Question about Kyocera FS-C5150DN Color Laser Printer
Kyocera Fs c5150 - call service???
Error code 7402-0001981 on kyocera fs c5150dn is showing on my printer could someone tell me what is causing this please?
SOURCE: WE HAVE A KYOCERA FS-1900
You may have a problem here. The early Kyocera printer had a problem with the developer unit. You can try and clean the developer unit but be careful. First you will need a can of air. The kind you use to dust off your keyboard and such. Then you should have a oil-less dust towel like a Stretch and Dust. First LIGHTLY dust the excess toner off the developer unit. I MEAN LIGHTLY. If you spray the air full blast in to the developer unit you will not only make a huge mess but you may also roll back a mylar in the unit making it worthless. Just lightly pull back the trigger on the canned air until you get a slight amount of air flow. Just enough to blow away the top layer of toner. Then using the stretch and dust wipe off the rest of the toner it should be in the same shape as the tracks on your document. Do Not Touch the metal roller with your hands, the oils on your fingers are enough to make the problem worse. Be careful if you roll the developing unit, make sure you are not pulling the toner out of the unit. If you are you are rolling it the wrong way. Some will only go one way. If after you clean the entire roller and the problem comes back, try cleaning it again. If it still persists then you may need a new developer unit and possibly a drum unit. Get in touch with your nearest Kyocera dealer for part pricing.
Posted on May 29, 2008
leroyal
  • 2120 Answers
SOURCE: Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
Posted on Jan 23, 2009
FixinFax
  • 3085 Answers
SOURCE: Kyocera KM-3050 - Faxing error code
Try calling that number from a regular phone and listen for fax tones...it may not be a fax number.
Posted on Oct 16, 2009
  • 241 Answers
SOURCE: I have a kyocera FS-2000D with error code: Call fo...
Error code 0150 is an engine EEPROM communication error. The engine board might need to be replaced. I have heard that sometimes a defective developer unit could cause this same error code. I would try swaping a develper from a working FS-2000D first.
Posted on Jun 09, 2010
  • 525 Answers
SOURCE: kyocera FS-1016MFP "printer error service
Code: 6000
Contents: Broken heater lamp error
The temperature won't rise by 1°C/33.8
°F during warming up and the heater is
turned on for 5 seconds.
°F during printing and the heater is
turned on for 5 seconds with the duty
cycle more than 60%.
Causes:
- Defective fuser thermistor.
- Broken thermal cutout or heater lamp.
- Defective engine/high voltage PWB.
Posted on Feb 21, 2011
Kyocera FS-C5150DN call service 7403:0004749
this error is about the Magenta developing unit.
Please check the connection between the ptinter and the developing unit. Restart the printer after that.
If the error will not go away after that you will have to replace the Magenta developing unit.
If the error still will not go away you will have to replace the engine power board.
Best regards,
Marius
Oct 11, 2016 | Kyocera FS-C5150DN Duplex Network Colour...
ERROR POWER OFF KYOCERA FS-C5150DN
What is exactly the message been displayed in FS-C5150DN?
Jun 09, 2014 | Kyocera FS-1030DN Printers
HOW TO RESET A KYOCERA FS-C5150DN
you can open the command center of the printer, login using the password admin00. Then go to tab "Basic", click Reset and choose the last one, which says Reset Entire Device To Factory Defaults.
If you just want to reset the frpo parameters to factory defaults, then use the command !R! FRPO INIT; EXIT;
I have a kyocera fs-c5150dn and it keeps saying check the toner container what does that mean
check the waste toner bottler or the other toners reset in machine then reboot
May 01, 2014 | Kyocera FSC5150DN Laser Printer
Kyocera 1020 error codes list
Hi Pandirayaj,
I have this manual for you to see errors in Kyocera FS-1020D. Hope it helps.
Kyocera FS FS 1020D Operation Manual Page 37 Error Messages
Apr 25, 2014 | Kyocera Mita FS-1020D Laser Printer
I have a fs c2126 kyocera printer it gives me c4600 error code
Good afternoon,
Please can someone tell me what is the error C4600 printer kyocera TASKalfa 2551ci?
How can I solve it?
Jul 20, 2011 | Kyocera FS-1118MFP Laser Printer
Kyocera FS-1016MFP "printer error service
Code: 6000
Causes:
Feb 02, 2011 | Kyocera FS-1016 Printer
Kyocera fs 1016 mpf printer error service call 6400
Code: 6400
Zero cross signal error
While fuser heater ON/OFF control is
performed, the zero-cross signal is not
input within 3 s.
Causes:
- Defective the power source PWB
- Defective the engine/high voltage PWB.
Dec 15, 2010 | Kyocera FS-1016 Printer
I have a kyocera FS-2000D with error code: Call for service 0150:0000049. Help...thanks in advance
May 20, 2010 | Kyocera FS-2000D Laser Printer
Kyocera FS-C5150DN Color Laser Printer Logo
671 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
