Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Computer file sharing
I have a Dell laptop with WiFi, using windows vista home premium. It connects to the internet through a Lynksys WiFi router with several desktops connected via ethernet cables (cat5). Is there a way I can set up the laptop to share files with one of the wired desktops that is running windows XP with all service packs installed?
  • 50 Answers
First check,
laptop and pc is in same workgroup.
then,Right ckick on the file---------------share and security-------------cilck on blue under line like if you understand security risk....................................--------------then choose just enable file sharing---------ok
its done!
Posted on Apr 04, 2009
Enable ICS on a windows Vista Home Premium Machine(Dell)
- Configuration on the machine that is connected to the internet.Firstly make sure that firewall on the machine is configured to allow ICMP and access to HTTP / HTTPS. Also make sure that the port 80 is opened on the firewall
To enable ICS perform the below steps - Identify the Dial-up connection that has to be shared - Right Click on the Dialup connection and go to properties, in the sharing tab enable ICS and choose the connection through which you would share the internet to your network.
- Configuration on the Client Machines
Connect the other computer to this one
You should be good to go now.
* I am assuming that you are not using a router or a hub, it is a direct connection.
Apr 04, 2011 | Microsoft Windows Vista Home Premium with...
Vista to Vista wireless, Can't share printer
So your third laptop which runs Vista cannot connect to the Printer and Dell machine?
There are some reasons for that. First check whether you have access to the Dell machine (whether you can reach it) Open a command prompt and do a ping to verify the connectivity. Example. ping (The ip address should be the one of your dell machine. You can find it by running ipconfig in a command prompt on Dell machine.)
1. If you cannot reach it you have to check the network utility (wifi or any other method you use). Make sure that it function properly. 2. ping the router using router's ip address. If ping works you can reach up to their. So from there you can check the Lynksys management console to know why it blocks the machine entering the wlan. May be a addressing issue or authentication issue. If you cannot reach it however it might have problems with the connection as well. Make sure that you allow connections to the wlan on Toshiba Vista laptop if you use a antivirus solution with a firewall or any other firewall.
If you can reach the machine (or even if you cannot reach) you must check whether you have access to the workgroup (you have to join if you are not in the workgroup which you use) and you must enable file and print sharing. If you run the windows firewall that would block you in as well. Its better if you can check whether the print spooling service runs. Start -> Run Type in services.msc Hit enter. Check and enable the service.
If you can reach the Dell using a ping: Check whether the dell machine can access the laptop. Use my network places. It will ask you for the credentials. Provide them. If any error occurred try detecting the network. Add the machine properly to the workgroup. Enable access to the machines via file and print sharing in windows firewall. (go to the firewall go to Exceptions tab and select the File and Print sharing)
Check this Microsoft resource as well.
Please rate the answer and a testimonial (comment) if the solution helped you to solve the problem...Thanks for contacting Fixya
May 30, 2010 | Linksys WRT160N Wireless Router
How to make vista act as router? without using any outside router !! the inbuilt wifi syatem should act as router..
Yes well IF you use two network cards, a WiFi Adapter & an Ethernet Adapter, you can do this, now with a WiFi adapter, as you say, What you do is connect to the internet on the PC, and "Share" the internet connection via the WiFi. You set up the WiFi as either an "Access Point" or a an "Ad Hoc" network, if you want to communicate with the "Other" PC's, and have then communicate with you, as well as access the Internet. So setup is simple, using the manufacturers DVD install the WiFi. card, then, Set it up as you wish, the PC's that connect should be in the same Workgroup, have sharing enabled and be passworded too then as said connect to the Internet and the "Other" pc's will be able to "Burrow" out through you Internet, through the ADSL Modem attached to the "Main" PC. Usually via the Ethernet port. You still need to set up an SSID and use a WAP/WEP key for security. on the WiFi card.
Mar 08, 2010 | Microsoft Windows Vista Home Premium with...
File sharing between computers
Thanks for giving me the opportunity to help. Try the following:
On your laptop with Vista, click start, then network from the right side. This will take you to the Network Screen. Click on the Network and sharing screen. Click on options such as file sharing, printer sharing etc. Make sure that you can see each device your your network. If you can't you must go to each PC and use the network options on the XP machines. It's pretty simple, just follow the instructions that the wizard provides.
I hope this gets you up and running. Thanks for using
Jan 27, 2009 | Dell Inspiron 1501 Notebook
DNS error when connecting PS3 to internet
you could try getting a wifi adapter and creating an access point, you can connect that way if your ps3 has wifi I have a laptop with windows XP Pro and have been trying that my desktop PC with Vista Home can see it.
MY Components:
-Desktop PC with Vista Home (Main PC, connected to Internet with Ethernet to a Linksys Wireless Router B and G).
-Get internet thru cable TV (broadband),from this cable modem plugs to router and from router to PC Vista(desktop)
-Linksys Wireless G/B Router
-G-Card for my Laptop Windows XP Pro and
-Playstation 3 capable of sharing info and use printer
At the moment all of them have internet w different IP's (,,etc.). What I want to achieve is that I can use the Printer that is connected via USB to my PC Vista (desktop) and share files. Right now the only thing been able to do is that my PC Vista see my Laptop but Can't find my PC on my laptop. Anybody, Help?
-When I turn On my media sharing in my PS3, my internet on Laptop loses it while PS3 search and find,then, because laptop lost wireless,the PS3 looses the laptop and I get wireless back. I knowis a stupid setting but tired of workin back n forth. Thanks
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
Cannot Communicate from Computer to Computer
A connection from USB adapter directly to USB adapter may or may not be possible. Borrow a wireless router from someone and use it to test supporting connections to your two computers. I think you will find this a much easier way to proceed. Routers can be had for $40 or less. Shop around.
Good Luck
Nov 18, 2008 | Linksys Wireless-G WUSB54G 802.11g/b
Laptop accesses network, but not desktop
you need tocheck the sharing, on both pc's go to taskbar on right, right click the network icon, click network and sharing centre and ensure the sharing buttons are all on.
Make sure thay are also on the same workgroup, right click my computer icon>properties>advanced system settings>click computer name tab and check the workgroup name is the same eg both mshome or workgroup
Sep 03, 2008 | NetGear RangeMax WPN824 Wireless Router...
Wireless Networking
hey,, the reason why your pc cannot see the laptop or vice versa is cause you dont have public domain or file sharing enabled .. to to the follow these
1.) Click start then control panel
2.) Under NETWORK and INTERNET select set up file sharing
3.) On the task Bar select Set up a connection or network
follow the onscreen instruction to create a network and remember to leave it as public or allow Lan users to view your files..
Jul 09, 2008 | Microsoft Windows Vista Home Premium with...
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
