Question about Kenmore 22422 Top Load Washer
I have a Kenmore it does everything but spin...it makes all the right sounds as if it is working...but tub does not move... however... this happened once before so I started doing smaller loads....all of a sudden it started spinning again.... then out of the blue it stopped working again... then it worked again one time...and now again will not spin???
    Problem Solver:
  • 8 Answers
Lid switch ,drive coupling between motor and trans mision,or a bit more complicated ...the clutch [brake assembly]worn out .need to take machine appart for last solution.
Posted on Jan 22, 2013
5 Suggested Answers
  • 2920 Answers
SOURCE: Washer stopped spinning (spins only once in a while)
you probably have a clogged drain on the washer
Posted on Jan 01, 2009
  • 113 Answers
SOURCE: Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Posted on Mar 03, 2009
jsrock516
  • 5911 Answers
SOURCE: Series 70 kenmore washer ,spin cycle not working
If the washer will fill and drain, but won't agitate or spin, you, indeed, may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupling can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria. Let me know if you have any questions. I hope you find this information helpful. NOTE: There are other problems that can cause the washer symptoms as you describe, but the motor coupling is the least expensive and easiest solution to try first. If the motor coupling is still intact, please let me know.
Posted on May 27, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Washer 110.24992300 spin problems
The pressure switch is mis-reporting the water level to the ECU.
Test/replace the pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Kenmore elite he4t makes a sound like a card in the spokes of a bike when spinning. Everything else seems to work. It was just moved cross country.
the spider gear is bad,you can take the bottom panel off to see if the shocks or one of the shocks are broke but if it's happening in the spin cycle it's the spider gear.i hate to tell you this but it would be cheaper to change out the washer,the gear is like 500 bucks just for the part and you have to pull the hole washer apart to get at it and split the tub and change out the back part of it,this happens mostly from using to much detergent,it eats at the spider gear and it crumbles like acid is on it,everybody reads the back of the bottle but those measurements are for top load washers,the front loaders use less water and very little detergent and it should be H.E. detergent,it has less suds in it.let me know how you make out,don't call anyone in to check it,isee this all the time,save your money for a house call.good luck
Sep 01, 2010 | Kenmore HE2 Plus Front Load Washer
My kenmore 90 series model 110 will not spin, makes a buzzing sound
HI,
This problem is caused by either a broken washer tub drive belt or a broken washer tub drive coupler, look under the machine for evidence of this.If it is found to be true you have to go for a replacement of that particular unit.
Mar 29, 2010 | Kenmore 24032\24036 Top Load Washer
Describe your Kenmore 24032 \ 24036 Top Load
MAke sure that the cothes are not unbalancing the tub. Iv seen this happen where the clothes are unbalancing the tub and it moving around and the when the water for the rinse is coming out its not getting in the tub its splashing on the top of the tub ring due the the unbalanced spin. does this happen when you wash a heavy load? do you notice it not doing that when you washer a light load?
Jul 26, 2009 | Kenmore 24032\24036 Top Load Washer
Loud noise in washing machine
Hi, Raise the lid and stick something into the hole to activate the lid switch. Start the washer in spin cycle and after 30 seconds or so, release the lid switch and see if the tub continues to turn and make the rumbling noise. It sounds to me like the block that holds the inner tub has gone bad.
Has nothing to do with the move but, might have just happened.
Please let me know if this is the case or if I can assist you further.
Thanks
Vic
May 30, 2009 | Kenmore 22422 Top Load Washer
Kenmore Washer Tub banging on fast spin
there are some springs that help hold the tub even as it spins also make sure that the washer is level check front to back side to side and corner to corner if it is unlevel they will be out of balance in high speed spin
May 07, 2009 | Kenmore 23822 Top Load Washer
Kenmore Elite Washer top load Wont spin
Sounds to me like the belt is broken or has slipped off. Try taking the back off (6-8 screws) and you will immediately see if that is the problem.
Dec 23, 2008 | Kenmore Elite 45986 Front Load Washer
Squeeling sound on spin cycle
This sounds like the same problem I had with my 887-327. It seems that coins can fall into the water pump from the bottom of the drum. I had to pull the water pump off the direct drive and turn the blades until the dimes came out. After I reinstalled the pump everything was quite again.
Nov 24, 2008 | Kenmore 88732 Top Load Stacked Washer /...
Kenmore 94802 washer belt overheats, smokes, and melts
sounds like perhaps the trannsmission has locked up and is not spinning freely, therfore the belt is meeting resistance and not turniing.( try turning the trans. pullley( where the bsck of belt is wound)does it turn freely??? try turning the tub from inside does it spin at all??? before i condemn the tranny i would check for article of clothing fallling between the tubs, holding from spinning, also ive seen (nails/screws/bra underwires,etc..) poke through onr of the holes with in the tub abd stuck to the outer tub also preventing the tub from spinning, look closely to all the inner basket holes!!!
Apr 08, 2008 | Kenmore 94802 Front Load Stacked Washer /...
Kenmore 22422 Top Load Washer Logo
22 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
