Question about Mitel 5220 IP Phone
How do i program direct trunk select on mitel 3300
I can get the set to program a key to select the trunk by setting a speedcall code on the specific key. The problem is that it doesn't give a lamp indication on the phone I'm using or any other phone in the office. If someone else presses the same programed button on their phone they will get a busy indication but I would rather they see the line in use before selecting it.
SOURCE: MITEL 5224-how do you set up your voicemail??
I have this phone at work. There's a button that looks like an envelope. Touch that and it will prompt you through recording your voice mail. This phone also features various "away" messages so that you can record a couple different ones and then activate whichever you want depending on your day. This is also accessed through the voicemail button. Once you play around with it a little, you'll find it's a rather simple phone. Right now, I'm trying to figure out how to access my voicemail from home! Good luck!
Posted on May 13, 2009
SOURCE: we have a mitel 3300 connected to cisco CM thru siptrunk
can somebody help me we have a Sip connection between a mitel 3300 and Cisco callmanager only the conference call doesn't work who can help me out
Posted on Jul 10, 2009
  • 7 Answers
SOURCE: hello we got mitel 3300 PABX with 5212 phones , we
assign speed call with destination number then program that speed call access to call reroute always
Posted on Oct 30, 2009
  • 37 Answers
SOURCE: disable external calls on mitel 3300
This is a function your phone vendor will need to complete for you specifically they will need to setup a Class of Restriction for the set that you would like to block from using your outbound trunks.
Posted on Dec 24, 2009
  • 37 Answers
SOURCE: How to change the names on the phones?
You will need access to the phone system "Telephone directory" form this can be done by your system administrator, or your phone vendor.
Tip
One For All URC-3300 Code Entry To program your One For All URC-3300 remote...
To program your One For All URC-3300 remote control to operate your TV you can use the direct code entry function.
To enter for a code for your TV follow these steps:
  1. Turn on your TV.
  2. On the remote, press the TV key once.
  3. Press and hold SET until the LED blinks twice, then release SET.
  4. Enter the first four-digit code from the code list. The LED will blink twice. If it does not blink twice, go back to step 2 and try the same code again.
  5. Aim the remote at the TV and press POWER. The device should turn off. If it does not turn off, repeat steps 2 through 5 with the next code in the list.
I hope that helps.
____________________________________
One For All URC-3300 Manual
One For All URC-3300 Code List
One For All URC-3300 Code Search
One For All URC-3300 Reassign Key
on May 30, 2010 | Televison & Video
Tip
One For All URC-3300 Universal Remote Reassign Device Key
Would you like to re-assign one of the function buttons on your One for All URC-3300 Universal Remote to control a different device?
If you would like to program the CBL/SAT button to control a DVD player, here are the steps:
  1. On the remote, press and hold SET until the LED blinks twice, then release SET.
  2. Enter 9 9 2. The LED will blink twice.
  3. Press DVD/VCR once.
  4. Press CBL/SAT once. The LED will blink twice. The CBL/SAT key is now ready to be set up to control your DVD player.
I hope that helps.
_______________________________________
How do I cancel a programmed key?
What platform is your phone contacted to? Mitel 3300, Mitel 5000, Mitel 2000?
Mar 13, 2015 | Mitel 5330 IP Phone
How do I change the date and time on a Mitel Superset 4025 phone system?
The time has to be changed in the programming interface of the phone system itself. You cannot change the time from any set other than a 4150 or a super console 1000. These sets can only be used to change the time on a mitel sx200 or icp. This does not work on the 3300.
Oct 09, 2014 | Mitel Superset 4025 Corded Phone...
Tip
  1. Turn on your TV.
I hope that helps.
on May 30, 2010 | One For All URC-3300 Remote Control
Tip
I hope that helps.
Disable external calls on mitel 3300
Nov 25, 2009 | Mitel 5212 IP Phone
We have a mitel 3300 connected to cisco CM thru siptrunk
Apr 02, 2009 | Mitel 5212 IP Phone
Mitel sx-20 trunk interrogation function codes
From a DTMF station set installed as the test line on equipment #1, go into trunk group programming (Command #66)
The SX-20 display will show programming registers.
A B C D E F G H
A,B = Trunk equipment Number (1st trunk should be displayed)
C = Register 1
D = Trunk Group Membership 0 = Incoming only
1 = Group 1
2 = Group 2
3 = Group 4
4 = Group 4
E = Trunk Type 0 = Standard CO Trunk
1 = Dictation Trunk
F = Reversal Meaning 0 = Not Incoming of Disconnect
1 = Incoming Call
2 = Incoming Call or Disconnect
G = Disconnect Timing 0 = 60ms
1 = 500ms
2 = 1.5 sec
3 = 4 sec
H = Start Type 0 = Loop Start
1 = Ground Start
Move to the appropriate register using the ENTER/NEXT function (star key).
Change the data as required.
Exit programming (# key)
Hope this helps!
Mar 25, 2009 | Lands Phones
Mitel 5220 IP Phone Logo
144 people viewed this question
Top Mitel Computers & Internet Experts
Martin Murray
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
