Connon 1023iF Drum unit
Do you have a part number for the Drum Unit and what is the cost and best place to buy?
Thank you
  • 100 Answers
How do I replace the drum?
Nick
follow the instructions in the user manual
step 1 - purchase a replacement drum unit
step 2 if you do not have a user manual download user manual click on this link http://electronicbusinessmachines.com/wp-content/uploads/2015/04/iR-1023iF-Basic-Operation-Guide.pdf
and read page 173 to 175 replacing drum unit section 12-12 in maintance section of manual
Sep 17, 2015 | Canon imageRUNNER 1025iF
Prints are having black lines and smudges along the sides of the paper. What do i need to clean?
Unfortunately when it comes to toners and drums there isn't much that can be fixed with cleaning. It sounds like either your toner cartridge is worn or defective and spilling toner, or your drum could need replacing and therefore is acting up. To check if it's the drum, pull out the drum unit and look at the drum roller (but don't touch it!) you should see streaks or color changes on the roller in places matching where the smudges on the paper are if the drum needs to be replaced.
My bet is on the drum. Drum units are fairly easy to get a hold of, since it is a "replaceable" part of the printer. And if you can install the toner you should do fine with the drum unit as well.
Hope this helps, good luck!
Aug 18, 2010 | Canon imageRUNNER 1023iF Black and White...
Printed image repeats later
I have a Dell 5100CN, and believe that this problem is caused by the drum not releasing the full charge which holds the ink in place on the drum until the page is printed. After the image is transfered to the Drum, the 'Fuser' unit heats up the paper and pressure forces the paper against the drum to transfer the toner from the drum to the paper.
Since the Image is printing, and you are getting a ghost, I guess that the problem is most likely the 'Pressure Roller' or 'Heater' in the 'Fuser' unit.
Buying the Fuser unit from Dell could cost you around $200 from Dell, but I just found one on eBay for $129 Got to www.ebay.com and search for item number 190388919845
I highly recommend that you buy a new OEM (original Equipment Manufacturer (Genuine Dell)) 'Fuser Unit'
Good Luck
Apr 23, 2010 | Dell 3010cn Laser Printer
Inner drum lid moves into closing position but will not lock up
Hmm, this is a new one to me. If you have a certified tech near you it may be worth having them out, I would contact F/P and see if they will cover it, or at least parts, they are usually pretty good about giving customers a "freebee" once.
Jun 07, 2009 | Fisher and Paykel Fisher & Paykel Washer
Canan ir 1018 make sound
Normally nise come from the drum unit when the waste toner is too full.Remove the waste toner by removing the drum unit and remove the waste toner plug and disgard the waste toner and reinsert the drum unit.
May 18, 2009 | Canon imageRUNNER 1023iF Black and White...
Message received drum life end soon
The message means the imaging drum is going to need replacement soon. The imaging drum and toner cartridge are the two main parts that need replacement sometimes. In some printers the drum and toner cartridge are replaced in the same unit, but the Brother has separate parts. The drum is rated for a certain number of copies, so as it gets close you get the message. Replacement drums are available at big-box office places and online. An original Brother is in the $100-$150 range and generics around half that cost.
Apr 01, 2009 | Brother MFC-9440CN Laser Printer
Error message "Waste Toner Full Replace The Drum" which was replaced approximately one month ago.
Open the left cover,remove the drum.you will see on the drum unit there is plastic plugs that you can remove,remove them and remove the waste toner in the dustbin.put the plugs back and insert the drum in it's place.
Dec 04, 2008 | Canon imageRUNNER 1023iF Black and White...
Canon NP-1215
1-toner may be bad (moisture)
2-primary wire not charging - no contact or broken (unit with a thin wire above drum)
3-seperation unit shorting out (wires under the drum)
Sep 01, 2008 | Canon imageRUNNER 1023iF Black and White...
jasbo
jasbo
