Question about Kocaso SX9701 Android 4.0 ICS 9.7" IPS Capacitive Touchscreen Tablet 1080P 1.2Ghz 16GB WiFi 1GB RAM
Need manual for Kocaso SX9701
Just need instruction manual better than the one in the box
How can I fix the charger port on my kocaso tablet model sx9701?
If the charger port is broken it is unlikely it can be repaired.
As a hint, when you get your replacement, buy the extended warranty.
Apr 16, 2015 | Tablets & eReaders
How to factory reset Kocaso SX9701 tablet lost password and cant get through screen lock
There is nothing in the manual.
http://www.kocaso.com/manuals/SX9700/SX9700_User_Manual.pdf
If you set a pass code (or pattern) that you cannot remember, please enter the wrong password (10-20 times) until you are prompted to sign in via your google account. Please note, this will only work if you have already setup your google account on the tablet. If you have not set up a Google (or Gmail) account on the tablet, you will have to perform a firmware install, which will revert the tablet back to factory settings.
Support Troubleshooting Guide
May 30, 2014 | Kocaso Tablets & eReaders
Hard reset Kocaso SX9701 password lost
When command do I need to reset?
you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it.
Apr 19, 2014 | Kocaso SX9701 Android 4.0 9.7" Tablet PC -...
How do i reset. the screeen is frozen
Try pushing the reset button in the TINY hole in the back of the tablet.
Dec 12, 2013 | Kocaso SX9701 Android 4.0 9.7" Tablet PC -...
Kocaso Sx9722 The operating system will not come up.. Only the word Android
Use the firmware for SX9701 at the bottom of the page http://www.kocaso.com/support.html.
There are instructions to follow and you may need to use the Phoenix Card self extractor. Links are all on the same page.
Jan 23, 2013 | Kocaso Sx9700
Kocaso SX9701 Android 4.0 ICS 9.7" IPS Capacitive Touchscreen Tablet 1080P 1.2Ghz 16GB WiFi 1GB RAM Logo
Top Kocaso Tablets & eReaders Experts
CrisO
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Kocaso Tablet and eReader Expert? Answer questions, earn points and help others
