Question about Casio Parts Cash Register PC Desktop
How do you assign a key for a clerck. - Casio Parts Cash Register PC Desktop
  • Casio Master
  • 1,780 Answers
On most machines a PIN number must be entered and then the clerk button pressed. If the PIN numbers have not been assigned, the default is usually 1
Posted on Jan 23, 2013
How to make a template (not line) shortcuts on Casio Classpad fx-CP400?
I suggest you play with key combinations (Shift + some key) to discover if there is any beautiful template that gets generated by it.
Dec 04, 2017 | Casio Office Equipment & Supplies
Programming keyless remote
Below is a couple proceedures on the subject --first one sets your personal security code in case you lose your Fob or if the battery should die the second one is ASSIGNMENT of a Key Fob to the bike
Below
mail_dir.ashx?url=http%3a%2f%2fwww.fixya.com%2flxp.gif%3ftype%3dimpression%26mailid%3d204&met=0&mt=204 This must be done when you buy a new button type key fob for the Alarm if you lose one.
I assume you know your personal entry code using the directional switches and the key switch to activate , if not , it's in the
Owners Manual
If you never set the code,the dealer can help you out here.
1. Set run switch to off
2. ign to acc
3. hold both turn sigs till lights flash
4. use
Left Turn Signal to enter number by pushing 7 times
5. use right turn signal as enter key
6. repeat until all 5 are entered and you hit enter
lights should flash and you should be OK.
KEY FOB ASSIGNMENT
The Key fob on TSSM motorcycles must be set so it will operate the alarm system on the vehicle.
This assignment must be completed with no pauses between steps greater than 10 seconds.
Turn the ignition OFF after all key fobs have been assigned.
The
programming mode will also exit after 60 seconds has elapsed without detecting any fob signup messages
or turn signal switch activity.
Two key fobs may be assigned to the TSSM.
The first successful attempt to program a fob will disable all previously assigned fobs.
If a second fob is to be programmed, it must be done in the same programming sequence as the initial fob.
Nov 16, 2013 | Harley Davidson Motorcycles
Always show pls clerck on the display
What is " pls clerck "? What kind of Computer?
Dec 27, 2012 | Computers & Internet
HOW TO ASSIGN A DEPARTMENT TO A KEY
Check and see if you assigned it as a PLU or as a department or as a group. Go for department
Nov 12, 2012 | Sharp ER-A420 Cash Register
Royal Alpha 9500ML Cash Register Error reads = Clerk logon is required but no passcode has been set for a clerck? I'm still seeking help.
when the register is in "reg" mode first hit "1" and then "clerk" button. it will fix your problem. the same thing happened to me.
Aug 29, 2011 | Office Equipment & Supplies
How do you record on tracks 3-8? i can record only on tracks 1 and 2, this is marketed as an 8-track recorder but is it really?? if i cant record on track 3 or track 4 then i just waisted alot of money i...
Yes you can record on the other 6 tracks, but you need to assign them.
If you are having problems assigning them, don't forget that you need to clear the previous assignments (for track 1 and 2 for example) FIRST, before you try and assign to say tracks 3 & 4.
To clear assignments hold down the assign key and the previously assigned tracks should flash. While still holding the assing key, press each one of the flashing channels seperately to un-assign them. Now release the assign key.
Jan 08, 2011 | Tascam Dp-02cf Digital 8-track Recorder
Assigning keys
If you want to assign speed dial keys watch this clip
To assign other fuctions watch
Mar 11, 2010 | Samsung Prostar DCS-24B-LCD Corded Phone
Nokia 6085 how to speed dial
To assign a number to a speed dialing key, select Menu > Address Book > Speed
dial list, and scroll to the speed-dialing number that you want.
Select Assign or, if a number has already been assigned to the key, select Options >
Change. Select Find and the contact you want to assign. If the Speed dialing function
is off, the phone asks whether you want to activate it
FOR MAKING CALL
Assign a phone number to one of the speed dialing keys, 2 to 9. Call the number
in either of the following ways:
• Press a speed dialing key, then the call key.
• If Speed dialing is set to On, press and hold a speed-dialing key until the cal
Dec 22, 2008 | Nokia 6085 Cellular Phone
Nokia 1100 Speed dialling
Press Menu, select Contacts and Speed dials. Select the key you want,
( to ) and press Assign. Select whether you want to assign to call or to
SMS. Select the name you want and press Select.
After the phone number has been assigned to a number key, you can speed dial
the number in the following ways:
• Press the corresponding number key and then press Call, or
• If Speed dialling is set to "on", press and hold the corresponding number key
until the call is started
Nov 30, 2008 | Nokia 1100
I want to call record in nokia n73
You can assign any selection keys ( 4 keys on the top of the numerical key pad) as recorder key.
ASSIGNING A KEY
Eg :- to assign right selection key as recorder .
press menu key.. go to the folder named tools... setings...phone...standby mode ..move cursor to right selection key and select recorder.. when you exit from the menu you can see recorder on your right selection key.
Recording
while recieving or making a call you can click the right selection key and record the incoming and out going audio.
if you dont want to assign the keys...
while on a call go to menu... office ...recorder..
Aug 11, 2008 | Nokia N73 Cellular Phone
Casio Parts Cash Register PC Desktop Logo
18 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
tomferryman
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
