Question about Frigidaire Washing Machines
E13 frigidaire affinity washer air leak in air bell
Error code 13 1st step is it leaking water, its not, second step check for air leak in air bell system, third check sensory board. How do you check for an air leak in the air bell system?
  • 100 Answers
SOURCE: frigidaire affinity front loading washer
Any E20 code means your washer doesn't drain.  More than likely there is a screw, nail, coin, bobby pin, etc locking up your pump and causing it not to drain.  Keep in mind that your washer has a 1 yr warranty but some service companys will charge for this kind of repair because it is not technically covered under warranty.
Posted on Oct 30, 2007
  • 1314 Answers
SOURCE: Frigidaire Affinity Front Load Washer leaks soap
back of the washer remove the top panel
Posted on Mar 14, 2008
SOURCE: ERROR CODE E20
Just fixed mine, only I did not have to take it all a part. Just tip it over and reached in thru the opening in the bottom. Took the clamp loose with a phillips screwdriver and pulled the rubber off that contains the filter. Stuck my hand in the opening and pushed up on the filter from the bottom on the rubber container. Out came the filter and I cleaned it and pushed back down inside until it was past the lip that held it in place. Works great, took about 10 mins., not bad for a woman, huh. Thanks for the info, could not have done without your diagram and information.
Posted on Jul 26, 2008
localwonder
  • 6784 Answers
SOURCE: my frigidaire affinity wont start
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
Posted on May 29, 2009
beltronic205
  • 1467 Answers
SOURCE: i transported my frigidaire front load washer.water leaks.
Check your pipes /drain and sump hose sounds lie something has came off in transit
Posted on Apr 08, 2010
Error code 13. Turned water on to machine and it leaked.
Try this link
it says the following:
E13 Condition Water leak in the tub or air leak in pressure-switch air hose Check/Repair The washer fills for too long without the water level pressure switch tripping to indicate that the washer is full. Check for a leak in the wash tub. If the tub is not leaking, check to see if the washer is overfilling. If it is, check the air hose and water-level pressure switch for problems.
Shop Parts Outer wash tub, Air hose, Water-level pressure switch
Frigidaire Front Load Washer Error Codes Sears PartsDirect
Jun 09, 2015 | Frigidaire Washing Machines
Error code E:13
I thin E13 is motor error, I will check.
Sep 03, 2008 | Bosch Nexxt 300 Series WFMC2201UC
Tip
Frigidaire Affinity Common Error Codes. (E4A, E9E, E56, E46 and more)
Hi.
This error codes apply to Frigidaire Affinity washers and dryers:
E11 - Fill time too long.
E13 - Water leak in tub, or air leak in air bell.
E14 - Reed switch.
E21 - Water not pumping out fast enough.
E23 - Drain pump relay on control board failed.
E24 - Drain pump relay on control board failed.
E31 - Pressure sensor not communicating with control board.
E35 - Pressure sensor indicates water overfill.
E41 - Control board indicates door switch is open.
E42 - Door remains locked after cycle is completed.
E43 - Control board problem
E44 - Control board problem.
E45 - Control board problem.
E46 - Control board problem.
E47 - Control board is sensing the door PTC circuit is open during spin.
E48 - Control board is sensing the door PTC circuit is closed.
E4A - Program Timeout Fault.
E52 - Bad signal from tacho generator.
E55 - Motor overheating.
E56 - High motor current.
E57 - High current on inverter.
E58 - High current on motor phase.
E59 - No tacho signal for 3 seconds.
E5A - High temperature on heat sink.
E5B - High temperature on heat sink.
E5C - High temperature on heat sink.
E5D - Communication problem.
E5E - Communication problem.
E5F - Communication problem.
E67 - Input voltage on microprocessor incorrect.
E75 - Water temperature sensor circuit (digital readout models only).
E76 - NTC temperature for the cold water valve over the limits
E95 - Communication error.
E9E -Voltage error.
EB1 - Incoming power frequency out of limits.
EB2 - incoming line voltage above 130 VAC.
EB3 - Incoming line voltage below 90 VAC.
EF1 - Clogged drain pump.
EF2 - Too much soap.
on Apr 09, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Loc error code Frigidaire frontloader
From the frigidaire site.
Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 Too much soap.
Jul 24, 2014 | Frigidaire GLTF2940ES Front Load Washer
Error code e13
Hello Billy, I understand your unit is displaying error code E13. Here are a few troubleshooting tips that may help you get to the root cause:
· First, be sure that your tub is not overloaded. Sometimes when overfilled, water can and will slosh outside of the unit.
· If the tub is not overfilled, check your hoses and other connections. Like most laundry units, there is always some vibration associated with the functionality of the machine. As the appliance is used over time, hoses and other connections can loosen and begin to leak. Be sure to secure any loose connections.
· If the above items did not assist you in resolving the issue, it could be a number of other underlying causes - primarily an electronic pressure sensor, switch or the unit's main control board. These parts are commonly replaced by experienced service technicians.
Aug 03, 2013 | Frigidaire Affinity ATF7000ES Front Load...
Error code e13
Hello Mark Depner - Typically error code E13 indicates that the washer is detecting a water leak in tub or air leak in air bell. You will need to contact a professional to move forward accurately and verify where the leak is located.
Oct 06, 2012 | Frigidaire ATF6000ES Front Load Washer
I have a Frigidaire Front Load Washer during its cycle usually 24 and 16 min into the wash cycle it will stop and beep giving a E10 error message. What does this mean?
The cause of the error is that no cold water is getting through the cold water valve (inside the machine).
The E10 error indicates that one of a group of error codes occurred. The specific code could have been one of the following:
  • E11 - Fill time too long. (See test 1 below)
  • E13 - Water leak in the tub or air leak in the air bell. (See test 2 below)
  • E14 - Dispenser drawer reed switch is open. (See test 3 below)
To recall the specific fault code from this group, follow these steps:
  1. Wake the machine by pressing any button
  2. Wait 5 seconds
  3. Press and hold the Start and Pause/Cancel buttons simultaneously
  4. All LEDs will go blank and after a few seconds the control will signal the stored code
Based on the specific error code, follow the specified test and troubleshooting.
The magnet for the dispenser drawer reed switch is shown in the second image below. If this magnet is missing, you will get the E14 code.
Some of the troubleshooting provided is intended for service technicians. Do not conduct any test or troubleshooting that you are not completely confident that you can safely complete. Unplug the washer before accessing internal components.
http://appliancejunk.com/forums/index.php?topic=1364.0
That website above directly addresses your issue.
Jun 01, 2010 | Frigidaire ATF6000ES Front Load Washer
E10 error
Wait 5 seconds
Good Luck!!
Thanks
Jul 06, 2009 | Frigidaire ATF6000ES Front Load Washer
E20 error message
replace the control panel or have it repaired,there is no e20 listed as a trouble code,so it needs to be replaced.
To clear latest stored error code:
Place the control into Diagnostic test Mode.
  • Turn the program knob clockwise 9 clicks from the Start Position. The control will signal the last error code.
  • Press and hold the Options and Pause Cancel buttons for 3 seconds. The code will be cleared.
  • Exit Diagnostic Mode to return the washer to normal operation.
E14 Reed switch.
EF2 Too much soap.
Apr 22, 2017 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
248 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
