Question about Epson WorkForce WF-7525 colour inkjet wireless printer - A3 EPSON
Epson wf 7525 paper not loading
I put paper in the paper tray but it keeps saying paper not loaded or jam. I have tried everything! I thought it was the cheap paper at first so I got proper branded paper I have put the correct amount in and adjusted the paper guides correctly. The wheels keep going round but they don't feed the paper. This printer is only a few days old and so far I have not been able to print anything because of this problem. Please help
    Top Expert:
  • Epson Master
  • 35,505 Answers
Because this printer is new, the problem is not likely to be due to a worn pickup mechanism but the mechanism may not be working correctly as you have noted. Referring the problem to the printer manufacturer may get results
Posted on Jan 22, 2013
ohms
  • 1879 Answers
SOURCE: computer keeps saying "paper out" or "not loaded properly"
disconnect the printer from the computer
do a manual paper feed
if it can feed paper, replace usb cable or try another usb port
Posted on May 14, 2009
tigertail
  • 163 Answers
SOURCE: Epson R300
First of all turn the printer off & disconnect all of the cables. Turn it over and give it a shake, you'll be amazed at what gets inside the feed hopper. Next try a stiff piece of A4 card (the backing from an A4 notepad for instance), feed the card into the paper feed and push it through quite hard to overcome the spring resistence. Once it has started to go through open the lid and check if it has pushed anything through the rollers. Feed the card all the way through the mech and pull out of the front. Hopefully the card will have cleared the paper path of any objects and reseated the sensors.
Good luck.
Posted on Mar 12, 2009
gwbm
  • 353 Answers
SOURCE: epson stylus C43UX. my printer keeps saying paper
The printer reports a paper jam because the paper feed system cannot feed paper.
Look down into the place where the paper goes (the "automatic sheet feeder" or ASF) and you should see a fat wheel with a grey ribbed rubber facing. Place a single sheet of paper in the ASF and do a test print (right click the printer icon and select properties). Watch to see what happens in the ASF. The plastic panel behind the sheet of paper should move forward to push the sheet against the rotating rubber wheel, which should then feed the paper into the print position. This is presumably not happening! Can you what does happen?
If the expected movements are not happening, you need to remove the printer top cover to see what the problem is and resolve it - perhaps the ASF has come loose or something. This is easy if you know how to do it - otherwise it's likely to cause you to take a large hammer to the task! If you need help on this, please report back with a new post.
Posted on Mar 28, 2009
aicaxz
  • 511 Answers
SOURCE: epson c90 paper feed problem
Is the message general error? The problem is tchip. When turn on chip is recognized by printer, but when start to print, printer "read" some information from the chip. Here is the error. Some pin at the chip for redaing the existence of chip, other pin for reading the information. Check connector between chip and carriage.
Posted on May 30, 2009
  • 4 Answers
SOURCE: My printer (Epson R800) keeps on giving me the error 'Media not loaded correctly'. Even before it's even tried grabbing the paper, it starts blinking red on the paper/trash button. I've never had this
I experience the exact problem. I installed the latest Mac drivers for OS-X 10.6. Did not help. Does not even try to grab the paper, red light flashes on paper / trash button and "Media Not Loaded Correctly" warning. I have experienced more frustrations with Epson printers than any other brand, so this is no real surprise.
Posted on Sep 07, 2009
How do I print on 11 x 14 paper? According to the online manual, the Epson WF - 7620 does print 11 x 14. And that is why I bought the printer, but I cannot figure it out!
Load A3 size paper on the lower tray.
Verify you see A3 as an option in paper setuo on the printer screen against tray 2.
Make sure you have selected A3 on the software before you print.
EPSON WORKFORCE A3 WF 7620DTWF
Sep 18, 2016 | Epson WorkForce WF-7620 Wireless Color...
Why is my Epson WF7620 showing" cassette 1 insert correctly"
The switch inside that makesxeither an electrical connection orca mechanical one tells the printer that the paper tray is home loaded and awaiting commands is not being activated by the tray
The switch has become faulty overtime and needs,a replacement
The bit on the tray that pushes the tray loaded switch has broken off the tray is missing the switch or a wiring fault has developed
And the switch has no power so it still can't see the tray even if it is loaded thus error paper tray missing continuously is being displayed
Jul 04, 2016 | Epson WorkForce WF-7620 Wireless Color...
MY Epson WF-3520 will not print from the rear paper feed.
Try reloading the drivers for you printer for XP, un-install the windows 7 driver and install xp. check the Epson web site for xp drivers if available.
Apr 06, 2015 | Epson WorkForce Office Equipment &...
I have a Workforce WF-2530 printer. When I turn it on, after a few moments it simple says PRINTER ERROR. SEE YOUR DOCUMENTATION." The MENU button does nothing. Holding RESUME and turning printer on
Does your computer have any further information when it's connected? "Printer Error" sounds pretty generic, not a lot of detail to tell you where to look.
I would open the ink loading hatch, and check that there's nothing jammed in there, that all your ink carts are fully seated.
If nothing there, head for the back of the printer, pull the paper-handling tray out, and see if there's paper jammed in there. replace.
Pull out paper tray, make sure there is paper there, and that there's nothing jammed in there too.
When you turn it on, is there any sound, like the printer head moving back and forth?
I have a similar printer, and the error messages I see are rather more informative. . .
Jan 15, 2015 | Epson WorkForce WF-2530
My epson xp-312 will not print on photo paper.it keeps saying paper jam.how can i load when the back tray only allows one sheet of normal paper?
When a printer indicated paper jam, it means one of its sensors does not indicate a movement of paper, where it expects it. In only rare occasions the sensor is defect, but most of the time here is really a jam. This must not be a complete sheet of paper. Can be a little scrap left somewhere in the printer. Sometimes a paperclip fell in or just a paper tray was not put in place. Please open the printer and look careful using a flash light, to see if you can find anything that does not belong in the printer. Then switch it off and really unplug it for a few seconds. Reinsert the plug and switch on. If the error keeps coming back you should call a service centre, although ig you have to send it in for repairs, a new printer is probably cheaper, unless it is still under warranty.
Jan 13, 2015 | Epson Office Equipment & Supplies
Keeps saying load paper, paper is in
Are the rollers worn out? If they have a slick appearance, that is your problem. Also examine the tray and see if it is lifting properly.
Sep 30, 2017 | HP Photosmart 3310 All-In-One InkJet...
Workforce 630 paper jam
Epson Workforce 630 has two paper loading areas. One at the bottom and one at the top, back of printer. Make sure you set the printer to correct paper source, or just make sure paper is loaded in both trays to see if it starts taking paper in either one.
Jun 17, 2017 | Office Equipment & Supplies
Epson Stylus photo 340 r printer paper jam when trying to print
first, make sure you the paper correctly to avoid paper jam.
Single Sheets 1. Open the paper support and raise the extension. 2. Place your paper short edge first against the right edge of the feeder, under the tab, with the printable (whiter or glossier) side up. If you are loading multiple sheets, fan the stack of paper before loading it to prevent paper jams. Note: Don’t load paper above the arrow mark inside the left edge guide. Some special papers can be loaded only one sheet at a time. Slide the left edge guide against the paper. Make sure it is snug, but not so tight that the paper is bent. (For letter- or A4-size paper, you may not need to move the edge guide over.) paper.4.2.1.jpg 4. Open the output tray and pull out the extension. You should also follow these guidelines:Always load the short edge first, even when you’re printing landscape-oriented pictures. • When using special papers, check the paper package for additional instructions. Some papers require using a support sheet included in the package. Note: Always keep unused paper in the original package and store it flat to prevent curling.
if you loaded the paper, it jammed again, remove the paper and tried to print, still the same, its a hardware issue, alraedy, the printers roller is broken
Feb 09, 2010 | Epson Office Equipment & Supplies
Canon pixma 3100 keeps saying load paper and won't print
If you have paper in the loading tray and it keeps giving you out of paper message then the sensor by the loading hopper is not working and would need to be replaced.
9 times out of ten though you might want to clean the printer and make sure the hopper is not just jammed this happens when you put too much paper in there at one given time.
thanks
Sep 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Epson WorkForce WF-7525 colour inkjet wireless printer - A3 EPSON Logo
436 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
