Question about Radio Shack Accurian ADR-3223
When recording from the tv to hard drive only get picture and no sound
I figured out how to record from the tv to hard drive but only get a picture and no sound can you help me out what I may have hooked up incorrectly to get the sound. thanks
  • 1 more comment
  • Robert Gilliard Jan 24, 2013
    When recording from the tv to the accurian only get a picture, and no sound please provide insturctions on how to resolve this issue.
  • Robert Gilliard Jan 25, 2013
    To more fully understand the installation of the Accurian HDD/DVD recorder perhaps the following will help. The recorder and TV are hooked up to xfinity HD receiver. I also have an S video cable hooked up b etween the Accurian recorder and the Xfinity box thinkin that I should be able to receive the signal directly through the box. Still I receive video recording but no sound. I have recorded movies from cable previously but this was performed off an old TV and regular cable. My problem started after buying a new HD TV and upgrading to a an HD cable box. The movies recorded from the old set up can be played back and have sound. Any additional thoughts.
    Additionally, I can play pre-recorded DVD's with out problems. So, obviously the machine is capable of providing sound.
Can you record from a smart tv with arecording box
First of all you need to check if your TV supports recording. Some 2010 models do and most 2011 have it implemented. Look for stickers or logos such as:
  • USB Recording
  • PVR (Personal Video Recorder)
  • DVR (Digital Video Recorder
  • The following manufacturers support it in some of their models. Typically mid-end to high-end models. Check the manufacturer web site if you are unsure.
  • Samsung
  • Sony
  • LG
  • Philips
  • Panasonic
  • Toshiba
  • Sharp (only Time Shift pausing)
  • Grundig
    What you need
    Many consumers have USB recording enabled TVs without actually using the function - simply because it requires an extra USB hard drive ou need the following:
    1. USB Recording: A HDTV that supports recording.
    2. A USB HDD: FlatpanelsHD uses a USB HDD from Transcend.
    3. Digital channels: Recording is only enabled on digital channels - not analog. You can record SD, HD and 3D.
    Some manufacturers recommend USB hard drives with external power supplies but we have used a Trandscend USB HDD that takes power from the USB plug on all manufacturers' TVs without any problems. Manufacturers typically allow 1:1 recording, meaning that you will see no loss in picture quality.
    How to set up USB Recording
    Once you have purchased a USB hard drive and connected it on the back of the TV you can move on to "pairing" the USB HDD with the TV. Here is how to set up USB recording.
  • Connect the USB HDD to a free USB port on the back of the TV.
  • The USB hard drive now needs to be formatted (all data will be deleted).
  • Most TVs help you to format the USB HDD automatically but on some models you need to enter the menu and select format HDD (or something similar)
  • Sep 29, 2016 | Televison & Video
    My LG DVB-T HDD/DVD Recorder will not play or record sound via TV Channels!
    If the TV source is separate from the recorder, there has to be a physical connection between the two. From your description it seems there is a video connection, but what about audio?
    Dec 03, 2013 | Televison & Video
    As a beginner, i would like to connect seagate external drive to tv and use as a recorder
    You can't connect a hard drive to a tv and record to it even if you have a usb port on the tv. The tv will read from the usb port pictures and music but it will not record to it. The tv does not have any software built into it that will let you use the usb port as a personal video recorder. It won't work.
    Jul 16, 2011 | Televison & Video
    Picture playback
    Your hard drive needs to be reformatted.. its a long process
    Mar 15, 2009 | Philips DIRECTV R15
    No picture when I play back on vcr
    Are you using AV connections(Red, Yellow, White) cable connections? If so The video connection may have come loose.
    Feb 10, 2009 | GoVideo Go Video DVD/VCR Combo
    Direct TV DVR sound/no picture or pict. no sound
    My Direct TV has no sound or picture but does show channel info at the top. Any help is appreciated.
    Dec 13, 2008 | Directv (R10) DTV Receiver / 70-Hours...
    Direct TV DVR "skipping" like a dvd
    You have an internal hard drive error. You will need a new box.
    Jan 22, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
    Recording from my vcr to the dvd hardrive
    It may be that the tape you are trying to record from is copy-protected. You will then get a "scrambled" picture
    Nov 04, 2007 | Wharfedale DVD-M3 DVD Player
    Radio Shack Accurian ADR-3223 Logo
    20 people viewed this question
    Top Radio Shack Televison & Video Experts
    Computer Repairing
    Computer Repairing
    xxxxxx xxx
    Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
