Question about Ovens
Used the self cleaning electric oven and now can not use the oven the digtal shows door when bake or broil is pressed
    Sergeant:
    Champion:
  • 249 Answers
What is your model number is then we can get started to fix your problem right away
Posted on Jan 22, 2013
ginko
  • 19396 Answers
SOURCE: GE Elec oven JT952-30" blinks the "lock" after self-clean
Try unplugging power cord or trip circuit breaker, to cut the power to the appliance, then wait one or towo hours for the oven to cool down completely.
If the door stays locked, then there is a fault, probably a faulty temp probe that had blown because of high temperatures generated on self cleaning, or a defective control assembly. In that case you will need to call a technician to take apart the oven and fix the fault.
Enter model number here to find assembly diagrams and parts.
Posted on Jan 02, 2009
MY REPAIRMAN
  • 61 Answers
SOURCE: F2 displayed when using self cleaning
REPLACE THE OVEN TERMISTER PROB IT WILL FIX YOUR PROBLEM. CALL 800-614-2700 TO GET PRICE ON IT AND HAVE MODLE # REDAY
Posted on Jan 25, 2009
SOURCE: Oven will not heat up on bake broil or convection cook.
I justn encountered the same problem (Model KERS507Y). Haven't checked yet...but am suspecting the Thermal fuse. Have you solved the problem?
Posted on Apr 09, 2009
SOURCE: Kenmore Ultra bake self cleaning oven is showing code E0 - F2
My oven will not stay on, when started to preheat it will come on for a few seconds and they it will make a beeping noise and the codes E0 F2 will appear. The codes stay on even if the oven is off.
Posted on Aug 27, 2009
  • 41 Answers
SOURCE: We have a whirlpool oven model #RBS305PDB8 last
There is a design problem with certain model Whirlpool ranges where the thermal fuse blows during self-cleaning (auto-clean). This may be because of inadequate insulation, causing the outer panel to overheat. When the thermal fuse is replaced, the range will work, but it will blow the next time auto-clean is done. To safely work around the problem, the thermal fuse may be replaced with a thermostat, which will reset itself once the oven has partially cooled off. If the part number of the thermal fuse is 9759243, it will blow at 120 deg C (248 deg F). This can be replaced to a Selco Part# SES-L250 thermostat. The terminals are perpendicular (90 degrees), so they have to be bent to 30 degrees for the wires to fit behind the back panel.
Selco part# SES-L250 specs:
Surface Mount
3/4 in. disc
120/240 VAC
25 A
SPDT
open on-rise (normally closed)
open (cut-out): 250 deg F
close (cut-in): 220 deg F
temperature differential: 40 deg F
Info: http://catalog.selcoproducts.com/item/3-4-disc-thermostats/surface-mount-automatic-reset-open-on-rise/pn-5113?&seo=110
Available: Selco distributors: http://www.selcoproducts.com/distributors.php
and online at
Allied Electronics http://www.alliedelec.com
If the Selco SES-L250 'surface mount' thermostat is not available, an 'airstream type' thermostat can be used with a few differences:
1) I recommend to replace it to a 240 or 230 deg F thermostat. The reason for the lower cut-out temperature is that an 'airstream mount' thermostat will not be flush with the back panel, as is the original 250 deg F 'surface mount' one, so it may cut-out at a higher (unsafe) temperature.
2) I recommend to add Heat-sink compound between the thermostat and the sheet metal. This is used for computer processors and is available at computer and electronic component stores.
3) An 'airstream type' thermostat is thicker than the original 'surface mount' one, so longer screws will have to be obtained. The sheet metal tabs on the thermostat will bend slightly when installing.
4) The terminals are perpendicular (90 degrees), so they have to be bent to 30 degrees for the wires to fit behind the back panel.
Recommended 'airstream type' thermostats:
Supco L240
Info: http://www.supco.com/images/pdfs/2009%20HVAC%20Caralog/2009%20Catalog%20for%20Web2.pdf
Available: http://www.appliancefactoryparts.com/applianceshvac/supco/crossref/thermostats2.html
Selco SE-L240
Info: http://catalog.selcoproducts.com/item/3-4-disc-thermostats/ts-3-4-disc-se-series-airstream-mount-open-on-rise/pn-5096?&seo=110
White-Rodgers 3L01-230
Info: http://www.white-rodgers.com/wrdhom/pdfs/06_Cat_pages/Cat_06_pg0092.pdf
General Electric LS2-240
Posted on Nov 03, 2009
RBS305 replaced thermal cutoff twice and again it won't come on bake or broil
Good Evening!
The self clean feature is causing your thermal fuses to fail or open. This is a safety mechanism that when open (bad) won't allow electricity to pass through any longer. The temperature in your oven exceeds what the components in your appliance can handle. If you want your oven to last it's longest, I would discontinue using that feature. If ever the control board or keypad on your oven by way of the self clean feature, we can help you with that. Fixyourboard.com can help. Send all inquiries to info@fixyourboard.com . Thank you!
Jun 05, 2017 | Whirlpool RBS305PD Electric Single Oven
Take GE Profile Oven LOC from pannel
the control board is bad,replace it there is no sequence to rectify this problem the board is bad
Jun 17, 2012 | GE Ovens
The oven is stuck at LOC.
The locking motor has gone bad on the range. Common for this to happen after self clean. You will have to replace or have the lock assembly replaced for the stove to work again
Mar 06, 2010 | GE JKP45 Electric Double Oven
Self cleaning gas range: Bake and broil will not light up.
the thermal fuse in back is out. sometimes they are resetable
Feb 09, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
How do i turn on the bake option on the self cleaning oven?
to just turn on the bake option there should be a bake button to press as well as a self clean option and broil cycle.
Jun 21, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Thermador double oven / Bake wont work /FC code flashed once
I found I have this exact problem. Same bake preheat issue: I can bake if I set broil first. However, the oven doesn't work if I press bake first. The control board has already been replaced a couple times over the years. Is this another replacement??
Aug 30, 2008 | Thermador SC272T Electric Double Oven
Self-clean not cleaning
I was wrong (I think).  the baking element probably was burnt out as the repairman said.  He replaced it and I thought selfclean still wasn't working.  In fact, I think I just had to give the self-clean function more time.  Also, I was judging by smell.  We have become used to a bad odor during self clean which was missing when it was broken and still missing after the repair.  Bottom line, the oven was clean after the baking element was replaced, sans smell.
Apr 19, 2008 | GE Profile JTP18 Electric Single Oven
GE OVEN SINGLE ELECTRIC JKS05BW
I have the same problem. Mine is a self-cleaning oven. But I'm just preheating it 450 and it did it. Then this AM it did it while broiling.
Apr 09, 2008 | GE JKS05 Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
