Question about GE A730 Digital Camera
How to replaced a broken LCD Screen in GE A730 DIGITAL CAMERA, if
Is fixable, thanks or where is a place they cant fix thanks
  • Helena Stephan May 11, 2010
    Hi, I dropped my replacement camera! Now everytime I turn it on; there is only a white screen with a dark ink spot on it... What can I do?
5 Suggested Answers
SOURCE: WHERE DO I GET DRIVERS FROM
WHERE DO IGET DRIVERS FOR GE A730 DIGITAL CAMERS .I LOST DRIVERS DISK
Posted on Jun 29, 2008
dlundmark
  • 797 Answers
SOURCE: GE A730 LENS ERROR
Hi sadloserx:
I am inserting this from a previous post, since this seems to be the same problem.
Also lens problems have to be described in full to see what is wrong. The following will give you some idea as to what I am saying.
This camera is telling you that there is a problem with the lens, either in the tracking, mechanical, or electrical circuit.
Try this: If the lens extends at all... then pull on the lens or push in to try to reset the tracking of the lens.
If the lens does not extend at all and makes noise, then it has problems in the lens gearing or motor.
If the lens makes no noise at all and you get the error with the shut down, then more than likely there is nothing that can be done.
Try this at your own risk:
With the camera off, gently hit the camera on a padded (folded towel) cloth on a solid surface, using one of the corners. This may jar the internal parts enough to make the camera work again.
BY doing this, you do risk damaging the camera beyond repair, however, if you have a camera not working anyway, it may be worth it.
I have fixed two cameras in the past this way. However, nothing is guaranteed.
Finally:
Find a repair shop and have it fixed. (These kinds of repairs can cost $150.00 or more). That will depend on your value and the age as well of the camera.
Sell it as is or for parts on a site such as Ebay.
Posted on Sep 27, 2008
  • 8 Answers
SOURCE: i need software download for ge camera a730 lost
Go to the manufacturers web site. Most manufacturers provide a download file for the cameras that they sell. This would be the first place that I would look.
Posted on Feb 19, 2009
SOURCE: when taking pictures with GE A730 digital camera,
i have problems with lines in my pictures how can i fix this my e-mail is sexyjo68@hotmail.com please help me
Posted on Apr 08, 2010
  • 98816 Answers
SOURCE: How do I download my pictures from my camera to my
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
Posted on May 17, 2010
I have a GE A730 and when i turned it on the LCD was black-out but it can take pictures. What is the problem, incase can i trobleshoot it by my self? how? thanks
It sounds like the connection to the LCD has been interrupted. If the camera still has warranty, it should be fixable. If the warranty has lapsed, it won't be cost effective to get it fixed, given the price of the camera.
Mar 01, 2011 | GE A730 Digital Camera
GE A730 lines across the screen in lit areas?
shutter unit of the lens is bad,so replace the broken,take it to camera tec.
Mar 08, 2010 | GE A730 Digital Camera
MY SCREEN \BROKE ON THE INSIDE OF MY DIGITAL
Unfortunately repairing a damaged LCD screen is not possible. Your best option is to purchase a new LCD screen for that model and see about having it installed or installing it yourself.
Jan 19, 2010 | GE A730 Digital Camera
Camera lens won't open, and when I turn the camera on the screen says "Lens Error"
Lens is probably just stuck, because of debris or misaligned gears. The lens can many times be repaired without having to replace it. It's probably misaligned gears inside. Try to return to manufacturer. If you're out off warranty, there are third party place that fix them such as camera lens repair. There are also free camera repair guide website that show you how to replace the lens, the part is usually available on ebay.
Oct 17, 2009 | GE A730 Digital Camera
Lost cable
Contact GE at this # 800.730.6597 and tell them you need a new usb cable to hook to computer
Dec 16, 2008 | GE A730 Digital Camera
My GE Digital Camera isn't working correctly
It sounds defective. Call 800 730 6597
Trevor Gordon
Senior Customer Tech
General Imaging Company
(Exclusive GE Digital Camera Licensee)
Jul 13, 2008 | GE A730 Digital Camera
Lcd picture
The LCD is cracked. Call 800 730 6597 and we will replace it for 35 bucks.
Trevor Gordon
Jul 04, 2008 | GE A730 Digital Camera
General Imaging
Call 800 730 6597 to have it replaced.
Trevor Gordon
Jun 01, 2008 | GE A730 Digital Camera
Ge A730 lines through pics
It is defective. Call 800 730 6597
Trevor Gordon
May 31, 2008 | GE A730 Digital Camera
LCD screen
i have the same problem, whith 2 cameras
Mar 23, 2008 | GE A730 Digital Camera
GE A730 Digital Camera Logo
37 people viewed this question
Top GE Cameras Experts
sonic boom...
sonic boom...
Are you a GE Camera Expert? Answer questions, earn points and help others
