Question about Canon iR 2016i Black and White Copier
Canon ir 2018 ERROR CODE E261 - Canon iR 2016i Black and White Copier
  • 199 Answers
SOURCE: canon ir 2018 ERROR CODE E246
check print controller pcb connection, ram & EEPROM
Posted on Feb 26, 2009
iservice
  • 318 Answers
SOURCE: where is the waste cartridge for the canon ir 2018
If you open the front cover and release the leaver of the drum unit.Remove the drum unit.On the drum itself is a plastic plug,remove the plastic plug and remove the waste toner in to a bin.The waste toner is stored behind the drum and must be removed reguarly.
Posted on Dec 15, 2009
n25an
  • 622 Answers
SOURCE: canon pc940 error code e261
try turning the machine off and then on...you either had a power surge and it freaked out your machine or the fuser is shot...
Posted on Dec 17, 2009
  • 6 Answers
SOURCE: canon IR 2018 system error E007
E007 means that the fuser film inside the Fuser unit is damaged which needs to be replaced, or the white patch on the fuser film is dirty and it just needs to be cleaned. I recommend getting a canon technician to fix it,
Posted on Jun 01, 2010
hamzaskilltd
  • 316 Answers
SOURCE: error e-261
zero cross signal error
Posted on Jun 12, 2010
IR 2318. What is e261 error?
http://www.copytechnet.com/forums/canon/76193-canon-ir-2318-error-e261-dont-found-manual.html
Apr 05, 2016 | Canon Office Equipment & Supplies
How do I correct problem E261-0000 in ir 2420?
The error code is to do with the power supply, here's a brief flow chart to help you. Canon iR3300 Error Codes
Oct 11, 2014 | Office Equipment & Supplies
System error 007 for canon ir 2018
this is error for fixing film rotation. There is no reset code, you need to replace fixing film in fixing unit, Fixing unit is located under left sideway door above drum unit ( green roller ).
Call service!
Aug 26, 2011 | Canon iR 2016i Black and White Copier
E 261
have u changed the fixing unit.if yes then the code is from fusing.otherwise check the main power supply as it might not be providing supply to the fixing.If it is ok then u have replace the main board as it is not providing the control signal for fixing .
May 18, 2011 | Canon iR 2016i Black and White Copier
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
My canon is giving me an eror code. it is e000808-0001. what should i do to fix that problem?
Please tell wich copir model? Like ir2016/2018/2020....
I know that this error wants to raise up at Canon iR 2018, and It means that the fixing circuit is broken or has short circuit.
You can try to reconnect connectors of fixing assy, but in most cases I had to replace whole fixing unit.
Hope that helped
Jul 07, 2010 | Canon Office Equipment & Supplies
Canon ir 2018i copier has a error [mode setting can be made
wich error, eg. E007, E019,...
Be specific, there is a bunch of error codes for this machine.
Jun 18, 2010 | Canon imageRUNNER 2018 Copier
Canon pc940 error code e261
Dec 17, 2009 | Canon PC-940 Black and White Copier
Canon iR 2016i Black and White Copier Logo
115 people viewed this question
old marine
old marine
