Question about Gateway 500XL PC Desktop
Video Card You responded to my question about replacing a video card. It is on the motherboard however I am unsure as to where I would plug the new one into, also, I havent a clue as to the type all sites talk about pci and something else and when I look inside my pc I dont see what they are talking about.
  • amycorsi5 Jan 28, 2009
    I have one pci slot empty and the agp slot has something plugged into it - it looks like another plug in for a monitor. Ok I feel like a complete dunce when I plug my monitor into that slot it works. Is this a backup?
    Thanks for all of your help.
    Done - not sure how it gave the other rating....clearly I am having a non tech savvy week!
    President:
  • Gateway Master
  • 1,314 Answers
Okay this model is rather hard to find the specs for lol. I need to know what type of slots you have on the inside. You should have some PCI slots which look like this. I need to know if next to them you have an AGP slot which looks like this. (Note, the AGP is usually brown and above the PCI slots).
Based on this information, then you can purchase either a PCI video card or an AGP video card which will work in your system.
PCI Video
AGP Video.
Thanks and please rate as fixya.
Posted on Jan 27, 2009
  • Kevin Shafer
    Kevin Shafer Jan 28, 2009
    Not a problem; that is your working video! Can you come back and change this from a bad rating to a fixya rating? Thanks!
  • Kevin Shafer
    lol I'm glad you had one already there and you didn't have to replace it. Good luck!
I had an emaxx motherboard model MCP61M-iCafe if I insert any video card it gives no display on the monitor.If I remove the Video card it's ok please help me
Assuming the computer is powered off and you confirm the card is properly seated and the video cable (vga, DVI, or HDMI) is snugly plugged in, it's going to be a driver issue. I would do the following
  • plug in the card
  • keep the video cable plugged into the onboard video
  • boot up
  • install the drivers
  • reboot and plug into the new card
Dec 28, 2014 | Computers & Internet
My Mother board is ECS P4M900T-M2, im thinking of upgrading my video card into 512MB or 1GB video card. is it possible since the specs of my board says; Integrated Chrome9TM HC IGP Memory: Maximum up...
Yes it is possible to still plug-in an expansion video card. The 256MB limit is for the shared memory if you will be using your integrated Video Card. You can ignore it once you plug in the new video card.
Hope this helps.
Sep 04, 2011 | EliteGroup P4M900T-M (V1.0) Motherboard
I replaced a cd rom and a graphics card and now I have no video signal. I wonder what I did wrong.It was a simple unplug the old one and plug in the new one. What did I miss? Could I have plugged into the...
If the card fits, you got the right socket.
Make sure the graphics card is seated fully, and then check to see if it needs a second power cable. Switch back to your old graphics card and uninstall your graphics drivers, then reinstall the new card.
Mar 01, 2011 | Soyo SY-P4VGM Motherboard
I'm getting wavy lines on my monitor. When I go into the menu of the monitor itself there's no lines so I'm thinking it's something with the computer itself. Perhaps the video card is going bad?
That's possible. I've had people send monitors in for service because of lines or distortion, but since the lines don't show up when they print they figure it's the monitor's fault. A new video card fixes that. Or the monitor might be at fault.
Test the monitor with another computer. If you don't have more than one, get a friend to bring over a laptop. Except on Macs, the external monitor connector on laptops is a standard VGA type, so you can plug your monitor in. If there are still lines, you'll know it's time for a new monitor or to see about service.
If you need a new video card, make sure you get one that will fit your motherboard. There are different slot types for video cards (PCI slots in older computers, AGP slots in newer ones, and PCI-E in the latest versions). This page can help you figure out which you have if you don't already know. Once you get a replacement card, all you need to do is plug it in to the appropriate slot. The motherboard will detect the new card and start using it. (I'm assuming you'll be installing a card where there wasn't one before. Most consumer computers have integrated video and that's what you're replacing with a plug-in card. If your computer already has a separate video card, obviously you'll just swap the old one for the new one.) Also - this will sound obvious but it's amazing how often it's overlooked - you need to connect your monitor to the video connector on the new card. People sometimes plug their monitors into the integrated video connector out of habit. On some motherboards the integrated video still works when you plug in a new card, but on others the on-board video is disabled. Then you either have the same bad video, or none at all.
With a new video card, your display may look funny when you start Windows the first time. Until you install the drivers that come with the new card, the color depth and resolution settings may not be right. But with the right drivers installed, your display should be back to normal.
Hope this helps. Thanks for using Fixya!
Nov 30, 2010 | E-Machines eMachines Desktop PC
Hi I have an HP ECS Motherboard. It has a pci exp.1.0 I tried to install a EVGA 01G-P3-N981-TR GeForce 9800 GT 1GB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card, the card is running...
hi,,,
see to it in the BIOS SET up if that card been detect into your motherboard.. the video card must be install through the drivers ..
thanks..
Jan 08, 2010 | Computers & Internet
I get no video and the monitor is good. Need to
IT doesnt matter. If the Video Card is built into the Motherboard and has failed; you can get NEW Card that can plug into an Expansion Port on *********** board
Make sure your motherboard is compatible with the NEW video card. For example, PCI Express video cards won't work with motherboards designed only for AGP or PCI video cards, and vice versa. Tigerdirect.com has a good selection. Call their Customer Service Tech; they have great prices, sales and knowlegable Customre Service Tech to Check if it is the right Type of Card. Its probably PCI but check anyway.
Simply shut down unplug and open the computer side panel and go to the back of the Machine. If there is a separate Card (it will be obvious as it has a VGA port) Remove it and just install your new card in its place and plug in your Monitor to the new VGA port. If not then just POP OUT A FREE SLOT in the back of your Computer next to the Plug In Port so the VGA port that the monitor plugs into stick out the back and plug in your Monitor.
Close , plug in and INSTALL THE SOFTWARE THAT COMES WITH THE VIDEO CARD. Set all settings to DEFAULT or be creative :)
Cheers !
Aug 21, 2009 | HP Pavilion a1253w Notebook
My video connection does not work monitor says "no signal." I checked all connetions and they's properly connected.
Check to make sure you have correct ram installed in motherboard as the video card may share that ram. Check CPU that it's installed correctly and video should work. If not then the motherboard is bad.
Jun 01, 2009 | Asrock P4I45GV R5 Motherboard
I change my video card settings in Bios to AGP, after that, i already installed my video card, but no display appeared, ican't restore my video card setting to previous settings because my monitor has no...
if you still have old video card remove the new one and replace with old one
change setting back in bios
then reinstall new card and instead of changing through bios just start computer it should automatically change settings for you
please let me know
May 03, 2009 | Computers & Internet
Keyboard/Mouse Plugged in NO VIDEO NO Keyboard/mouse plugged in VIDEO ???
Apparently there is something confilcting with something ot the ps2 ports are faulty! We'll need to find out! Try plugging up your system without the video card but the ps/2 devices plugged in! (we don't need to plug up hard drive, so plug them out if they are plugged in) When the system comes on(after your hear the POST beep, if the system speakers is plugged up to the motherboard). Try pressing NUM LOCK or CAPS LOCk to see if the light come on and off. If they do that means your machine is responding with the PS/2, if not then you need to find a PS/2 expansion adapter ot use a USB Keyboard and mouse! If you do get a response that means your ports are working and there is probably a confilct with your Video card! In that case, I assume you've already reset the cmos(if you haven't then do that). Also if you have an AGP port try an AGP Card, if you were using an AGP card try a PCI! Well the USB keyboard more than likely will work! try these out and get back to me! regards, babb
May 02, 2007 | Tekram P6 PRO-A5 Motherboard
Gateway 500XL PC Desktop Logo
146 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
