Question about Black & Decker SpaceMaker ODC325 Coffee Maker
Odc 325 Under the Countor
How do I release the support guids. I cannot see the side of the supports it is in a motorhome
I have one in my motorhome and there are two screws you have to take out. They put two black metal plates in to hold the unit from sliding out. I only found out yesterday as I was trying to get it out to see the model number. Just look up in behind it and you'll see the two screws holding it in place. Those brackets are affixed to the back of the coffee maker. Once you take the screws out now the coffee maker comes out of the guides freely.
Joanne
Posted on Jul 30, 2009
Actually, you just need to push up on the bottom to get the unit to go over the tabs on top of the brackets. Push up and the unit will slide forward. I just did this to mine (it quit working after 5 years-was a refurbed unit and I will try to fix it) and have it out. Suggest you remove the carafe first and be sure you unplug from the outlet.
Posted on Jul 13, 2009
  • 29 Answers
Grasp the coffeee maker assemby firmly and pull it froward (away from the wall). The The unit willl slide slightly forward in the hanging brackets leaving about 1/4 in of space exposed between the front of the hanging bracket and the main assembly. Insert a kitchen knife of flat-bladed screwdriver into that narrow space until you are pushing the plastic hanging bracket catch inwards, holding it there. If you are working alone, alternate this maneuver on the right and left sides while maintaining forward pulling pressure on the main assembly . It will eventually slide forward and out of the hanging brackets. It will be far easier and faster if you have a helper to help you push in both hanger bracket clips at the same time while keeping forward pulling pressure on the coffee maker. , because no one has three hands. Done this many times
Posted on Feb 16, 2009
Ajanta ODC-150 clock time change
The Ajanta Quartz ODC-150 clock has buttons at the side which allow the owner to the owner to set the time. Pressing these buttons in the correct configuration will enable this. Hope this help.
Nov 06, 2017 | Audio Players & Recorders
How do i reset maintenance require light on a 2002 honda civic
Take it to a mechanic and ask them to reset the ODC, or purchase an ODC reader that has reset capabilities.
Apr 21, 2015 | 2002 Honda Civic
I have a spacemaker that leeks at resover
Used/Cannibaliized Replacement parts for ODC 325 B&D Spacemaker Coffee Makers are regularly sold on eBay, including the entire water reservoir or even the water valve in bottom of the reservoir (the leaky old one can be pushed out from the inside of the reservoir, and a non-leaking used replacement valve can be pressed in in its place).I sometimes buy an old broken ODC 325 cheaply on eBay as a source of parts.
Dec 30, 2013 | Black & Decker SpaceMaker ODC325 Coffee...
I need bracket
There's one on sale on eBay right now. Just search eBay under ODC 325.
Dec 23, 2013 | Black & Decker SpaceMaker ODC325 Coffee...
How to adjust the correct time of ajanta quartz ODC-120
move the plastic button at the back slightly to the right side where it says "Time" and than adjust the time by pressing 'Mode' and 'Up/Countdown' buttons
Oct 14, 2013 | Watches
I have a Black and Decker ODC 460--it has been recalled BUT they want the data on the back of the unit. It is suspended from a cabinet and though they suggest it can be removed from the mounting kit...
The Use and Care Manual for your product can be found here:
http://useandcaremanuals.com/pdf/ODC460973.pdf
REMOVING THE UNIT
1. To remove unit from mounting bracket (for service or cleaning), first remove the thermal carafe. Slide your hand under the unit for support. Slide unit forward on its track guides to remove.
2. To replace the unit, slide it onto mounting bracket and all the way back until it locks into place.
Your right that they do not provide any specific instruction on whether there is a lock to release. I suspect you need to lift the unit up in the tracks before you pull forward.
Apr 25, 2011 | Black & Decker ODC460 Coffee Maker
I have one 325.SE with no instructtions as to how to program and what the control are for and the location.
You can click on the link you need for information about your TomTom 325 SE:
(The manual indicates XL - but it is for the 325 SE as well.)
TomTom XL 330/325 Reference Guide
TomTom XL 330/325 Installation Poster
RDS-TMC Traffic Receiver Reference Guide
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Feb 07, 2010 | GPS
Change blower motor in a 1996 ford countor
once you remove the glove box 3 lil screws under it . you will be able to access the blower motor . 3 or four screws on it . and its out
Oct 18, 2009 | 1996 Ford Contour
Water resevoir leaking
Replacement ODC 325 water reservoirs no longer for sale.
I keep a second ODC 325 machine for canibalization. The black rubber water valve assambly can be repaired (I did it 2 weeks ago) but it takes some creativity.
Nov 10, 2008 | Black & Decker SpaceMaker ODC325 Coffee...
Black & Decker SpaceMaker ODC325 Coffee Maker Logo
148 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
Henry  Thomas
Henry Thomas
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
