Question about Whirlpool Duet 3.8 cu. ft. Front Load Washer
On a WFW8410SW00 locks door and that is it will not work
2002 Cadi Deville, can't get any locks to operate with remote or dash push buttons, the remote operates everthing but the locks! When the remote door lock is pressed, lites flash,horn blows locks not.
Power Door Lock Operation
The vehicle is equipped with power door locks. Each lock actuator is powered and controlled by the door module mounted in the individual door, but the rear integration module (RIM), which is the master control for the door lock system, determines when the lock functions are permitted. The RIM receives and examines the requested lock function from the individual door modules, or from the remote function actuator (RFA) via the class 2 serial data circuit. The RIM also examines the transmission shift selector position and the ignition switch position information available over the Class 2 serial data circuits. If the RIM determines that a lock or unlock function is permitted, it sends a class 2 message back to the individual door modules commanding them to perform that Lock or Unlock function.
Power Door Lock Components
The power door lock system consists of the following components:
Driver door lock switch
Passenger front door lock switch
LH rear door lock switch
RH rear door lock switch
LH middle door lock switch (w/ V4U)
RH middle door lock switch (w/ V4U)
Driver door switch assembly (DDSA)
Driver door module (DDM)
Passenger front door module (PDM)
LH rear door module (LRDM)
RH rear door module (RRDM)
Left middle door module (LMDM) (w/ V4U)
Right middle door module (RMDM) (w/ V4U)
Driver door lock actuator
Passenger front door lock actuator
LH rear door lock actuator
RH rear door lock actuator
LH middle door lock actuator (w/V4U)
RH middle door lock actuator (w/ V4U)
Driver door cylinder unlock switch
Rear integration module (RIM)
DRVMDL fuse (10-amp)
PASS MDL fuse (10-amp)
RRDR MDL fuse (10-amp)
Class 2 serial data link
Sep 27, 2016 | 2002 Cadillac Deville
Automatic door locks delaying in locking.
It can be issue with keyfob or door locking mechanism.
Check the help link mentioned below:---
How to test Power door locks?
http://repairhelpcenter.blogspot.in/2012/02/how-to-test-power-door-locks.html
2006 Toyota Camry: Power Door Locks Not Working?
http://whatisbyme.blogspot.in/2012/05/2006-toyota-camry-power-door-locks-not.html
Door locks or windows not working on car?
http://schematicsdiagram.blogspot.com/2011/07/door-locks-or-windows-not-working-on.html
All power door locks not working on Honda Accord?
http://howtobyme.blogspot.com/2011/11/all-power-door-locks-not-working-on_14.html
Repairing car Door lock Actuator?
http://howtobyme.blogspot.com/2011/11/repairing-car-door-lock-actuator.html
How to Access car door panel?
http://howtobyme.blogspot.com/2011/11/how-to-access-car-door-panel.html
Vehicle door panel components?
http://howtobyme.blogspot.com/2011/11/vehicle-door-panel-components.html
Power door locks not working?
http://schematicsdiagram.blogspot.com/2011/12/power-door-locks-not-working.html
Door locks not working on Ford Explorer?
http://technoanswers.blogspot.com/2012/01/door-locks-not-working-on-ford-explorer.html
These details will help.
Thanks.
Dec 06, 2012 | 1995 Chevrolet G20
Power locks not locking on dodge stratus
For Doors not getting open with remote or key problem, there are help links provided below. Click the link below to go through its procedure and troubleshoot the problem: ----
Drivers side front door will not open from inside or outside?
http://technoanswers.blogspot.com/2012/01/ford-f-350-crew-cab-drivers-side-front.html
Car door will not close?
http://howtobyme.blogspot.com/2011/11/car-door-will-not-close.html
All power door locks not working?
Truck Door will not close?
http://schematicsdiagram.blogspot.com/2011/12/ford-truck-door-will-not-close.html
Where is Cars Door control Module located?
http://schematicsdiagram.blogspot.com/2011/12/where-is-cars-door-control-module.html
Door ajar light stays on?
http://technoanswers.blogspot.com/2012/01/door-ajar-light-stays-on.html
Door locks not working?
Front Door dis-assembly diagram?
http://repairhelpcenter.blogspot.in/2012/02/front-door-dis-assembly-diagram-for.html
Rear Door dis-assembly diagram?
http://repairhelpcenter.blogspot.in/2012/02/rear-door-dis-assembly-diagram-for.html
Doors will not open with Remote?
http://schematicsdiagram.blogspot.in/2012/02/lexus-doors-will-not-open-with-remote.html
How to replace Door Hatch ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-hatch-on-acura-integra.html
How to remove Doors?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-doors-on-acura-integra.html
How to Replace Doors?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-doors-on-audi-a4-and-vw.html
Remote will not unlock Rear door?
http://schematicsdiagram.blogspot.com/2011/12/remote-will-not-unlock-rear-door-on-gmc.html
Central locking not working ?
http://schematicsdiagram.blogspot.in/2012/03/this-is-how-system-operates.html
This will help.
Thanks.
Feb 21, 2012 | 2001 Dodge Stratus
Power door locks won't lock
Central locking not working?
This will help.
Thanks.
Feb 07, 2012 | 1993 Pontiac Grand Am
Remote Starter not working
This will help.
Thanks.
Feb 05, 2012 | 2006 Chevrolet HHR
1999 Ford Windstar power door locks only work when key is turned on
For Doors not getting open with remote or key problem,there are help links provided below.Click the link below to go through its procedure and troubleshoot the problem:----
drivers side front door will not open from inside or outside?
All power door locks not working ?
This will help.
Thanks.
Feb 03, 2012 | 1999 Ford Windstar
1994 honda accord power door lock doesn't work
This will help.
Thanks.
Feb 02, 2012 | 1994 Honda Accord
Central Locking
When you use your remote or insert your key in the Drivers Front door all the door locks should work at the same time by the door lock motors electrically. If you have to manually unlock the door because it will not lock or unlock by the lock motor, you need a door lock motor. The drivers and passengers front door can unlocked with the key manually. The rear doors you have to pull up the latch. If no doors unlock electrically with the remote or drivers door lock, intermittantly or all the time, you will need a Central Locking Electronic Control Module. You will hear the "beep" but no door locks will fire at all. If you have odd door locks not working intermittantly you need a new door lock motor for each door lock that malfunctions. You can hear of the door locks are working electrically. Yes, they are common problem. If you can hear the door lock working but the door still doesn't unlock you need to take the door panel off and lubricate the door latch assembly and work the lock, loosening it up. This is common as well.
May 30, 2009 | 1996 Saab 900
Doors wont all lock at the same time on my '95 saab 9000cs. i have to manually lock them individually. My dashboard lights flicker, sometimes the lights will stay on and sometimes i have to tap the switch...
When you use your remote or insert your key in the Drivers Front door all the door locks should work at the same time by the door lock motors electrically. If you have to manually unlock the door because it will not lock or unlock by the lock motor, you need a door lock motor. The drivers and passengers front doors can unlocked with the key manually only. The rear doors you have to pull up the latch.
If NONE of doors unlock electrically with the remote or drivers door lock, intermittently or all the time, you will need a Central Locking Electronic Control Module. Pressing the remote button you will hear the "beep", but no door locks will fire at all.
If you have a few odd door locks not working intermittently or not at all, you will need a new door lock motor for each door lock that malfunctions. You can hear if the door locks are working electrically. Yes, they are common problem.
If you can hear the door lock motor working but the door still doesn't unlock you need to take the door panel off and lubricate the door latch assembly and work the lock, loosening it up. This is common as well.
Sometimes a bad door lock motor can blow the central locking fuse. You will notice it because it will take a second or two longer to lock and unlock compared to the others. If the door lock motors seem fine, install a the next step up in amperage fuse. (From 15 AMP to a 20 AMP)
Apr 09, 2009 | 1997 Saab 9000
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
