My DVD drive suddenly stopped responding. I restarted my computer and the drive-logo(H:) in MY COMPUTERS appeared for a second and then suddenly it disappaeared. I entered a CD , but there was no response. Now, each time I start my computer , I can't find my DVD Driver(H:).......How can I solve it?
    Problem Solver:
  • 11 Answers
Go in the device manager delete the drive and reboot
Posted on Feb 14, 2009
How do I solve a problem with starting up windows in my hp pavilion g6? Whenever I start windows a blue screen appears and the computer restarts.
Sounds like your hard drive has either failed, come disconnected, or someone performed a full format of the drive which wiped out the partitions or the boot sector of the drive. Worst case you will need to replace drive and purchase reinstall disk from hp. Best case you will only need to purchase reinstall disk from hp. If you do need a new drive, I recommend purchasing it from hp directly, as it will already be prepared with hps proprietary boot configuration files which must be present for hardware to be recognized by system bios.
Dec 31, 2016 | HP Computers & Internet
My drive may have shorted out
Drive did not short out.. It DIED. There is a difference.
Aug 28, 2017 | Iomega Computers & Internet
How to watch movie here??
Perform an observation of the computer devices disk location compartments. For example, computers would provide logo indication of what media disk is displayed on the location drive. In situation that the computer disk area has CD rom, DVD rom, or CDRW or DVDRW is indication that movie disks with mentioned logos is displayable at insertion. Second, observe that the computers disk logos made specific demarcations least an alternate disk would least produce impressive expectations. Acquire a disk media at retails with movie material. Once inserted in computer disk compartment should take effects discussable. For example, the computer is prior designed to auto detect media material at insertion in components. Computer program also known as multimedia player displays momentarily after disk has been detected on computer. Compatible disks would display the media expectation either as audio CD or DVD movie. Alternately, in situation that the computer least displays recognizing media disk is indication that each entities has malfunctions. First disk media that least has movies or encountered malfunction is least recognized at insertion in computer compartment. Second, computers that least has the innovativeness of the disk media least recognize an impression. Alternately, computers that an internet connection would recommend a means to restoring malfunction that is encounter at inserting media in compartments. An expectation is to perform update to capture displays to outdated disks. Alternately, modern disks are recognized on computers that have network connections as least having the programs to capture an impression.
Feb 27, 2011 | Computers & Internet
Describe your sony vaio PCG-C1VRX/K Problem: O/S not found...cannot enable usb/cd use to fix/load new O/S
What do I do if the message "Operating system not found" appears when my computer starts, and why won't Windows start? ? Make sure the computer does not have a "non-bootable" floppy disk in the floppy disk drive (if applicable). ? If a non-bootable floppy disk is in the drive: 1. Remove the floppy disk. 2. Restart the computer and confirm that the Microsoft® Windows® operating system starts properly. ? If Windows still does not start, follow these steps to initialize the BIOS: 1. If there is a disk in the floppy disk drive, then remove it. 2. Turn off the computer. 3. Remove any peripheral devices connected to the computer. 4. Restart the computer. Page 1475. Press F2 when the VAIO logo appears. The BIOS Setup window appears. 6. Press the Right Arrow key to select the Exit menu. 7. Press the Down Arrow key to select Get Default Values. The message Load default values for all SETUP items appears. 8. Press Enter. The Setup Confirmation window appears. 9. Select Yes, and press Enter. 10. Select Exit (Save Changes), and press Enter. The Setup Confirmation window appears again. 11. Select Yes, and press Enter. The computer restarts. What do I do if my computer stops responding? Why can't I turn off my computer? It is best to turn off your computer using the Turn Off Computer option on the Microsoft® Windows® Start menu, located on the taskbar. Using other methods, including those listed below, may result in loss of unsaved data. ? Click Start on the Windows® taskbar, select Turn Off Computer, and then click Turn Off. ? If your computer does not turn off, press the Ctrl+Alt+Delete keys simultaneously. When the Windows Task Manager dialog box appears, click Turn Off from the Shut Down menu. ? If your computer still does not turn off, press and hold the power button or slide and hold the power switch until the computer turns off. ? If your computer stops responding while playing a CD or DVD, press the Ctrl+Alt+Delete keys simultaneously. You can turn off the computer from the Windows Task Manager. Pressing the Ctrl+Alt+Delete keys simultaneously or turning off the computer with the power button or switch may cause loss of data. ? Remove the AC adapter and battery.
Dec 13, 2010 | Sony VAIO PCGK45 PC Notebook
I can't fomat my computer as i don't know how to set first boot device as my DVD drive
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
but if you format your hard drive you will lose the current operating system and you will have to install another operating sytem unless you partition your hard drive and intall another operating system to that partition
hope this helps
Nov 26, 2010 | IBM (25P3294) Motherboard
Computer keeps rebooting at login page. It starts up by saying it has 3 of 3 updates and don't turn off the computer and it then goes to the login page for a split second before it reboots, How do I fix...
Hi, this is a common problem with a vista update, dont know why it does it, just does! When it tries to restart keep pressing the 'F8' button and you should get advanced boot options menu where you can get windows to try and repair itself to an earlier restore point, if the problem persists then I'm afraid you'll be looking at restoring back to original factory settings. Below is an extract from the Dell manual found at
http://book-lab.ru/pdf/DELL-INSPIRON/service_manual_for_DELL_Inspiron_1525.pdf
Restoring the Computer to the Default Factory Configuration
The Dell Factory Image Restore option allows you to restore your hard drive
back to its original factory configuration as when you first ordered it from
Dell. This option appears on Dell computers that were originally pre-installed
with Windows Vista® and does not include computers purchased through
the Express Upgrade promotion or computers that were upgraded to
Windows Vista from another version of Windows.
NOTICE: When you restore the computer to the default factory configuration, all
data on the C drive is deleted. Before performing this procedure, back up personal
files. If you do not back up personal files, the data is lost.
1 Restart the computer. To do this, click Start → → Restart.
2 As the computer restarts, press <F8> until the Advanced Boot Options
menu appears on the screen.
NOTE: You must press the <F8> key before the Windows logo appears on the
screen. If you press <F8> after the Windows logo appears on the screen, the
Advanced Boot Options menu will not appear on the screen. If you do not see
the Advanced Boot Options menu, restart the computer, and then repeat this
step until you see the menu on the screen.
3 Press <Down Arrow> to select Repair Your Computer on the Advanced
Boot Options menu, and then press <Enter>.
4 Specify the language settings that you want, and then click Next.
5 Log in as a user who has administrative credentials, and then click OK.
6 Click Dell Factory Image Restore.
7 In the Dell Factory Image Restore window, click Next.
8 Select the Yes, reformat hard drive and restore system software to factory
condition checkbox.
9 Click Next. The computer is restored to the default factory configuration.
When the restore operation is completed, click Finish to restart the computer.
Hope this helps!
Jun 04, 2010 | Dell Inspiron 1525 Notebook
Acer laptop Aspire 5535 DVD drive stopped working for no reason
It would seem the drive probably has a mechanical or electronic fault...
You did say it is a new computer. If it is there should be no real problem due to the usual warranty and the responsibility the retailer has for the products they sell. In addition if you paid by credit card you might discover it provides additional protection against faulty goods.
Apr 22, 2017 | Acer Computers & Internet
Optiarc DVD Drive does not work anymore.
Try uninstalling the device in the Device Manager, then restart the computer. See if Windows redetects the device and reinstall it. Next, try accessing the BIOS and see if the BIOS sees it, and be sure its enabled there. If both of these options fail, open the machine and make sure that the drive has a working power connector attached. If the connector is bad, switch the power lead over to a working connector.
Jan 28, 2009 | HP Pavilion a1620n (882780664494) PC...
Cd Drive Doesn't work anymore.
Okay. Restart your computer and after, go to device manager (right-click on My Computer/Properties/Material/Device manager). Do you see a CD-Rom/DVD drive?
Sep 01, 2008 | Computers & Internet
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
