Question about HP Pavilion DV5234US Notebook Laptop
I have HP Pavallion dv5 1106AX Notebook which comes with AMD Turion processor. I want to install Windows XP in this system but it doesn't support earlier versions than Vista. Perhaps there is some BIOS coding. plzz help me out to break that code or any alternative.
  • 180 Answers
You must (1) create your recovery DVD's first before blowing the operating system away - doing this will enable you at a latter stage to reinstall vista latter if xp doesn't work. Go to All Programs >> Recovery Manager >> Create recovery DVD's (2) burn a copy of your software setup folder from your OS. Make a note from device manager the make of specific hardware like wifi manufacture, modem, audio, video, webcam ect. you can sometimes go to the manufactures website to chase drivers. Some of the drivers are backwards compatible with xp.
There is no code for loading xp onto your laptop or changes in bios - there are eprom settings but that is held in confidence with Hp and you can't get them without a special dos based program for you'll **** up the bios no end.
The version of Xp you use must be SATA Supported - it's that simple. Older versions of Xp that is IDE will not detect SATA drives.
Posted on Mar 07, 2009
Rest complete computer from english to arabic language
Windows 7 and Office 2010 have language packs you can install from updates.
If already installed? To change in Windows, go to Start > Search and type Change display language. Choose Arabic from list.
Oct 14, 2012 | HP Pavilion XG885UA DV6-3122US Notebook PC...
HP dv6602au drivres for windosw XP sp2
I have that problem before and best way to identify drivers for XP is to use program called driver genius.
Feb 24, 2010 | Computers & Internet
Amd turion serial ata drivers
Go here:
Download and run the file and it will extract the contents into C:\swsetup\SP33031. Inside there will be an IDE\WinXP folder. Those would be the drivers you'd want to slip into your new disk.
Jul 02, 2009 | AMD Turion 64 X2 TL-56 CPU
Unable to install windows XP on my Notebook
you can't install Windows Xp from witin Windows vista. (not backwards comparable).
restart the computer press F12 when the HP logo comes up. that will bring you into BIOS. select advace>>boot order.
select CD-ROM as first boot. HHD asn second.
exit the BIOS and restart the laptop with CD in the CD drive.
press enter when the system start to install from CD......
and follow the screen (must reformat the HHD).
Jan 27, 2009 | HP Pavilion DV5234US Notebook Laptop
Amd turion x2 rm 70 mobile processor
I will be glad to share my little knowledge in this senario.
Basically, I am personally a fan of AMD processors who is the first to manufacture 64 Bit Processors for Desktops and Notebooks.
However, if you remember, Intel started concentrating on Performance and not on Speed after AMD was able to design processors which were able to outperform Intel processors with slower speeds.
So, you need to look into Performance and not into Speed of the Processor.
Coming to the processor installed in your notebook, it is normal but I recommend you to use Windows XP than using Vista since Vista need more RAM and processing power when compared to XP.
Also, Windows Vista Home Basic is the basic version among the Vista family with very little features.
Coming to the Heating issue, this is common for all Notebooks to heat up when used for long time since the Notebook parts are palced in a very small where if any part heats up, it is passed to other parts too.
Make sure that the Cooling Fan Vents in the Notebook are not filled with Dust.
You can find these vents located at the rear of the notebook from where the hot air should be emiting from inside the Notebook.
I recommend you to use a Vaccume Cleaner or Air Blower to blow away invisible dust which might be blocking the airflow.
Also, make sure that the Notebook is placed on a flat surface like a Table so that there will be air flow from the bottom of the Notebook and the Cooling Fan will be able to **** in the required air from the bottom and dissapate the heat generated by the internal components.
Also, check for any BIOS Update is available for your Notebook related to this issue and update with the same.
You need to contact HP Chat Support and get the exact BIOS Update for your notebook since updating the BIOS with incorrect Update will make the Notebook useless.
Hope this gives some idea about your doubts.....
Nov 02, 2008 | HP Pavilion DV5234US Notebook Laptop
Amd turion x2 rm70 vs intel core 2 duo t5750!!!!
I read this and don't believe you - yes the AMD dual core gets hot - yes AMD processor are HOT processors - is intel better - no there on par with AMD - the thu put rate is so close it doesn't matter - now vista basic is just that BASIC - if you want to bump it up - home premium 32 or 64 but ultimate 64 should get it going.
Oct 30, 2008 | HP Pavilion DV5234US Notebook Laptop
AMD Turion vs Intel Pentium processor
No there are no issues with Vista and the processor of the computer.
Jun 22, 2008 | Computers & Internet
System specifications
Here's the HP Support link for your laptop.
Apr 23, 2008 | Computers & Internet
Windows XP drivers for Compaq Presario v3424au notebook
bhenjot jab malum na ho gadhe to mat post kiya kar comment
chuttia samajta hain hamko
Aug 18, 2007 | Microsoft Windows XP Professional With...
HP Pavilion DV5234US Notebook Laptop Logo
256 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
