Question about Poulan Pro Chain Saw 46cc 20"
My Poulan Pro 4620 AVX was running good and easy to start but after a couple hours of pretty heavy cutting it began to lose power and die when the trigger was released. Each time it died it was more difficult to re-start and on the fourth or fifth time it wouldn't start at all. I cleaned the air filter, the spark plug and put fresh fuel in but it still won't start. What could be wrong?
  • Poulan Master
  • 7,063 Answers
Check the exhaust screen
Posted on Aug 09, 2017
  • 4088 Answers
SOURCE: Poulan Pro Chainsaw(PP4218AV) worked for a while now won't start
It's possible that the carburetor diaphragm in the lower chamber has hardened or cracked. Does the primer bulb fill with fuel after several pumps? If not, try moving the line that comes up from the fuel filter to the carburetor over to the primer port that normally connects to the other carburetor connection. Try to pump fuel again--if successful, then there is blockage within the carburetor which should be cleaned with spray carburetor cleaner inside and out. There is a small filter screen inside the main body that can be easily plugged with stale fuel. Hope this helps!
Posted on Jul 11, 2010
  • 248 Answers
SOURCE: Poulan pro 4218 avl, starts (sometimes) then dies,
may be choke problem,about 20.00 for repairman to fix
Posted on Oct 08, 2010
  • 1015 Answers
SOURCE: Hi, I just cleaned my
The fuel pick up or filter should be changed every year but if your saw will start and run good but just not idle then adjust the screw marked T counterclockwise slowly until chain starts to rotate without you depressing the throttle.At that point back it off about 1/16 of a turn until saw will idle but chain doesn't move.Thank you. P.S. If you want to you can go back to factory setting by turning H & L fully closed then open 1 to 1 1/4 turn and very slowly adjust for smoothest operation. Do not adjust H anymore then minimum off factory to avoid engine damage.
If you need further help I would suggest you have a trained tech.service it. Good luck.
Posted on Feb 14, 2011
  • 2239 Answers
SOURCE: My Poulan 260 pro starts and runs for 15 - 30
If you have changed the fuel filter, and the hoses are not leaking, then you may well have a blockage in the internall filter in the carb, the filter is under the alloy pump cover, usually secured with a single screw.
Posted on May 15, 2011
  • 2239 Answers
SOURCE: Chain will not stop spinning
I would say it has an air leak, through a gasket or crank seal, make sure the carb is tight and sealing properly.
Posted on Jun 15, 2011
Poulan pro brushcutter ppb150e is starting but cutting off after a few minutes, why is this?
FAQ Trimmers ' Poulan Pro
www.poulanpro.com > Customer Support > FAQ
If the unit has an on/off switch, move it to the on position (usually indicated by the ... This should happen between 1-6 pulls, but no more than 6 pulls. 7. ... Some units use a carburetor which does not require holding the throttle trigger. ... If you smell fuel after following the starting procedure, assume the engine is flooded.
Poulan Pro Trimmer dies when I give it gas.? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
May 22, 2007 - If you remove the two springs holding that cover on the muffler off you can ... Put it all back together and you should be able to crank up and cut. ... Poulantimmer PPB 100 JUNK, since new hard to start cannot keep running ... If, it sit with fuel in the carb then it may still need cleaned with some Carb Spray.
[PDF]OM, PPB150E, 2007-01, TRIMMERS/EDGERS - Poulan
Nov 25, 2015 | Poulan Garden
I have a Poulan Pro PP4620 AVX 46cc Gas Chainsaw w/20
If this is the tooless adjustment, it sounds like the small gears in the cover have stripped, remove the side cover, turn it over and remove the cover over the tentioning mechanism, replace parts as required.
Apr 18, 2012 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
Will not stay running
You have a fuel delivery problem. Main reasons for this is a dirty or plugged up carburator. If you know what you are doing, clean the carburator. If you let gas set in it for more than a month or so without starting it up, the good ole ethonal in the fuel has gummed up inside the carb. Once you get the carb clean (jets, ports, etc) and it still doesn't run replace the fuel pump. Cheap as heck and easy to install. Both items can be done in less than an hour and cost you about 25 bucks.
May 14, 2010 | Poulan Pro " Pro" Self Propelled Mower
Tile saw began having trouble starting. I would
Your motor brushed sound like they're gone bad. Some electric motors have two small plugs on the side which house the brushes. See if yours has this and get new parts. The other possibility is that the bearings are corroded and has built up enough resistance to stop everything.
Might not be able to replace those, however.
Oct 04, 2009 | Dewalt Heavy - Duty 10" Wet Tile Saw -...
Dies when pressing the accelerator
If your chain brake is not engaged, which i am sure you have checked, look at the air breather filter or the exhaust muffler which could be blocked with carbon.
Jun 08, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Idels good but when i start to cut it bogs doun
Either the spark arresting screen is clogged with carbon, or the carb is out of adjustment on the high speed jet.
Mar 31, 2009 | Poulan Weedeater/Electric Trimmer 4.1 Amp
34 cc Poulan,dies out when tipping it to side to cut tree.
I would check the fuel line for a pinhole or crack.It may need replaced.
Mar 14, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro Lawnmower
i have a 950 zx poulan pro lawn tractor. it will start but when i release the brake it cut off . i can start it up with out sitting in the seat.
Jun 14, 2008 | Dryers
Poulan Pro Chain Saw 46cc 20" Logo
69 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
