My iomega hard drive doesnt appear under my computer, it appears in dev. mgr but cannot assign a letter. Windows makes a sound to recognise its there, its says usb recognised and ready to go. just cant find it. tried different cables, different pcs, different op. systems... any help would be appreciated.. : (
  • 32 more comments
  • aaron shane Jan 24, 2013
    ive tried doing this, as windows 7 has no 'run' field i have right clicked my computer - entered device mgr through that. i have found the drive under disk drives - not universal serial bus controllers. there is no yellow exclamation point, the properties says the driver is upto date. - : (
    also it pops up when i 'safely remove hardware'... so my pc knows its there the device mgr knows its there- under disk drives but it doesnt appear in 'my computer' ...??
    i do appreciate all help provided : )
    ggrr now its not appearing in dev. mgr - what ya rekon - throw out?
    excuse the last one - it wasnt plugged in properly
  • Brian Sullivan
    Brian Sullivan Jan 24, 2013
    How are going with this ?
    struggling, still not going. i have been told it may need formatting, but i cant access it at all...
    even under computer management - its not listed...: (
    i have un installed the driver from dev. mgr then re plugged it back in windows has popped up to tell me that SAMSUNG USB DEVICE HM500JI SUCCESSFULLY INSTALLED.. however not appearing in my computer still
  • Brian Sullivan
    you might need to install a usb 3 card USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idlinghttp://blog.premiumusb.com/2010/09/usb-2... these can be purchased on Ebay cheap and easy to install http://www.ebay.com.au/itm/PCI-e-PCI-Exp... for roughly $9 or $10free postage
  • Brian Sullivan
    have a look back in computer management again to see if its ther e you might need to allocate a letter E or F
    this is on laptop as well as desktop - i cant allocate a letter in computer managment as its not appearing in there.. under dev mgr it appears under disk drives - no option to allow me to change the letter..
  • Brian Sullivan
    in device manager there should be something like a small triangle to expand expand right click on it select properties see what options are available
    no options - disk drive properties, says disk drives.. no other options
  • Brian Sullivan
    you might need to install a usb 3 card USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idlinghttp://blog.premiumusb.com/2010/09/usb-2... these can be purchased on Ebay cheap and easy to installhttp://www.ebay.com.au/itm/PCI-e-PCI-Exp... for roughly $9 or $10free postage
    this link has expired and i cannot find what it is im to look for. - plus im using this more on my laptop - didnt know you could add hardware such as usb cards in..
  • Brian Sullivan
    what sort of laptop ? you might need a usb 3 card
    Asus K55V - has usb 3. my desktop has usb 2, and my older laptop also has usb 2
    its just strange it picks up in dev mgr as a disk drive, and windows recognises it when plugged in and unplugged... but it doesnt appear as a drive or anything in 'my computer'
  • Brian Sullivan
    it might not have enough usb power to get to be recognised by your computers how big is the iomega drive ?
    only a 500 gb, i know this is such a big drama - but i myself like a challenge - but cannot tackle this one...i also have a 2 plug usb cable - to give it two port power , this is not working either..
  • Brian Sullivan
    In August 2010, USB 3.0 was released to the public, allowing individuals with the connection the ability to transfer data at speeds far faster than the previous USB 2.0 and even the standard FireWire connection. However, only the latest released computers have USB 3.0 connection ports on the computer. If you want to add these ports onto your current laptop, you must install the ports yourself. Remove the cover on the PC expansion card slot of the laptop, located on the side of the computer. Push the card cover in to unlock it, then slide the card out to expose the connection. Slide the PC USB 3.0 expansion card into the open card slot. Push it in completely until the card locks into place. Insert the driver installation CD into the disc drive of the computer. Wait a moment and the driver installation wizard loads onto the screen. Click "Next," then leave the installation location and name as the current settings. Restart the computer system and the USB 3.0 connection ports become ready for use.http://www.ebay.com.au/itm/170674739679?... Laptophttp://www.ebay.com.au/itm/300666362735?... Desktop also it might be totalledhttp://support.microsoft.com/kb/297694
    my laptop has usb 3... 3 ports at usb 3 speed
  • Brian Sullivan
    how old is iomega and how much work has it done ? has it ever been dropped or abused ?
  • aaron shane Jan 25, 2013
    brought 2/3 years back - i brought it off someone else. - this person said it was working - however they deleted absolutley everything off it. i think maybe the plug n play - or startup software preloaded also deleted.. - from what i can tell it hasnt been dropped at all - no scratches or dents or marks at all... and the drive still spins.. ..
  • Brian Sullivan
    Brian Sullivan Jan 25, 2013
    have you ever had it working ?http://windows.microsoft.com/en-US/windo...
  • aaron shane Jan 27, 2013
    no. however the person i brought it off, used it the day before.
    i have tried manually updating the driver, through dev.mgr and it says the driver is upto date.- when i un-install it via dev mgr, plug it back in - windows pops up and says device is working properly..
  • Brian Sullivan
    Brian Sullivan Jan 27, 2013
    selext the drive in device manager at the top of the page you should see File Action view and help select the view tab from the drop down list view hidden devices
  • aaron shane Jan 28, 2013
    done, still nothing changed.. :( i double clicked on the drive and it brings up the device properties.. under it there is nothing in the 'volumes' tab. This is where it contains the running programmes? and device specifications??
  • Brian Sullivan
    Brian Sullivan Jan 28, 2013
    what is the model no. of this iomega external fard drive ?
  • Brian Sullivan
    Does it have an external case ?
  • aaron shane Jan 29, 2013
    model # LPHD-UPC 500 GB external... small metallic case
  • Brian Sullivan
    Brian Sullivan Jan 29, 2013
    https://iomega-na-en.custhelp.com/app/an...
    Master:
  • 969 Answers
Use DEVICE MANAGEMENT to access your hard drives, each one must be initialized and have a drive letter assigned. If you have trouble reading a drive with a drive letter assigned, change the drive letter.
Posted on Aug 29, 2014
  • 27,725 Answers
Iomega portable hard drives connect to your computer through a USB port. When you connect the Iomega hard drive to your computer, it should pop up as an icon in your My Computer folder. If you can't find the icon in your My Computer folder then you probably need to update the driver for the device. Updating this driver is not very hard and can be done automatically from the Windows Device Manager.
Plug your Iomega hard drive into one of your computer's USB port. Click the "Start" button and go to the "Run" field. Type "Devmgmt.msc" into the Run box and press the "Enter" key. Go down to the bottom of the device manager to the "Universal Serial Bus Controller." Click on the little + (plus) sign to expand it. Look for an entry with a yellow exclamation point and click on it. Click the "Install the software automatically (Recommended)" button and then click the "Next" button. Click the "Finish" button when the installation has finished. Go to the "My Computer" folder from your "Start" menu and locate the Iomega hard drive icon. Double click the icon to gain access to the external hard drive. Hope it helps.
Posted on Jan 23, 2013
5 Suggested Answers
fwadley
  • 482 Answers
SOURCE: Iomega USB 2 Desktop Hard drive not recognised by xp sp2
did you set any jumppers to slave? Is it pluged in the right spot?
Posted on Nov 26, 2007
firesnake09
  • 2923 Answers
SOURCE: Weird clicking sounds
Clicking sound on an external hard drive is an indication that it's quiting to work. You mentioned that it's just stopped working, you may need to check the Disk Management of your computer to see if you could still reformat it. To do this, please follow the steps below:
FOR WINDOWS XP AND VISTA:
1. Make sure that the HD is properly connected to the computer.
2. Right-click 'My Computer' or 'Computer' folder and then go to "Manage".
3. Locate and click Disk Management.
4. Then, take note of the drive letters that will appear on the screen.
5. While the Disk Management window is opened, unplug the HD and check which drive letter will disappear.
6. If a drive letter disappears, then that is your external 250GB HD. You may reformat it to make it work again.
NOTE: Reformatting the HD will erase all the files saved in it. You may want to bring your HD in any data recovery center to retrieve the important files. If the HD didn't show up under your Disk Management, then there's nothing that we could do but to bring your HD in to the Data Recovery to save the files.
FOR MACINTOSH OSX:
1. Connect your HD to the computer.
2. Click 'Go' (located near the Apple icon, Finder, File, Edit and View).
3. Select Utilities and then click the Disk Utility Icon.
4. Take note the drive letters and then unplug the HD.
If a drive letter disappears, that's your HD. If nothing disappears, then the computer no longer detecting the HD.
Posted on Jun 01, 2009
SOURCE: I cannot see my free agent external drive
Thanks for your responses...
I've pretty much decided that it must be a hardware problem within the harddrive itself...Can anyone lead me in the right direction to maybe take out the harddrive to put into another external shell in order to hopefully recover my data? Again I'm using a Seagate Freeagent Desktop 500GB external harddrive.
Posted on Jul 24, 2009
etcrCustomPC
  • 61 Answers
SOURCE: WD Elements USB drive not recognized
Try going to Disk Management and see if they show up there.
  1. Click Start
  2. Right Click My Computer
  3. Click Manage
  4. Click Disk Management
If your computer is recognizing a mass storage device they should show up in disk management and you can just assign them a drive letter.
Posted on Sep 15, 2009
Testimonial: "Brilliant solution. Worked like a charm. Thx."
No assigned letter
Dear Bev,
Disk zero would be your internal drive and you do not want to be messing about with that.
Right click on My Computer
Select manage
Select Disk Management
Identify the (correct) disk
Right click on this disk and select Mark Partition as Active
If already active select the option to assign a drive letter.
If you are saying you have already done this and these options are blanked out then it looks like your hard drive "box" is being recognised but not the drive itself which may be a drive problem. If they supplied a CD, please run it to see if it installs any drivers.
Nov 14, 2013 | Computers & Internet
Not recognised windows vista
You have to go to control panel, adminstrative tools, storage and initialize the drive. However the way it sounds, the drive might have an issue, could be the cable or the usb port
Sep 25, 2012 | Iomega 1TB Desktop USB 2.0 Hard Drive
Iomage macmini 1TB not recognised in disk utilities
Check cable. Try different cable. Try different ports you connect the Iomega with the computer with en on the Iomega itself.
Dec 17, 2011 | Iomega MiniMax Desktop - Hard drive - 500...
It used to worked before... it says that device is working properly but it doesnt appear on the my computer...when i open computer management it says that the drive is unknown,,, uninitialized and...
I'd start by downloading the freeware 'Partition Wizard' and using it to make Windows 'assign' that drive an appropriate 'drive letter'. Sounds like maybe Windows will then suddenly 'recognize' your drive, and that may be all you need to do to get to the data on it. As to why it 'forgot' the drive letter in the first, place...? >>CLICK HERE
Feb 26, 2011 | Western Digital My Passport Essential...
My drive is not being recognised and im not sure why up in till this point it has worked fine? It is a WD Essential Model - Wdbaaf0010hbk - 1TB drive it has alot of valuble information that i would hate to...
when your external drive does not appear in "my computer" or not recognized in windows vista or windows 7, then just right click on my computer, click on manage, the go to disk management. Find your external drive there and right click on it, then select assign new drive letter. Select a letter from the midlle of the alphabet like m, then enter. The icon of your external drive should appear inside my computer
Oct 03, 2010 | Western Digital My Book Essential 1TB...
External drive not recognised by pc, do I need adriver update or is it more serious
Sep 27, 2010 | Western Digital My Book Essential 1TB...
It may not appear like your other drives eg. C: d: etc
it may appear as a removable drive lower down in the list.
Or you may have to add a drive letter
To add a drive letter in XP
Go to control panel, administrative tools, computer management.
Now select disk management, your drive should show in here
right click on it and click change drive letter and paths
now click add at the bottom of this box and just click ok
You should now be able to see it fine
Aug 24, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Western Digital External HDD not appearing in My Computer
It could be that the OS is not assigning a drive letter to your removable drive. To do this, go to disk management and assign one.
Assuming OS is Win 2000/XP/Vista
Right-click My Computer then Manage
Click on Disk Management
Right-click the removable drive and click on Change Drive Letter
Assign a drive letter and click OK
Your drive should now show up on My Computer
Hope this helps.
Jun 20, 2009 | Western Digital Passport 320GB External...
FOR MACINTOSH OSX:
Jun 01, 2009 | Iomega (33215) 250 GB Hard Drive
Drive No Longer Appears as an Available/Accessible Drive
goto disk management - right click and choose assign/change drive letter
Mar 18, 2009 | Electronics - Others
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
