Question about Cell Phones
Can't get the can top off my one touch can opener
Seems the batteries may be dead, it stopped in the middle of opening a can. Can get the lid off the can opener.
    Genius:
  • Cell Phones Master
  • 1,669 Answers
If the top is completely off the can, it is just being held by the magnet. You can use a set of plyers to pull it off. If it is still attached to the can and the top magnet you could use a screw driver to pry up the magnet and pry away the can. If there is a mechanical lever to release the can use it as well.
Posted on Jan 22, 2013
3 Suggested Answers
  • 1696 Answers
SOURCE: I bought a htc touch vivaT2223 in russia.but it
Well if you are tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
Posted on Jul 24, 2011
  • 12 Answers
SOURCE: I have a Samsung Seek
You need to Calibrate your phone. If you go to settings their should be touch settings and from their you should find the Calibrate option.
Posted on Jun 16, 2011
No spin
check the lid switch,close the lid and then open it a few inches close and open it a few times like this,you should hear a clicking sound when you do this,if you don't the lid switch is bad,common problem,
Jun 30, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore washer stopped dead in mid load.
Check the lid switch. You should hear it click when you open and close the lid. If you don't hear a click, replace the switch.
Oct 18, 2011 | Kenmore 24032\24036 Top Load Washer
It filled up with water and when I closed the lid it just wouldn't work. I checked all the plugs and fuses and besides all this I have all my clothes in the machine soaking. Help please?
check the lid switch,you could have broke it when you closed the lid.also next time you write send the model number,open the lid,get a screw driver and stick it in the hole on top,that's the lid switch set the timer to spin,or close the lid then open it an inch and close it and open it if you don't hear a clicking sound the lid switch is bad.all the lid switch does is to stop the washer from running with the lid open for safety reasons
Jun 10, 2011 | Whirlpool Washing Machines
Top Loader stopped during spin cycle and now won't work
The lid switch cuts off power to the washer and will cause the washer to stop and not to start at all when it fails or when the lid switch strike breaks. Check the lid switch strike located on the middle right side of the lid. Replace the lids witch strike if it is broken with part number 3950298.
Push and hold the lid switch, using a screwdriver, through the hole on the right side recess of the top cover and start the washer. The lid switch actually clicks when activated.
Check the continuity of the lid switch when activated if the washer still doesn't start when the lid switch is pushed and held. Disconnect power to the washer prior to servicing to avoid the risk of electric shock.
Remove the screws at the front bottom corners of the console then slightly pull the console forward to clear the console tabs from the slots on the cabinet, and then flip the console to the rear of the washer.
Disconnect the wiring harness connecting the timer to the lid switch wiring harness connector on the cabinet then using an ohmmeter, check the continuity of the lid switch while it is being pushed. Set the ohmmeter to XR1 then touch the test leads to the right and left terminals of the lid switch connector. Replace the lid switch when the resistance reads open.
Apr 06, 2010 | Washing Machines
Washer is full of water and completely dead...
the maytag atalntis is a great machine but often falls victim to the lid switch problem
try pushing in the lid switch, right in the middle on top of the lid
you will se a lil plunger, push it in
AP4008646
goto appliancepartspro.com
runs aound 20.00 but im sure thats your issue
Oct 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My Boxter battery is dead and I am not able open the trunk lid.
I have two Boxsters and have had to use this fuse box procedure on each. On the first car I followed the instructions in the manual and it worked perfectly. On the second car, I followed the identical procedure and nothing happened. After much fiddling, I realized that the clamp on to the door latch was not making a ground connection. Try touching the ground clamp directly to the head of one of the bolts on the door latch. This worked for me and the hood opened instantly. The quality of the ground connection seems to be the key. By the way, if you do not want to use a donor battery, a battery charger will provide sufficient power to release the hood latch. Good luck.
May 12, 2009 | 2001 Porsche Boxster
2000 Jaguar SK8 Cant open trunk...batteries dead.
you can charge the battery from the engine compartment. check your owners manual that is the correct place to jump and to charge the battery.
Apr 06, 2009 | 1998 Jaguar XK8
Whirlpool wahing machine LSQ954PW2
Hello lmaichin
Welcome to Fixya
My name is Huum,
You said,
Machine stopped in middle of cycle and is in a froen state. Checked power 115 volts available to the machine. Suspect switch detecting lid opening is defective. Can not even find sensor switch. please HELP!
At this site you will find the diagram you need. Lid Switch is # 11
http://www.pcappliancerepair.com/model-display.php
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
The Maytag top loader washer MAV7750BGW started to fill at the beginning of the washing cycle then stopped. Could not get it to do anything on any other cycle steps. Electrical supply OK. Managed to get...
It sounds like you have a lid switch problem. Check your the lid on your washer and see if it's not bent towards the middle. Often as things get sat on top, it will bend and not allow the switch to make contact. The washer doesn't do anything but fill when the machine thinks the lid is open. Try bending the middle of the lid back to where it is straight.
Jun 18, 2008 | Maytag Washing Machines
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
