Question about Sentry Fireproof Safe
How do we see the ecode number on the safe?
When keying in our password to open safe, it will not open the safe and we get a "ecode" error. What do we do now?
  • Joan R Hanson Jan 24, 2013
    You have not given me sufficient tips to open my safe.
    Scholar:
  • Sentry Expert
  • 170 Answers
Once you get the error light that means you are entering a user code that was deleted when the batteries went dead . Simply replace the batteries then use the master code in your owners manual to open the safe. Reprogram new user code instructions bottom of this page.
Posted on Nov 21, 2013
I lost the safe key and the password what should i do
If there is a visible serial number the manufacturer should be able to supply a duplicate key if it is a quality safe.
Your local locksmith might be able to pick the lock and get you inside the safe.
Failing that it will be a case of cutting the safe open to get the contents out and replacing the safe.
Jul 13, 2016 | Home Security
I have a godrej taurus safe .. Was using the default password 1234 to open it but after 2 days the safe is not getting open with its default password its throwing the error messsage in the display.
Follow this link:
https://www.youtube.com/watch?v=E7nWCVN2aME
In the comments you will find that some time ago default password was 2125. If it won't work then movie will show you other method.
Best regards
Mar 15, 2016 | Computers & Internet
Says code error
How To: Open A Locked Sentry Safe If You Forgot ...
? 5:21
https://www.youtube.com/watch?v=Mr8QrvVAtuI
Jul 15, 2014 - Uploaded by TipsNNTricks
I show you How To Open A Locked Sentry Safe If You ForgotThe Combination Or Loss Your Digital Code Or Lossed Your Key. The Sentry Safe ...
' Sentry® Safe ' Lost Your Combination
https://www.sentrysafe.com/.../Lost_Your_Combination
Sentry GroupCombo Recovery. What you'll need: Model Number; Safe Serial Number; Notarized Statement of Ownership. Step 1. Safe Info. Step 2. Notary Form. Step 3
opening a electronic safe forgotten the lock code ready to ...
www.instructables.com/.../OPENING-A-ELECTRONIC-SAF...
InstructablesJul 6, 2009 - I HAVE A SAFE GAURD COMPANIES SAFE I HAVE FORGOTTEN THE LOCK CODE TO OPEN IT. THEIR IS NO ALTERNATIVE OF KEY ...
How to Crack a Safe (with Pictures) - wikiHow
Jan 10, 2016 | Home Security
How do I get the combo for my safe I have the keys.
I can only give you a very basic answer as you provided NO information on the make and model of your safe. First, some safes allow you to change the combination with the safe open so if you have the keys ...no problem. Some on the other hand require you to know the combo to change the old one like passwords, especially if it is one that allows changes from a factory setting. The best advice is that you should contact the manufacturer on changing the combination, since you have the keys with the key number it should suffice to prove you already have access so they can help you without the required written proof of ownership required to open the safe.
Feb 18, 2015 | Home Security
Cannot open my secret safe by justice
Reference: Paisley Electronic Push Code Safe
Item # 5661462
Purchased at Justice. May be one of the following design/colors: 1. Pink and black 2. neon green 3. tye-dye (all in zebra pattern, I believe)
To gain access to safe without code proceed with the following simple instructions:
Use a screw driver to access batteries on the bottom of the safe. Remove all three AA batteries.
WAIT AT LEAST TEN SECONDS before reinserting betteries to functional position. Replace screw. Key in default passcode "0000#" Safe will now be unlocked and upon opening you can reset passcode. Hold down the "*" and when voice prompted to "key in passcode" enter new 4 digit code followed by the # sign... HOLD "*" until completed code with "#" You will hear the voice command, "enter passcode" after each digit entered. [Press & hold "*" (1234) press "#" release "*"] Close safe and new passcode should be set and work properly. If not, enter default "0000#" and try to reset once again.
Feb 03, 2014 | Toys
I have a Sentry A3810. After putting the ecode in and the "Proceed"light comes on,
We believe there is no solution to your problem as lack of opening lock on a periodic basis leads to moisture build up rusting the lock shut. If your model is still under warranty it ca be replaced. Call A1 Locksmith for additional info on drilling it open.
Jan 28, 2013 | Sentry Fireproof Safe
I have a safewell safe. Batteries are dead and I have lost my keys. The reference is EX2006029121. ANY IDEAS PLEASE.
I read this elsewhere. it's worth a try...
"I had the same problem, batteries dead and i could not find the keys. I read on the internet that if you get a hairdryer, and heat up the front of the safe where the keypad is and where the spare key goes in this will work, i thought anything is worth a try. So i held the hairdryer there for a bout 15 mins and what happens is the heat slowly boosts the battery life, enabling you to open the safe. You will notice that you start to get a beep noise from the key pad. even though i was getting a beep from the pad it didnt open straight away but after about 10 mins i retried the code and it worked. Make sure you replace the batteries immediately before closing the safe again "
Jan 25, 2012 | Locks & Locksmithing
My secustar safe wont open by entering my password, dont have the keys since i bought this semi-used on a garage sale. How can i open it? the number under cover is H0667 a locksmith will charge me 40 usd...
I just had the same problem because the battery had died, luckily I didn't sleep through all of my science classes so I got the wifes hair dryer, warrmed up the outer shell of the safe for about 10 minutes which allowed the batteries once last gasp and opened the safe. Changed the batteries and good to go.
Now my question - this is a secustar wall safe and ' thought it came with a key that I can't find nor can I foind a spot to use a key? how do I know if it is the model that uses a key ?
Nov 04, 2010 | Sentry Fireproof Safe
Password for 007 facebook hack v1.0
Facebook Hacking v16.96 :JKP96-3365A-66686-6QWE-223MI
Code Data Analys Repaire By Mirel : zied1
Code Pro Facebook Hack 1.5 by Hacker zmaim : 02102102552
Code Facebook Hack 1.7 by the joker step 1 : 123456
Code 007 Webcam Hack v1.0 : webcamvalid
Code 007 Facebook Hack v1.0 : b.h.y.u.j.h.g..r.df.d.e
Code Pirates Facebook Hack v1.02 by Meril : ililekeyou
Code Pirates Facebook Hack v1.02 by Meril Original : ilikeyou
Code Facebook Hack 1.7 by the joker Step 2 : assel
Code Pro Webcam Hack v 1.0 : Name : hacker zmaim Key : 21X72-MA68I-ZX5V3-D4TLW-JXXZ
Unlock Code Facebreak v2 : marylin monroe
Code 007 Webcam Hack v1.2 Original : wow007
Facebook Password recovery master : aerds-dafvb-ghytg-rfvbn
Oct 16, 2009 | Sony Ericsson K800i Cellular Phone
Replacement Key
goto SentrySafe.combox..
https://www.sentrysafe.com/customerCare/replacementKeys.aspx
request a duplicate key base on the model and serial number on the safe
Nov 17, 2008 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
140 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
 Brian Main
Brian Main
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
