Question about Panasonic FP-7735 Black and White Copier
Copier does not start workng
After turning on, my iR 4570 begins loading, but not finishes it. then appears error code E000003-0000 and on display it says that if I just turn it off and the on the problem would be fixed, but with no results. the problem just repeats. how to solve this problem. and what that error code means?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
E000 to E004 are all to do with the fixing unit. It can be reset but if comes back you will have to check the fuser parts. It has been known to be caused by noise on the mains supply so a filter might keep it away.
***ALWAYS DISCONNECT POWER BEFORE WORKING ON MACHINE****
Since this code has not cleared ( so to speak) you will have to check the; fuser thermister, fuser thermal fuse and the fuser lamp. These can be tested with a multi meter. If any or all of these are defective you have to replace. After replacing defective parts, reconnect power, re-clear code and machine should work.
If code re-appears or does not clear then you are looking at a brd (board) problem and should call for to have a tech come out.
To reset. Press the star button followed by 2 and 8 at the same time, then the star button again. You should now be in service mode. Select COPIER and this will give you some options along the top. Select FUNCTION. In the list select CLEAR. From the next list select ERROR and press ok. Then switch off machine and back on at the power socket. If it clears then all is ok.
Be warned!! Do not try to change any settings in service mode or clear any other function!!
Posted on Jan 28, 2009
E0002250001 canon 4570
Disconnect and than connect the flexible cable,if not okay,replace it
Jun 27, 2014 | Canon IR 4570 COPIER FOR 220 VOLTS ONLY
Jam code 205 in canon Ir 4570
Try to open up the copier where usually the paper goes through and check for any remains of bits of paper.
PS: on the screen shows which side of the printer has to be opened.
Feb 24, 2014 | Canon IR 4570 COPIER FOR 220 VOLTS ONLY
Canon Image Runner 4570 saying load staples when staples have been replaced
yes, there is in additional function then Common setting then finisher or staples you swicth to off
Mar 06, 2013 | Canon imageRUNNER 4570 Copier
CANON ir 3530 finisher error
canon ir 3530 shows finisher error (displays spanner)
Nov 10, 2012 | Canon gpr-16 ir 3530 blk...
Canon copier 4570 error code e000007-0000
canon ir 4570 error solution for Code E000007-0000
Nov 25, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Our Canon Image Runner 330S shows error message E014....
is there an error code appear on panel display?
if there a error appear try to reset you may press * key,press 2&8 simultaneously, the select copier then select fuction then clear then error then ok then turn off& on
Jan 04, 2010 | Canon imageRUNNER 400S Copier
E000000-0001
Okay, to be of real help you have to reset the error in service mode as the officetech1 said. To do this you need to press the head key (the head with the star inside) then 2+8 together and then the head key again. This will get you into service mode. Then select 'COPIER' then 'FUNCTION' then 'CLEAR' then select 'ERROR' or 'ERR' press 'OK' then switch the machine off and on again. This may get it working for a while or a long time. But if not, you will need a fixing film unit to remedy the problem.
Mar 10, 2009 | Canon imageRUNNER 4570 Copier
Canon imagerunner 2230
try to clear in service mode touch Additional funcion key then 2 8 at same time then additional func key again in that order screen should change to service mode then touch copier then function then clear then err then ok then turn off machine using main switch if it wont clear you have a bad fuser
Dec 02, 2008 | Canon IMAGERUNNER 2230 Copier
Canon ir 2016 copier on display says ( Download Standby) thanks
We have a Canon IR 2016 J and in a beginning in the dispaly appears the message "Download Stanby" then after we replaced the PCB board appeared the message "System Error E354" what should we do to solve this problem, and if it is possible to send us the Service Manual with error codes for Canon IR 2016
Apr 18, 2008 | Panasonic KX-FB421 Plain Paper Film Fax
Canon ImageRunner 4570 gives me an error code:E000001-0010
A E 000 code is a fuser ass'y problem. It will need to be rest in service mode...
Mar 04, 2008 | Canon imageRUNNER 4570 Copier
Panasonic FP-7735 Black and White Copier Logo
94 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
