Question about Sony Vaio Laptop Pcg-7z1l
Need a new adaptor
My power adapter gave out and i can't find one anywhere!!
  • Sony Master
  • 32,281 Answers
Google the Internet for a power adapter for your model Sony laptop.
Make sure the the new adapter is the same voltage and amp as the old adapter. This information is printed on the adapter.
Posted on Jan 23, 2013
My hp pavilion dv6-2117ax laptop won't power up (no power light on where adaptor meets laptop). Replaced power adaptor / charger and laptop powered up and operated for a day and then next day woul
The laptop probably isn't charging. Could be a bad d/c connector on the laptop or the battery is bad. Remove the battery and plug in the a/c adapter and see if it powers on. Wiggle the a/c plug in gently while pressing the power button on the laptop. It powers on and off briefly then I'd say it's the d/c jack on the laptop, bad sodder joint.
Dec 04, 2012 | Computers & Internet
Which AC adaptor to use with New Balance Elliptical 9.0e
if u have a lot of ac adaptor then find thesame voltage output to ur gadget..if you don't have the exact voltage dc output for ur gadget better buy one....what is your machine need? ac power or dc power? if your machine is electronicaly operated so u need is dc power...but if your machine is like a motor so u need is ac power....tnx
Jun 19, 2012 | Computers & Internet
Hello I have a JBL on stage 2 that I bought in the
Congratulations. You are among the first to approach us after having done a lot of the research up front instead of considering us a proxy Search Engine secretary.
I'm going with OS200ID as the unit's model number.
The DC input and physical fit are the only considerations for the dock's power - 12V/1.25A.
Item 190555626796 IS indeed a universal voltage (100-240 vac) sourced supply. The seller, DIGIDAVE, http://www.digidave.co.uk/help invites queries, too.
I'd say this is exactly what you need to use the the OS anywhere on the planet with a plug adapter.
Jul 18, 2011 | JBL On Stage Speaker Dock for Apple iPod...
Lenovo laptop(8932) will go into a sleep like mode (you can still see the screen, very dim) when plugged into ac adaptor. Doesn't do it with battery power. Changed system board, power adaptor - no...
Good Day Psmith!
It looks like the AC adaptor is not making the right supply voltage needed for your laptop.
If you have a multi tester, you can test your ac adaptor to see if it has stable 20V voltage output supply needed for the laptop to make it work.
Set your tester to DC range. Plug the ac adaptor to your wall socket. Hold the other end of the ac adaptor (the one you connect to your laptop. Insert the red (positive) lead into the center of the adapter pin, then touch the black (negative) lead to the outside metal part of the pin.
Read the display in your tester. If the adapter is working properly, the meter should read between 19 to 20 volts of the rating. If the adapter is faulty, the meter will read below 18volts.
If that would be the case, I'm afraid you will need to replace your ac adaptor.
You can purchase online a replacement ac adaptor for lenovo 8932.
1. From this site, it costs $34.99 + $8 https://www.ebuybatteries.com/product/models/2_IBM-Lenovo-AC090W008T15_IBM+Lenovo+ThinkPad+R61+8932.htm
2. From this site, it costs $39.95 http://www.eznsmart.com/p-31667-lenovo-thinkpad-r61i-8932-laptop-ac-adapter-replacement-20v-45a-90watt-charger.aspx
Please accept my answer if this is the information you need.
Don't forget to give a four thumbs up rating!
Thank you for asking Fixya.
Jun 23, 2011 | Computers & Internet
Need new adaptor for benQ FP951......because the old one broken....thx
A quick search on Google for "fp851 adapter" turned up several sources. Here's one listing from eBay, which is always a good place to check. If you're not in the US, you can check eBay listings in your area or find an online source that will ship to you. You shouldn't have much trouble locating a replacement.
Jun 02, 2011 | BenQ LCD Power Adapter for FP951 Monitor
THE AC ADAPTOR SPARKS ELECTIRCTY WHEN PLUGD IN
Don't use it anymore. If your computer hasn't been ruined by the sparking electricity, then it will be if you continue to use that adapter. Where is it sparking from? If its sparking from the port on the computer, then your DC jack needs to be replaced. If its sparking from anywhere else on your adapter, then the adapter needs to be replaced as soon as possible.
Aug 04, 2010 | Gateway (6500172) Power Supply
Problem in SENAO High Power 200mW USB WiFi 802.11bg Adaptor
There are a few things you can do in this case. First, I would check to see if you have your network profile set up correctly. This is done by going in to your wireless properties and checking the profile to see if the encryption password is correct as well as the encryption type and so on. Next, you can go in to the device manager and make sure the wireless adapter is recognized and enabled. If you need help doing these things, let me know.
Aug 07, 2007 | SENAO High Power 200mW USB WiFi 802.11bg...
Sony Vaio Laptop Pcg-7z1l Logo
69 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
