I did a system restore and the power got shut off now it comes on and stays on but wont show anything on the screen
Try shutting off the computer then enter safe mode by tapping the F8 key untill the system boots. Select " Safe Mode" from the list and run system restore again while in safe mode. If you're lucky the system will restore as it should.
Good luck
Posted on Jan 22, 2013
5 Suggested Answers
leecom72
  • 4806 Answers
SOURCE: Having problems restoring my acer 5100 notebook.need help please!
Hi there.
Log into Windows and press Acer Empowering Key to launch, you can use that utility to restore the system.
If you have a pqservice partition but alt f10 does not work there is a file called mbrwrwin.exe and rtmbr.bin which is needed to install the acer missing magic code all you have to do is type the following on a dos prompt. mbrwrwin install rtmbr.bin it adds the file to a slot
Once you have done that reboot the computer and wait it takes a while to restart, it then it seems to find new hardware (dont know what it finds) then do a reboot and then you can alt f10 to your hearts content.
Good luck and thanks for using FixYa!!
Posted on Mar 15, 2009
jcoady
  • 79 Answers
SOURCE: hear power on, black screen. wont do anything.
Two suggestions:
Toggle the display by pressing Fn+F8 (Function key+F8). Wait a few seconds between attempts in order to allow the system to switch display ports.
Attach an external display to the system and power it on. Once you think it has had time to boot, toggle the display as described above.
Do Either displays work at any point during either test?
If no, the display chipset on the system board has failed & the system board would need to be replaced. If only the external display functions then you have a failed LCD, or the cable/connectors between the LCD and the system board are suspect.
Posted on May 27, 2009
caroldon
  • 17130 Answers
SOURCE: safe mode wont shut off
Possible that the PC's operating software- OS- is corrupt . It ispossible there are problems in the registry files ,the RAM or the main drive of the hard disc.
I think the OS and the drivers need to be reinstalled if the system is not responding to a RESTORE
Posted on Jun 30, 2011
  • 11800 Answers
SOURCE: my acer aspire one D255
The Windows inside your netbook has been so corrupted by viruses that even its own recovery fails. You should try a factory restore: while the One boots (the Acer screen is on) press F10 - this will launch the recovery process, follow it with the instruction on the screen. If even this fails then the corruption has damaged even the recovery partition.
In that case there is only one thing left to do: you will have to order and buy at Acer a recovery disk and use it (with an external cd unit) to reinstall. You do that here
https://secure.tx.acer.com/RCDB/Main.aspx?brand=acer
Posted on Jul 03, 2011
Wont Boot 1st PSU Flashing Amber
standard troubleshooting:
1) I've seen power sources appear to power up a system, but are somehow broken just enough to not get the system to POST (do you have another system you could at least borrow the power source from?)
2) pull anything you can so that you just have mobo, power, cpu, memory, and graphics.
2a) try using just one memory chip (and try each chip you have, or best to borrow a chip from a working system); even try different slots
2b) if onboard graphics, try a known working graphics card addon
2c) does the screen power off (like normal sleep) or system shutdown? if latter, try re-thermal pasting the heat sink to the cpu.
May 22, 2016 | Fujitsu Siemens Siemens PRIMERGY RX300...
LG LS970 wont reset stuck on system screen wont show keyboard
take the battery out of it and start over..
Jan 12, 2014 | Cell Phones
Dell latitude e5510 laptop got blue screen saying that a problem has been detected and windows has been shut down to prevent damage to your computer but it wont do anything ele's help any one
have you made any changes before the blue screen appear? installing a driver maybe? if you have,try to undone those changes by booting with Startup with last known good configuration (undo recent registry and driver change),use System Restore,or Roll Back device driver,Scan your computer for viruses
and Return BIOS settings to their default levels,go to BIOS by pressing F2 or del exactly after you press the power button and the screen show up
if it still in blue screen,that's probably that some of your system file is missing,and you need to reinstall your operating system
Please let me know if it's working or not,i don't like to abandon anyone,and thanks for using fixya
Aug 29, 2012 | Dell Latitude E5510 Laptop Computer (Intel...
I dropped my iphone and it doesnt stay on now. it will show the apple logo, maybe come onto the passcode screen and then completely shut down after a couple of mins. it wont stay on long enough to restore....
That exact thing happened to me, when you plug it in, does it show a battery with a very small amount of red fluid? If it does, leave it plughed in for about an hour or two. That's how I fixed mine, it was then fixed and Itunes recognizes it too. Hope I helped.
Jan 15, 2011 | Cameras
I updated my Toshiba Satellite laptop, it was an up date that came with the computer and a update for a flash player that I think came with the computer, So I installed them both and it said if I turn the...
Take your battery out, leave it out for 5 minutes and try it again. If the same thing is happening afterwards, and you are able to, connect an external monitor to your laptop and use the function key to try and switch to it, and see if that works and if there is anything showing up on it.
Sep 16, 2009 | Computers & Internet
My PS3's hard disk file system is corrupted
There is an alternate way to restore your HDD. Turn off your system and when u see the red light, hold the power button in front until you hear a total of 4 beeps (1 alone, 1 alone, 2 together). It usually works on second try. it should show a screen and say hook up controller with a usb cord. Then it should show i think 6 options. Choose the restore option. it should work.
Hope it works and wish you all the best!
P.S.- I just got the 80010514 error on my ps3 and my ps3 games dont work anymore :(
Jan 07, 2009 | Sony Playstation 3 (PS3) Console
File system error
If its possible plug the unit in your computer and it should come up in My computer under removable storage. Right click it then cilck format.
Jan 05, 2009 | Philips GoGear SA3245/37 Digital Media...
TOSHIBA SATELLITE LAPTOP a300d-14O TURNS ITSELF ON AGAIN AFTER SHUT DOWN WHEN LID IS CLOSED
Your power management in Windows is corrupted. I would do a system restore to an earlier date.
1.
Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore.
2.
On the Welcome screen, click Restore my computer to an earlier time, and then click Next.
3.
On the Select a Restore Point page, select the date from the calendar that shows the point you'd like to restore to, as shown in Figure 2, and then click Next.
Figure 2
4.
On the Confirm Restore Point Selection page, verify that the correct restore point is chosen, and then close any open programs.
5.
Click Next if you are ready to proceed or click Back to change the restore point.
6.
The computer will shut down automatically and reboot. On reboot, you'll see the Restoration Complete page, and then click OK.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 19, 2008 | Computers & Internet
Toshiba satellite with windows xp will only show black sreen and wont let windows xp repair
Your description of the symptom shows that your operating system installation has been corrupted. Fastest and easiest way to resolve the Issue using the "Recovery and application disk" (it comes with laptop) to perform full system recovery. I would like to remind you full system recovery will erase everything saved on Hard drive. You can check possible option on http://support.toshiba.com
If you dont have recovery and application disk you get one. You can call Toshiba @ 1-800-457-7777
Please post if you need further assitance
Good Luck
Jan 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
Wont power down after shutdown
your operating system is screwed up,backup your files and reinstall with the restore disk/repair ,good luck
Nov 26, 2007 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
