MA-516 TEC motherboard
The motherboard is Out of order can you tell me how to fix it the display always shows four vertical half bars
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 153 Answers
Do you have onboard video or an add in AGP / PCIe video card
Posted on Jan 25, 2013
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
What is the firing order for 2007 suzuki forenza sedan 2.0 litre
Redux (firing order is 1,3,4,2 but forget that)
it's not a Suzuki J20a
nor a suzuki J20b
so what is it? , it's the GM D-tec 2.0L
its not suzuki engine, (first fact) if in USA.
see photo.
it can only be wired 2 ways, guessing
1423
or
2314
the only question is which end is #1
sorry i dont know. (no FSM for it )
if you cross 1 and 4 it will run , due to wasted spark
same with 2 and 3.
the ECU fires them not 1,3,4,2
it fires the 1 then 4, repeat see?
firing coil one fires 4 too. they are wired in series. see?
when i find #1 lug, ill post it to all d-tec pages. here.
Jul 18, 2014 | Suzuki Forenza Cars & Trucks
Verticall bar on the screen
A vertical bar is frequently a sign that the matrix decoder has failed.
The usual solution is to replace the display panel itself. Dependent upon the model, sometimes this may not be economically viable.
There is also a possibility that the connexion between the display panel and the motherboard may have come loose. Try removing the connexion and replacing it before you replace the display panel.
Dec 10, 2013 | Samsung Televison & Video
Vga port not working donot show display
Make shore when you place this item in the refuse that you stomp on in or at least snap it in half, so that it doesn't bother the next budding Tec Dude. (phased diode/resister next to port)
Try adding a PCI card
Sep 17, 2013 | Computers & Internet
Display shows only half screen. Other half is ok. The bad side is just vertical bars top-to-bottom. Thanks, Jim
This indicates a bad LCD screen, Hook a external monitor to the video output on the back of the laptop, If okay! the display on the computer is bad and will need to be replaced, "costly" Now! if both screens show the same problem, it is the Video Graphics Card that is apart of the motherboard that is the issue, It will need a computer technician to address this.
Jan 16, 2011 | Toshiba Satellite P35-S609 Notebook
Half display on plasma
How close is hi power stereo speakers or anything with magnetic
Apr 21, 2017 | Philips Televison & Video
Dark Grey Vertical Bar
1. try connecting laptop to an external monitor and check if this vertical dark gray bar appears. if yes it means video is the problem. you need to boot in safe mode then uninstall the video driver. boot to notmal mode then download and install the latest video driver. if still same problem then replace video card. if video is built in with motherboard you need to replace motherboard.
2. when the vertical dark gray bar did not appear in the external monitor then it means issue is with the LCD panel. Do this turn off laptop. press and hold D key then press Power button at the same time or Press and hold on the Fn key then Power button check if the test will run. Color displays full screen when you keep pressing on N key when the colors appears check the vertical dark gray bar if still exist in the test, this means LCD panel and LCD cable needs to be replaced.
Oct 31, 2008 | Computers & Internet
Acer 2410 display having 3inches wide black vertical line at the right end
Hi...there,
The problems.. your panel are damaged. Don't bother to replaced...will cost you a lots of $$$.... It's time for retired...
Oct 14, 2008 | Acer Refurbished 11 3 STN LCD DISPLAY **...
Computers & Internet Logo
David Payne
David Payne
