Question about Black & Decker FP1400 Quick N Easy Plus Food Processor
Shredding zucchini or carrots
I have a problem using the shredder when I shred zucchini or carrots and such. Instead of being nicely shredded it all turns to mush and some turns into chunks. I think the combination disk is the big problem. Sure could use some advice on getting a nicely shredded product or will get rid of it and go back to an Oster as I had beautifully shredded results from it until it was no longer repairable. Becoming a very frustrated cook! Help!
3 Suggested Answers
SOURCE: I have a Black and Decker Handy Shortcut, I need a part
I need the exact same part.
Posted on Aug 13, 2008
  • 1304 Answers
SOURCE: I broke my FP1445-10 Shred Disc on my Black & Decker
F905801440000000 SLICE/SHRED DISC call 1-866-925-PART
10.00 bucks
have a great day
Posted on Oct 08, 2009
  • 1739 Answers
SOURCE: Need a slice/shred hub for the Slice/Shred Disc
Available replacement parts for Black & Decker FP1200 Quick N Easy 8 Cups Food Processor can be found here:
Posted on Mar 26, 2011
0 characters
1 Points
How can I put shredding blade on the arm stand?
It should come with it. The riser for the disc goes on the boss where the blade would go. The disc goes on top of the riser, then the lid and you feed food to the shredder through the chute tube.
Apr 14, 2016 | Food Processors
How do I remove shredding disc from center of plastic bowl. 1st time in 37 yrs it is entirely stuck.
wow didn't know they lasted that long . but get some really good gloves and try turning the opposite direction that they cut and pull outward toward you .
Feb 14, 2015 | Food Processors
My Wolfgang Puck 4 cup continuous flow food processor quit working while shredding cheese. I cleaned it all up and still it doesn't work. Did I blow a fuse? Is it repairable? I've had it for quite some...
Same thing happened to me! Placed a piece of provolone in the feeder, as Wolfgang shows on TSC, and pressed to shred. It turned about 3 times and poof! a flash occurred and the processor died. I believe there is a problem with the wiring due to overload (surprising since it was a small piece). If that's the case, whatever electronics are in this machine are probably fried. I have not brought it to a repair center because the estimate and repair will probably cost more than the machine itself. I also have the rice cooker and it is fantastic! I guess I just got a lemon.
Aug 20, 2010 | Wolfgang Puck BFPR0035CF Food Processor
I want to shredd zucchini to freeze for later use in zucchini bread. Lost manual. What blade should I use
To shred it into thin strips, use the blade with a series of holes in it. To slice, use the blade with a knife blade in it.
Sep 11, 2009 | KitchenAid KFP760 12 Cups Food Processor
10.00 bucks
have a great day
Aug 24, 2009 | Black & Decker FP1445 Food Processor
Am I missing a part
I overlooked this too. Set into the foam packing material is a stem made just for the shredding disk. It's about 4" long and also has a hex shaft. This hex is just slightly smaller than the hex on the other shaft the drives the blades. The dough hook - Remove the blade assembly and put the dough hook in its place.
Apr 08, 2009 | Black & Decker Food Processors
How to attach grating/shredding blades to GE Food Centre FP22
When you remove the regular chopper blade, it should fit on top of the stem. The chopper blade must be removed to use the slicer / shredder attachments.
Jan 05, 2009 | GE Food Processor
Black & Decker FP1400 Quick N Easy Plus Food Processor Logo
1,050 people viewed this question
Top Black & Decker Food Processors Experts
Jim Thurston
Are you a Black & Decker Food Processor Expert? Answer questions, earn points and help others
