Question about Kenmore Washing Machines
Wahing machine makes a loud banging noise
Kenmore top loading washing machine series 90 makes alot of noise as if something came loose when it spins
    Top Expert:
  • Kenmore Master
  • 35,737 Answers
This could be due to pending failure of the flexible joint beneath the tub
Posted on Jan 22, 2013
  • 113 Answers
SOURCE: kenmore 90 series loud whirring/howling noise during spin cycle
Sounds like you have a broken motor coupler. They are inexpensive. Can be a little tough to replace but I can walk you through it. You can purchase a coupler here.
http://www.shop.washermd.com/product.sc?categoryId=1&productId=1
Dave
Posted on Dec 19, 2008
  • 113 Answers
SOURCE: Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Posted on Mar 03, 2009
  • 188 Answers
SOURCE: Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
Posted on Mar 10, 2009
  • 256 Answers
SOURCE: Very loud banging noise when front load washing machine spinnning
Ensure that the appliance is balanced/level on the floor. Contact an appliance service company.
Posted on Feb 22, 2010
jsrock516
  • 5911 Answers
SOURCE: Kenmore Wahing machine model #23922 won't agitate or spin
If this is a Whirlpool manufactured TOP LOADER (such as Kenmore), an no agitation/spin problem can have several causes. Most commonly, this is caused by a broken motor coupling. The following link explains how you can diagnose the problem and repair:
http://www.fixya.com/support/r3965207-whirlpool_top_loader_no_spin_problem
I have included parts sources and instructions on how to replace any parts as well.
If this just a simple matter of the agitator not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
Whirlpool manufactured washers use a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
If the auger (top half of the agitator) is slipping, I would suspect the dogs or cam assembly need to be replaced. The part number for the dogs is included in the link I provided. For a little more you can purchase the entire cam assembly which includes the dogs, the cam, the cam seal and thrust bearing.
If the entire agitator appears loose or slipping, check the agitator bolt to ensure it is tight. DO NOT overtighten as this can restrict movement of the agitator or damage it. Tighten until snug.
Last of all, the most expensive problem that can occur, is a failed gearcase (transmission). The gearcase averages between $80 and $160 to purchase. If you wish to replace the part yourself, it is not that difficult. The following link explains how:
http://www.fixya.com/support/r3576575-replacing_a_gearcase_on_whirlpool_manufa
The procedure is rather lengthy, but not as difficult as you would think. It can save you a lot in labor charges.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need.
NOTE: I would recommend you check your agitator to ensure it is tight, followed by a check of the motor coupling. A tell-tale sign of a broken motor coupling is to look for black dust or broken plastic pieces under the wash tub. To make sure, disassembly to view the coupling if recommended. If you replace the gearcase, replace the motor coupling as well.
If you have any questions, please post back and let me know. I hope this is helpful to you.
Posted on May 14, 2010
Testimonial: "I printed out your Dec 4, 2009 post on replacing a motor coupling and am using it now. Your directions are amazing! I have the washer apart and the broken coupling off in less than 30 minutes. I took time to take pictures as I was disassembling the washer so I can remember how the screws and clips were attached in that 30 minutes too. I'm going to follow your directions on replacing the agitator dogs too. Thank you for your help!"
Kenmore Elite Oasis HT makes loud noises during spin cycle.
The tub may be unbalanced and wobbling. This may be due to washing heavy items such as rugs, towels, etc. If it is noisy with regular laundry loads, the mechanism that supports the tub may be loose or broken.
Sep 10, 2012 | Kenmore Oasis Agitator 4.5 cu. ft....
Wash machine won't spin all the time and makes a loud banging noise.
Check to make sure that your clothes are not piled to one side causing the load to be off-balance. If that does'nt fix it then, It may be that your machine has a balance stabilizer on it that has worked its way loose or even off.
Jun 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
Feb 22, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore 90 series with speed selector switch set to heavy duty cycle it works fine any other setting , regular , hand wash setting the agitator makes a loud clicking sound as it agitates
sounds like a transmition problem. does the noise happen when it goes into spin on the other settings? If no noise in the spin cycle on the other setting, then it sounds like a the gears in the transmition internally when bad for the agitation.
Jul 30, 2009 | Kenmore 15864/15862 Top Load Washer
Tub support broke
POST THE MODEL NUMBER PLEASE
Apr 16, 2009 | Kenmore 22422 Top Load Washer
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 90 series loud whirring/howling noise during spin cycle
Dave
Dec 18, 2008 | GE WBSR3140DW Top Load Washer
Kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 Series Washer Noise--Won't spin
For Tegres
If the noise is only when there is water flowing, check tighten the screws that mount the water fill solenoid valves to the case. The solenoids operate on line current so they vibrate at 60/50Hz (local suppply frequency) if they are loose at all, the noise is loud the body acts as resonators
For SRONEAL, that symptom describes coupling failure exactly, have you removed the coupling to check, often times the motor side hub is stripped, but there is no visible external damage
Jul 23, 2008 | Kenmore 15864/15862 Top Load Washer
Washing machine
This sounds like the brakes have gotten some residue on them and are grabbing way too hard. The banging is the tub stopping too fast and the torque from this makes the tub bang into the cabinet. Just one bang at the end of a spin. Is this correct???
Nov 25, 2007 | Kenmore 23012 Top Load Washer
Washing Machines Logo
145 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
