Go to your printer setting, double click on the QuickBooks PDF converter to open the printing queue, select any jobs listed and click cancel. If there are no jobs listed or you can't cancel them.
You will need to
3. Delete the PDF converter from the printer list.
Restart QuickBooks and try and reprint.
Hope this helps
3.What you need to do is go to your printer settings and delete the QuickBooks PDF Converter
Posted on Feb 18, 2009
My deskjet F4280 has stopped printing with my macbook pro OS X 10.5. it was working fine until the last few days. I have tried reinstalling it, however, when i get to the "select the device...
That CD may not have the updated version. Check the following link and download the driver for your computer's correct operating system. It will take you throught the install process quickly:
HP Deskjet F4280 All in One Printer Software and Drivers
Mar 30, 2017 | HP DeskJet F4280 All In One Printer InkJet
F4280 not able to set the size of paper scan!#@$
1. All you need is Uninstall the the printer from your control panel.
2. go to my computer and open your Hard drive (C:)
3. Go to the programs folder and open it.
4. delete the HP F4280 folder.
5. reinstall the printer.
Make sure that your printed is not connected to your PC during software installation until you are being told to do so.
Aug 08, 2009 | HP DeskJet F4280 All In One Printer InkJet
Hp6500 won't print my invoices from Quickbooks, Help!
Quickbooks generally give problems with every darn printer on the planet.If you are not using the latest quickbook version then try this. save the document on your desktop and then close the original file.Then open the saved file and select the path to print and click on file point to set print area and then click on set to print area click on ok on the dialog box.Then try to print once again and see if it works.....it should if it doesn't call in to HP at 18004746836 and we will be happy to resolve your issue via a remote access session with your computer
Jun 15, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
My hp deskjet allinone doesnt print but is connected itsays error
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | HP DeskJet F4280 All In One Printer InkJet
HP F4280 won't print Excel documents. It will print Word documents.
Try opening your Excel 'Page Print Setup', and changing the 'Print Quality' setting from 1200 dpi to 600 dpi. It worked for me...
Dec 26, 2008 | HP DeskJet F4280 All In One Printer InkJet
Attempts to print on HP Deskjet F4280 shut down my programs
Sounds like the drivers are not installing properly. Are you installing through the CD or downloading the drivers from the HP website. Since a lot of the new drivers are no longer supporting XP you will need to download a scrubber utility and delete all of the pre installed drivers and attempt to reinstall through a manual installation of the drivers.
Apr 18, 2017 | HP DeskJet F4280 All In One Printer InkJet
Just brought a hp deskjet all in one F4280,the software that came with it is for F4200 is this the wright software.
Software for F4200 series will fit all HP starting for F42..., including F4280. That is the right software.
Oct 22, 2008 | HP Office Equipment & Supplies
HP DeskJet F4280 All In One Printer InkJet Logo
251 people viewed this question
Ben Johnson
