Question about PC Magazine Startup Cop Pro
Startup cop pro consumes cycles, forgets settings
When i restart my computer, and some other times when I notice it is running slowly, Process Explorer says Startup Cop Pro is using up to 50% of the cpu cycles. More recently, every time I restart, SCP "discovers" "changes" in 15-30 programs, and wants me to decide whether to allow them. I don't want to click on "allow all", in case there's something bad hiding in there, but it's a pain.
  • PC Magazine Master
  • 3,187 Answers
Down load ccleaner and do a run on this software its free and safe clean the files then clean the reg files using the software. old reg files can cause problems as so software tries to reuse them and they have been changed by the system that's way they old. i use this alot to speed up system and works just fine.
Posted on Aug 04, 2017
I need to find a set up disc
What operating system set up disc are you referring to ?
Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
a) Insert the Windows 7 System Repair DVD or Installation DVD and reboot.
b) Select the correct keyboard input method and click 'Next'.
Note: If you are using the Windows7 Install DVD then at the 'Install Now' prompt (Do not pick the Install Now option) instead choose the 'Repair your computer' option located in the lower left of the dispay.
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options.
Do you want to apply repairs and restart your computer?"
d) Click 'Repair and restart' and reboot again to the Windows 7 System Repair environment.
e) Click 'Next' at the keyboard selection prompt and when the 'System Recovery Options' screen appears verify that the "Use recovery tools that can help fix problems starting Windows" is selected.
Note that on your Dual Boot system there now should be only one operating system listed. Click the 'Next' button.
f) Now from the menu list select the 'Command Prompt' option.
g) At the DOS prompt type the following three commands:
bootrec.exe /fixmbr
bootrec.exe /fixboot (may return an 'Eliment not found' message)
bootrec.exe /RebuildBcd
h) Close the command prompt window and click the 'Startup Repair' option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages "Windows cannot repair this computer automatically" and "Startup Repair cannot repair this computer automatically".
These messages are the result of the radical changes made by removing the other drive. Ignore the Send/Don't send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window.
Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'.
This time the repair process may only that a few seconds and when prompted "Startup Repair could not detect a problem", click 'Finish' and run the 'Startup Repair' option one more time, click 'Finish', and then remove the System Repair DVD and click 'Restart'. Reboot the computer.
http://windows-xp-pro-startup-disk.soft32.com/free-download?gclid
windows xp pro start up disc
http://systemdiscs.com/?utm_source=neosmart&utm_medium=article&utm_campaign=Vista_Recovery
vista recovery disc
Hope this helps.
Nov 20, 2012 | Computers & Internet
Upon starting my dell inspiron mini 10 I have to wait 17 min before I can use the start button. ctl+alt+dell show me the process running: system idle process is the only process running, the CPU usage...
Do you have any antivirus program installed? If you have, check if it set to scan during startup. This might be the reason why your computer is slow during startup since a full computer scan can definitely eat up memory usage.
Hope this helps.
May 22, 2011 | Dell Inspiron Mini 10 Notebook
After a few minute my mouse get hang and i need to restart my computer..i am using windows xp.can u please help me?
Could be a possibility that there is a background process which is consuming most of your memory due to which its getting hanged. You can try to start the computer into the clean boot mode and observe the computer performance.
start->run->msconfig
select Selective Startup and uncheck "Load startup items" and then click OK.
Then restart the computer. Hopefully it should resolve the concern.
Feb 13, 2011 | Computers & Internet
I don't want Palladium on my computer and I can't delete it
Manual Removal procedure for Palladium Pro The first step you must take in order to remove Palladium Pro is to stop one of the following processes below. Only one of them will be running.
  • Palladium.exe
  • PalladiumPro.exe
  • Palladiumantivirus.exe
  • Z.exe
To Stop this process you can browse to the file location shown below and re-name the file first and then restart your computer. Then browse to that file location again and delete the file.
The next step in Palladium Pro removal is to delete the following file:
Windows XP :
  • C:\Program Files\Palladium Pro\PalladiumPro.exe
  • C:\Documents and Settings\USER NAME\Application Data\Palladium.exe
  • C:\Documents and Settings\USER NAME\Application Data\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\Palladium Pro.lnk
  • C:\Documents and Settings\USER NAME\Application Data\Roaming\Microsoft\Windows\Start Menu\Programs\Palladium Pro\Palladium Pro.lnk
  • C:\Program Files\Startup\Palladium Pro.lnk
Windows Vista / Windows 7 :
  • C:\Users\YOUR USER NAME\AppData\Palladium.exe
  • C:\Program Files (x86)\Palladium Pro\PalladiumPro.exe
  • C:\Users\YOUR USER NAME\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\Palladium Pro.lnk
  • C:\Users\YOUR USER NAME\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Palladium Pro\Palladium Pro.lnk
  • C:\Program Files (x86)\Startup\Palladium Pro.lnk
  • C:\%AppData%\Z.exe
Once you have successfully deleted these traces, Palladium Pro should no longer be running in your machine and now you should run a complete virus scan for the system using Spyware Doctor with Antivirus. This will let you know whether you have been able to remove all the traces of Palladium Pro successfully and also whether there is any other threat still available in the system.
If you need advanced help or an expert we recommend www.onlinecomputerrepair.org
Palladium Pro Registry Removal Procedures Now that your system is free from the Palladium Pro file traces that have been mentioned above, it is time to get rid of the infected registry items.
  • HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run "Palladium"
  • HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run "Palladium Pro"
  • HKEY_CURRENT_USER\Software\Palladium Pro
It is important that you run a complete virus scan for your computer when you are done with the removal procedure to ensure maximum protection for the system. For that, we suggest you to run the scan with Spyware Doctor with Antivirus.
Palladium Pro Directories: XP
  • UPDATED: We have a report of it being at C:\Windows\Palladium Pro for some users.
Windows 7 / Windows Vista
  • C:\Program Files (x86) \Palladium Pro
Or mail me googolplexcorporation@gmail.com we will remove it through remote desktop support
Jan 27, 2011 | Computers & Internet
My macbook pro OS 10.6.4 either freezes or crashes on startup. Crashed when trying to startup with Drive Genious 3, TechTool Pro 5, System Disk or Disk Warrior. Not sure what to do next. Tried holding ...
Restart your mac. As it's restarting/booting up, hold down the command, option, R and P keys simultaneously. As it's booting up and you're holding these keys, you should hear the startup chime, continue to hold the keys down, it will cycle and you'll hear the startup chimes again. Let it go thru this cycle 7 (seven) times before you let up on those keys. Once it's cycled 7 times, let it boot up normally.
If that doesn't work, then reinstall the original system software that came with the Macbook. You may have to reformat the hard disk and do a clean install.
Jul 05, 2010 | Apple MacBook Pro Laptop Computer with...
A system shutdown notice appears on the monitor that i can't delete
assuming that u r using win xp pro sp2..
hv a licensed and UPDATED antivirus installed (i prefer avg/kaspersky, however, without updation a full version antivirus is useless)..
download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'remove all the unnecessary startup items from here..(if u can't find what to remove, post me/us in ur comment with all the items listed in each n every tabs herein)..
remove all unnecessary software from add/remove programs..
download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
disable the follwing: a) 'Automatically Restart' right click on my computer->properties->advanced->startup n recovery->(uncheck on the) Automatically Restart; b) 'Error Reporting' right click on my computer->properties->advanced->error reporting->disable error reporting->(uncheck on the) 'but notify me when critical error occur'..
to hv better supervision try contacting ur system admin/vendor....
Nov 06, 2009 | Computers & Internet
I am trying to reinstall my visioneer 4800 old scanner on my XP. I am told it doesn't find Twain and I do not know how to instll it safely. I think it was uninstalled at a time when the computer was...
Before you install try this.
1. Start -> Click Run
2. Enter msconfig and click ok
3. Click Startup tab
4. Uncheck program that you don't want to startup
You can disable programs that you don't want automatically load when you start your computer. By disabling these programs will help your computer startup faster.
5. Click Ok and restart
Now you should notice that your computer startup faster.
My Hot Tips to Make Your Computer Faster:
* Regularly check your startup folder to prevent malicious programs installed itself without your knowledge.
* Delete the temporary files from Temp folder (Start > Run > %temp% > delete all files).
* Upgrade your RAM to makes your computer boot faster : )
I hope this helps you to make your computer faster..
Sep 16, 2009 | Visioneer 4800 Flatbed Scanner
My startup page on my computer takes forever. How to speed it up
If you're running Vista that's normal.
Here’s a quick procedure that helps speed windows vista startup:
  • Click the Windows Start button
  • Right click Computer
  • Click Properties
  • Click Advanced System settings
  • In the Advanced Tab, Start and Recovery, click Settings
  • In the Time to display operating systems list setting, set a 5 second value instead of 30.
  • Click Apply
Now, Reboot your PC. You’ll notice a boost in the performance of the startup process.
Mar 08, 2009 | Dell Pentium 4, 2.26 GHz (1W391)
CPU goes to 100 % usuage with more then 2 gigs memory installed
Firstly make sure that your BIOS doesn't have a configuration/setting for larger RAM installed and doesn't have any RAM paging configurations that need setting.
If Kingston tech support couldn't solve this, we can presume that the memory sticks and the motherboard memory addressing is good. To solve this you need to look for an application post-startup that is hijacking your CPU. It's then likely that you have an older application that when it addresses more than 2 gigs gets thrown into an endless loop and hogs your system. The following will identify and help you eliminate that application.
With your 2 gigs installed, do the following.
Click Start>Run and type in "msconfig". This runs the configuration utility that shows your startup programs and services. Select the "Diagnostic Startp" option , then click "Apply" and follow the restart instructions. When your system reboots select "cancel" when asked to restore the settings. This will keep these settings through the next steps. Make sure that your system works well in this diagnostic mode with the 2 Gigs. All those burdensome background running applications that sap your system resources will be eliminated (temporarily) and bare Windows can run unencumbered without being dragged down. Shut down your system.
Install the remaining 2 gigs. Reboot and see if the system still maxes out at 100% (make sure you leave it for a while to give it a chance to settle down).
Try your issue again. If this time it operates as normal without the system being maxxed out, you'll know that at least one of those startup applications is the culprit. Running msconfig again will allow you to restore the Normal Startup, and the Startup tab will allow you to remove selectively that application that is causing the issue.
One way to identify which one is the culprit is to restart normally (select the Normal Start option in msconfig and reboot) and once back up, do a ctrl-alt-del to bring up the Task Manager. Click the "Processes" tab and then click the heading "Mem Usage". This will sort running processes by how much memory resources they consume.  The memory hogs may not be the one giving you the problem, but it's likely that a heavy memory/resources consumer is also sapping the CPU cycles needed to operate normally. Make a note of the top heavy memory users (print a screenshot) and use this list to eliminate any that are also on the startup list back in msconfig.
Don't use the "End Process" button in the Task Manager to simply stop them, as you'll likely stop one that is critical to Windows functionality. Msconfig's Startup list just shows the ones that get started at Windows boot up and can be eliminated without crippling Windows - much safer.
Use your memory hog list to start eliminating, one at a time, the offending applications from the startup list until the issues is resolved. Its a little tedious, but helps clean up your system in the process.
Hope this helps, and please rate my answer.
Dec 31, 2008 | Evga (133-P4-NF51-AX) Motherboard
Xp windows explorer delay w/ "open with"
Sounds like you have too many background applications running that intercept right-clicks for their own functionality.
Click Start>Run and type in "msconfig". This runs the configuration utility that shows your startup programs and services. Select the "Diagnostic Startp" option , then click "Apply" and follow the restart instructions. When your system reboots select cancel when asked to restore the settings. Now all those burdensome background running applications that sap your system resources will be eliminated (temporarily) and Windows can run without being dragged down.
Try your issue again. If this time its quick and without the long lags you reported, you'll know that at least one of those startup applications is the culprit. Running msconfig again will allow you to restore the Normal Startup, and the Startup tab will allow you to remove selectively that application that is causing the issue.
The memory hogs may not be the one giving you the problem, but it's likely that a heavy consumer is sapping the CPU cycles needed to handle your right-click pop-up menu and run-with selection. Make a note of the top heavy memory users (print a screenshot) and use this list to eliminate any that are also on the startup list back in msconfig.
Hope this helps.
Dec 27, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
Top PC Magazine Computers & Internet Experts
David Payne
David Payne
Are you a PC Magazine Computer and Internet Expert? Answer questions, earn points and help others
