Question about Vehicle Parts & Accessories
I turn my steering wheel (right or left) on my 94 nissan pick up and it turns half a steering wheel before the tires actually start moving .. any suggestions?
    Genius:
  • 1,003 Answers
Replace power steering pump may have bad impeller
Posted on Feb 04, 2013
2 Suggested Answers
SOURCE: high pitched squeal when starting car
Sounds like a belt, and possibly the one on the power steering pump which may be the sepentine belt. Could be caused by power steering pump pulley resistance or the belt tensioner bearing. Try a visual check with motor running. Be careful of moving parts!
Posted on Jun 06, 2012
Center a rack and pinion from under the dash
yes you possibly can ( depends on the room available.)
I would do the centring at the top of the rack and pinion as this is where a multi spline is that will allow for correct centring.
when you get the shaft off the box
firstly turn the rack from lock to lock ( wheels of the ground) and position the shaft at the midpoint of the turns counted fro left to right
next with the steering wheel place it in the straight ahead position
put the shaft back on the rack and tighten up the lock bolt
May 13, 2015 | 2003 Nissan Altima
Front passenger wheel
Have a competent mechanic determine what is wrong.
Mar 14, 2014 | 1993 Toyota MR2
Steering failure
sounds like the gear box or sterring rack went out have some one move the wheel look see what is moving and wha tis not
Aug 26, 2013 | Jeep Grand Cherokee Cars & Trucks
Right front wheel squeak
Jack the car up put you hand on the 12 and 6 o'clock position and try to rock the tire if it moves it is a bad wheel baring if it squeaks when applying the brakes it can be the pads are worn out if it clicks I can be the half drive shaft if it is a drive shaft run one way if it is quit it is ithe inside it will be noisy if you make circles the other direction then there are the strut towers that can squeak hope this helps
Nov 07, 2017 | 2005 Chevrolet Suburban 2500
Why won't my ignition key turn over and my steering wheel is locked in place at the sametime?
I'm assuming you mean your key wont turn in the ignition. first off check to make sure the car is in park. then what you gotta do is put in the key and put a little pressure as if turning but dont turn too hard, then even though the steering wheel is locked you will have to try to move it a little, if you parked with your tires turned then you will want to try to turn the wheel in the same direction, (even locked you should be able to move it about a half inch) you will have to turn the wheel hard but it should move enough to allow the key to turn, you may have to jiggle the key a little in the ignition but it should eventually turn, just remember not to try turning the key too hard, the extra force wont make it go but can cause the key to break. this tends to happen when you turn the car off andthe steering wheel gets locked if the wheels are turned hard in either direction. also if multiple attempts at this still dont work, try taking the key out and turning it over and trying again. Even though both sides of the key are identicle, because of wear on the key and the ignition, sometimes when the wheel locks the ignition, it will only turn if the key is put in a certain way. Hope this helps, good luck
Aug 29, 2012 | 2002 Pontiac Montana
It starts to swerve to the left or right without turning the wheels almost like your swerving back and forth
sounds as though you have play in steering gear box- most of the time thier is a lock nut on top with a slotted screw in middle loosen lock nut and tighten screw then reset lock nut. do not over tighten slotted screw in fact tighten and then back off half turn so steering box is not too tight.
Jan 26, 2011 | 1981 Ford F 150
There's too much play in the steering wheel of my 94 chevy silverado. How do I fix it?
play in the steering wheel for that truck is more than likely caused by worn tie rod ends, and sometimes ball joints. The steering box is least likely to give you problems, unless it had bolts come loose. Check out the tie rod ends first; with the vehicle off, have someone else turn the steering wheel from left to right within that free zone, and look at the joints in the steering linkage. If you see one half of the joint moving more than the other half, you know it need replaced. If you have more questions, or if you need more help, feel free to post a comment, and I'll check up on it so you aren't left hanging.
May 12, 2010 | 1994 Chevrolet C1500
Steering wheel shudders when turning left 03 ford explorer
when my front wheel bearing went the ABS light came on common on ford (exploders) explorer anyway check the unaversal joint on front there thould be no play at all when moving from foreword and reverse actually easyest way to do this is to jack the tire off the ground and move tire back and forth and look for any play, and last tires ? Are they warn my exploder did the same thing the only fix is 4 new same size tires I changed my wheel bearing and tires and all is good at 94K good luck CJ
May 12, 2010 | 2003 Ford Explorer
Locked steering wheel
Try having someone rock the car frontwards and backwards, while you rock the steering wheel back and forth and try to turn the key - it sounds like you're jammed up hard against the steering column lock.
Please rate if this is helpful!
Mar 17, 2009 | 1996 Nissan Sentra
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
