Question about Bushnell Sportsman Rifle Scope 3-9X 40 Multi-X Matte 1" 15oz 0.25MOA
Scope will not zero in. Had the scope for three years Had no problem till recently .
I got my scope for my birthday, got it mounted and zero in used it for three years had no problems. Went to target practice. shot my frist round was off to left about foot. Adjusted less than one quarter turn took another shot it was off to the right about a foot and high. Can't or won't adjust. Please advise. Gerald
  • 115 Answers
I would send it to them to be checked.
Bushnell
Attn repair
9200 cody
overland park KS 66214
make sure to put your name, address, telephone number, and a detailed description of the issue in the package.
Posted on Mar 13, 2014
5 Suggested Answers
  • 30 Answers
SOURCE: scope elevation adjusted allthe way up & still shoots low
Bushnell sells nylon inserts for scope rings that fit inside of the scope rings and will affect the height of the ring to correct the problem. If you install them on the front scope ring, it will correct it and realign the rings correctly. It appears that the front ring towards the muzzle is not as high as the rear ring near the breach. This is why that even though the scope's adjustment is elevated as high as it will go, it is still hitting low because it is actually pointing down because apparently the rear ring is higher off the barrel than the front ring. The Bushnell inserts can correct this.
Posted on Sep 01, 2009
  • 2418 Answers
SOURCE: I have a Bushnell Elite 4200 6x24x40 rifle scope 42-6242M
First is to try for a group, do not adjust the scope in any way. Shoot 4 rounds with out adjusting the scope. The gun should settle down and start to group. If you can not get a group in 6 rounds go clean that gun & check your ammo. Start over. If she does not group, its the gun not the scope. Once it starts to group move the cross hairs in the opp direction small clicks and "TAP' the scope after each adjustment. Shoot for a group each time 2 rounds should group. Get a target that has a grid to help get on faster.
Posted on Sep 24, 2009
  • 2418 Answers
SOURCE: Hello, I have a Bushnell sportsman 3x9 mounted on
Start buy loosening the scope in the mounts. Loosen the front first to see if it is in a bind (left/right). Tighten it back down but not completely. Loosen the rear looking for some movement or popping sound. If you see a movement or notice some odd thing. check the mounting slots for dirt or dings that may cause an offset to the mount. If all is well. Go and start and zero for 13 - 15 yards. you want to be 1 1/2 inch hi. Now after each shot rap the scope with a screw driver handle or something solid, just to give the scope a shock not hard enough to bend it or dent it but shock it. Large scopes are meant for larger shock than a 22 produces, rapping the scope will help move the cross hairs and settle them in place. Hope this Fixya up. If it does help, please leave a testimonial. Thank you for using Fixya.
Posted on Dec 12, 2010
  • 2976 Answers
SOURCE: My name is james and
You backed it off too far and the alignment screw came out of the internal guide. They are usually pretty close to accurate when they are released from the factory. Make sure your mounts are in proper alignment and tight before trying to sight it in. 1 click is normally 1 inch at 100 yards.
Posted on May 14, 2011
What does the 15 ys mean?
How to Zero Your Rifle Scope: 15 Steps (with Pictures ...
www.wikihow.com > ... > Guns and Shooting > Rifles
wikiHowLearning to properly mount, sight, and adjust a rifle scope will result in accurate shots and saved ... MESSAGES. LOG IN ... Start with a good quality base mount and mounting rings to ensure that your scope will be held sturdy for years to come.
Aug 30, 2015 | Optics
Scopes have a spring on one side of the optics tube and a screw on the other side. This is for up and down and side to side adjustments. The issue appears to be that the springs have lost their point of contact or tension.
Nov 22, 2017 | Bushnell Sportsman Rifle Scope 3-9X 40...
Elevation adjustments do not seem to hold or the scope moves slowly over time. I'm not certain. Windage works fine. Looked at manual on the web and the scope must have changed design because not...
Most of the time a scope that creeps off its zero, has a loose mount screw and or loose mounting ring. Check the mounts all screws. Some times the opposite is true. The mounts are to tight and in a bind. Then during firing the receiver heats up an tweaks the scope enough to cause creep. If the scope is always on zero when cold and creeps off after a few shots, she is in a bind. Make all adjustments to the scope base and rings with a cold gun. Loosen the front ring screws first then re-tighten then loosen the rear doing the same. Then try and re-zero the gun. If the gun never comes back to zero, you end one day shooting hi to the right and try again the next day shooting in the same spot try to re-tighten all screws. Screws from mount to gun then scope rings to scope body.
Jan 02, 2011 | Nikon 39x40 Matte Nikoplex Buckmaster...
Just bought this scope and want to use on my rem 243,will it hold a zero once zeroed in?
The ability of a scope to hold it's adjustment is pretty much pre- determined by the quality of the scope itself...Better scopes hold adjustments better than cheap ones. Same goes for the mounts...a good mount will not loosen up or change point of aim.
If you are using a good quality scope and good mounts, once sighted in, unless you drop the weapon or have it shipped as 'baggage" on a long distance hunt, It should stay reasonably zeroed.
A 243 is not known as a "shoulder buster" so recoil should not affect adjustments.
243's are generally used in long range shooting. Therefore changes in temperature and normal use can change point of impact...so can changing the ammo you use. Therefore I don't recommend not checking accuracy before taking any weapon into the field. Wether you are using a $40 scope or a $1000 one, you owe the animal you are shooting, your very best attempt to take it down with one well placed shot. Checking zero at the anticipated shooting distance is the best way to insure that.
Dec 20, 2010 | Chevrolet 3500 Cars & Trucks
Directions for mounting weaver 1inch see thur scope mounts
there the same as any other mounts,,, screw then down on a wever mount and plonk your scope into them,,,then re-zero the scope
Nov 27, 2010 | Weaver 1 INCH PICATINNY WEAVER BASE RIFLE...
In the process of zeroing the scope in I noticed that I can adjust the elevation of the scope up but can't set the adjustment down as far as I need to go in order to be sighted in. This is the first time...
There are a few things that it could be. Make sure you have the scope mounted with the elevation screw on top and the windage screw on the right side. Next, carefully check the distance of the scope from the receiver. If the mounts aren't exactly the same, the scope could be tilted upward. Try switching the front and rear mounts. Make sure you don't have either of the mounts on backwards. Make sure the scope is built for the caliber you are shooting.
If none of these fix your problem, Leupold scopes are guaranteed for life.
Oct 07, 2010 | Leupold Rifleman Rifle Scopes BHK290
I have the 6x18x65LU atn rifle scope. I had the scope mounted to my 30-06 on two 1" weaver rails. the scope keeps sliding forward though the adjustable scope rings. I've been recentering the scope and...
be cearfull you dont crush the scope tube,,but try rapping a little strip of sticky rubber or plastic tape round the scope tube then nipping the scope ring caps down onto this,,,but i think your scope rings are worn out or the wrong size,,ie 30mm not 25mm
i have air rifle scope's on my 7.62/308 and on my 303 none of them move about at all and they have stayed on zero for years now!
Aug 25, 2010 | ATN 6-18X65LU Daytime Rifle Scope
CAN NOT ZERO GUN
You may try to bore sight it first. Pull the bolt and setting the gun on a good rest sight thru the barrel at a dot on the wall within ten feet. Then adjust the scope to that dot. As you adjust the scope tap the bore of the scope with a screw driver handle, tap it after each adjustment not hard, but enough to give it a sharp jolt. Once you are close here, move out to the range and shoot at 15 yards. Using a rest, again tap the scope after each adjustment. Then move out to 50 yards and you will want to be shooting high 1.5 to 2 inches here. Shoot slow keep the barrel cool and try for 2 shot groups till you have got the scope dialed in. Then move out to 100 yards for your preference of zero. Remember use the same ammo you will hunt with or at least the same bullet weight. If you can't get her to get on paper you can try to loosen the scope in the rings, one at the time once the gun is a little warm. Loosen the barrel ring first then snug it back down and then the receiver ring. If your group moved now, she was in a bind due to a cold gun at set up / installation.
Dec 01, 2009 | Optics
Tasco 6x24x42 cosistancey issues afield.
It has to settle in to the mounts an the mounts to the gun. You take a screw driver and tap on the scope as you adjust it. Tap with the handle and just tap it not bang. every time you make an adjustment tap it. The 222 does not give a great kick so you do not get the settling from that, you have to cause it by taping the scope with the screw driver.
Jul 19, 2009 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
Zeroing scope adjustment
First, adjust wind-age and elevation to center or zero position. Remove your scope from the gun and make sure that the scope mounts are aligned, this is critical. Purchase an alignment tool is necessary. Then remount the scope. The scope should seat in the mounts without binding. If it does bind, the mounts are not aligned.
Start sighting in at close range,10 to 30 yards, then move out to 100 yards.
Jan 03, 2009 | Tasco 3-9x40 World Class Riflescope 30/30...
Bushnell Sportsman Rifle Scope 3-9X 40 Multi-X Matte 1" 15oz 0.25MOA Logo
79 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
