Question about SpeakerCraft BassX-10 Subwoofer
I need a repair center for a home theater powered subwoofer. Unfortunately, the manufacturer does not repair the units out of warranty. Do you know of a repair center that could help?
  • yukinmataki Feb 16, 2009
    I have a no sound subwoofer g-608 doesn't make sound, anyone know a repair center in layton, ut area
  • jsolerfam Apr 26, 2009
    my subwoofer does not turn on,
    is an polk # psw 202-50335
    need a place to fix it,in orlando fl
Found someone local who would fix it in their garage. Search Spectronics Las Vegas.
Posted on Jan 28, 2009
How to prevent subwoofer from going to the stand by mode
According to customers on the Amazon website there is no override option to prevent it switching off.
Sep 28, 2014 | Onkyo SKW-204 Powered Subwoofer
I have a Panasonic SB-WA340 Active Subwoofer, and need to know if this is compatible with other Panasonic home theater units?
It should be compatible with other Panasonic equipment that has an output for a powered subwoofer
Dec 25, 2012 | Audio Players & Recorders
My hkts 15 subwoofer sounds blown. Ive tested the speaker and its not. I sent it in for repair and they could not find anything. Now I thinking its the amp? One day it started working fine and then sounded...
It could be either bad parts or bad solder connections or both but I agree with you if did what you said. Amp will have to be run for a while to know if it or something else.
A scope monitoring the line with the issue will be able to see when it fails.
Dec 21, 2012 | Harmon Kardon HKTS 15 5.1 Home Theater...
Can i put an extra sub woofer on my lg da3525 via the woofer out socket and what plug do i require to do this
How to Connect 2 Subwoofers to One Receiver
Subwoofers produce the deep bass sounds that give home theater the realism of being at the movies. A good subwoofer can rattle the walls during action sequences, while adding depth to recorded music and a heightened sense of feeling in the midst of a televised sporting event. Because most home theater receivers are equipped with a single subwoofer jack, connecting a second subwoofer requires a simple audio adapter available at electronics stores. Self-powered subwoofers have their own built-in amplifiers to drive the bass speakers, so they cannot drain power on the main receiver in a system and thus pose no danger to the equipment, even when an extra subwoofer is connected.
Things You'll Need:
Home theater receiver
Y-adapter with RCA jacks on two ends and an RCA plug on the other, available at electronics stores.
2 RCA subwoofer cables
2 subwoofers
Instructions
Plug the Y-adapter into the home theater receiver's "Subwoofer OUT" jack.
Connect an RCA subwoofer cable to each jack on the Y adapter and route the cables to the subwoofers in the room. Because subwoofers deliver an omnidirectional sound, the boxes can be placed anywhere they won't get in the way, but within reach of an electrical outlet..
Plug an RCA cable into the "Sub IN" jack on the back of each subwoofer.
Connect the subwoofers to wall outlets and turn on each unit by pressing the power button, typically located on the back panel.
Adjust the volume and crossover settings on each subwoofer as desired. The crossover adjustment knob tells the subwppfer which low-end frequencies to reproduce from the audio signal, such as a movie on DVD. All frequencies higher than the crossover setting will be transferred to the other speakers connected to the receiver.
Tips & Warnings
Use subwoofers that are closely matched in power, as rated in watts, when using two subwoofers in a home theater setup.
Disconnect the subwoofers from the power supply while making the audio connections.
Have a nice day...
Feb 19, 2011 | LG DA-3525 Theater System
LED lights dim on HT720
Check the subwoofer for a blown fuse. I hope this helps. ~ Bruce :)
Aug 31, 2009 | Audio Players & Recorders
Subwoofer powers on for about 4 seconds and then shutsdown
I don't know if you were able to get the problem fixed, but I had the same sort of problem where it worked and then all of a sudden it stopped working right in the middle of a movie.
I took it to a repair shop and he found that it was the power supply... a $4.00 part.
Jun 14, 2009 | JVC TH-C30 System
SP-PWM505 subwoofer does not stay on
Well i had exactly the same problem, my sub turned off right away when i turned the whole thing on. Well i opened the subwoofer and was trying to find out something unusual, i took out, i believe, internal amp, well, whatever that thing is, under the lid. Which one is screwed with 6 copper screws, so you unscrew those screws, lift that lid and that whole board comes out. On that board i find something like burn around one of the parts.
http://www.flickr.com/photos/28004328@N04/3333561417/in/photostream/
you can see it in the pick, the part q2902, then i contacted JVC. At the beginning they said i need to take the whole thing to service center and so on. But later i made them to tell me what kind of part that is, so here :http://www.jvcservice.com/store/ProductDetail.asp?Part=KTC3199/GL/-T
bought soldering gun in home depot for $15, returned after i was done. And that is it, just have to replace it, but total cost only $12 ($5 part +$7 shipping)
May 15, 2008 | JVC TH-M505 System
Jvc th m603 center unit - powered subwoofer
Yes go to JVC.com It will cost you $20.00
Mar 30, 2008 | JVC TH-M505 System
No power!
every thing is working the system and the subwoofer my problem is the center and surround speakers are not working
Nov 20, 2007 | Panasonic SC-HT720 System
JVC XV-THC4 Home Theater System
it a 8pin din cable ,,,,I picked up one from a specialty cpu shop in Norcross,Ga
but search ""8pin din cable"" see what you find!!!!
the power cord is extremely common ,you can find that one anywhere ,,,,,most any dvd player ,playstation etc etc etc uses that cord
Sep 17, 2007 | JVC THC4 Home Theater System with 5-Disc...
SpeakerCraft BassX-10 Subwoofer Logo
457 people viewed this question
Top SpeakerCraft Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
James Oliver
Level 1 Expert
Craig Butler
Craig Butler
Are you a SpeakerCraft Audio Player and Recorder Expert? Answer questions, earn points and help others
