Question about Garden
What cause your fs38 to shut off by itself running on full trottle
Strart fine but when sqeezing trigger shut off
    Sergeant:
  • 322 Answers
That is usually a fuel delivery problem. Check the carburetor diaphragm to see if it is stiff and check the fuel lines.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Posted on Jan 23, 2013
REPLACE TRIGGER IN STIHL FS 38
Heres the illustrated parts diagram showing the beakdown on the handle and location of the trigger mechanism. If you want the full parts manual, i can send it to you. :)
Apr 20, 2013 | Stihl Garden
Trottle cuts out on 09 ultra classic hd
Have you pulled any error codes?
If so, what are they?
I have a troubleshooting flow chart for a 08 Road King, it might be close enough for ya.
From your description, it's going into "limp" mode, so it can limp home.
Pull any error codes and repost them.
Mar 31, 2013 | 2009 Harley Davidson FLHTCU Ultra Classic...
There's probably a sensor in your throttle housing that regulates the amount of fuel that goes through the throttle body to the engine. The sensor could be located on the throttle or you may have a bad throttle body. There are computers on both ends. I believe you ought to call the dealer and find out
Engine starts fine, runs fine for about 5-10 minutes of various speeds. Then it shuts down suddenly regardless what trottle possision. Engine will start right away again, but promblem will accure after few...
Could be so many things, I know on modern Harleys there is a shut off relay that turns off the engine if the bike is on its side. If that switch goes out, the motor won't run. Probably have to take it to the dealer.
Jul 08, 2011 | Honda Fusion Motorcycles
I have gas in my oil and it wont trottle,idles fine but back fires when u try to trottle up(threw carb).
it sound like the needle and seat might be slowly leaking by causing it too flood down the carb and in too the oil if your oil is not over full and just has some gas in it your exhaust lobe may be worn on the camshaft causing the backfire you try too throttle it
Dec 29, 2010 | Polaris ATV
Put a goodrige hose on front brake but cant get it to bleed.yamaha xvs 650 brakes were fine before i put the hose on.
I had same problem, i ended up reverse bleeding it with airline at work. Regulated pressure down to about 5 psi, then attached hose prefilled with brake fluid between bleed nipple and airline trigger and gently sqeezed trigger till fluid came out in resevoir.Helps that i work in a hose distributor and have all the hose and fitting to hand mind. hope this helps
Mar 03, 2010 | 1997 Yamaha XVS 650 Dragstar
Need to replace line on FS38 Line Trimmer. No instuction manual. It must be an easy procedure. What diameter line and how is it done?
I googled your fs38. It is a Stihl FS38. The first sight on the search comes up with an 82 page operating manual from stihl.ca
This should help.
Good Day.
Oct 25, 2009 | Garden
Lid Switch Trigger Broken: How To Fix this?
There is no fix for the lever. Go to www.repairclinic.com and order you a new one. They are cheap and relatively easy to replace.
Mar 14, 2009 | Kenmore 22422 Top Load Washer
Fuel pump keep going out in my 2002 isuzu rodeo
check the relay, it could be stuck in the closed position causing the pump to run 100% of the time the key is on. it should shut off when the fuel pressure is at operating range. like a well pump on a house, it needs to start and stop with the pressure difference. if it runs continuously it will burn up fast.
Dec 04, 2008 | 2002 Isuzu Rodeo
My dishwasher shuts itself off
The lights will typically blink when the door comes open. It may be that when the washer warms up, parts of it expands and allows the door to open slightly. It may also be that the trigger that registers the door being shut is not being tripped.
Aug 03, 2007 | Frigidaire 18 in. FDR252RB Built-in...
Garden Logo
80 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
