Question about Maytag Neptune MAH5500B Front Load Washer
The bearings have been replaced but now it is smoking (mostly seems from the inside) and smells like the belt is burning, but the belt isn't hot. HELP!! :)
    Problem Solver:
  • 8 Answers
I think this washer has a heater with doing the bearing probably wires crosed over or damaged [heater goes on and no water smokes then ] ceck your wiring on the element green is ground.
Posted on Jan 22, 2013
4 Suggested Answers
  • 3 Answers
SOURCE: Maytag Legacy top load washer is SMOKING!
this is a bogus website that is trying to push smelly washer product....no real fixes and there are other products out there for less just use bleach first
Posted on Oct 01, 2008
  • 833 Answers
SOURCE: burning smell and smoke from motor
Sounds like the transmission is jammed.  This will cause the motor to bog and burn.
Posted on Nov 26, 2008
  • 2920 Answers
SOURCE: maytag neptune smoking
it could be the seal on the drum or it could be the belt getting too warm
Posted on Jan 12, 2009
Replacement engine warranty
Are you putting too much clothes in at once? Bad motor. It could be bad bearings causing the motor to go bad.
Dec 28, 2014 | Washing Machines
I have a steam vac spinscrub carpet cleaner works good but it just started smelling like it was burning and started to smoke
Anytime someone says they smell something burning on any type of vacuum cleaner of carpet cleaner etc. All I can think of is the belt is rubbing on plastic which would cause the sense of something burning because you possibly are smelling the belt........
Mar 12, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Dodge caravan 2001 blowing burning power steering fluid.
I can answer some of your questions without being there in person.
The smell inside the van is from fresh air entering the venting system. Not sure why you don't get it from all vents. The fresh air intake is in front of the windshield and will pick up any smells from the engine compartment.
Loosing the serpentine belt would not necessarily cause you to loose ps fluid, but having a leak could drain the pump and damage the bearings in the pump, causing the pump pulley to drag on the belt.
The ps pump could be in the final stage of failing.
And the shaft seal in the pump could be leaking fluid onto the engine and exhaust.
Feb 23, 2013 | Dodge Grand Caravan Cars & Trucks
Won't pull in dirt
you need to change belt on brush and also check for locked up bearings on brush roller and or debris lodged between brush and guard dislodge if need be or replace bearings on brush roller if they are bad
Jul 24, 2012 | Dirt Devil 12 Amp HEPA Filter Vacuum...
New balance treadmill 2500
1) see any wires is burn, and repair.
2) see if there are some electronic component burn, like resistor, capacitor etc, replace the board
3) Test the motor for burn winding.
4) Lube the deck belt , the lack produce enough friction betwen deck vs deck belt.
5) Lube the rollers bearing.
6) If you need service tech contact to www.unitedassemblers.com
see the block d
God bless you
Jul 06, 2012 | New Balance 2500 Treadmill - Free Silver...
Smells like burning rubber
sounds like a bad bearing take the belt off and see what pulley is hard to turn look for the one with dark marks on it from the belt
May 12, 2012 | Craftsman Garden
I accidently sucked up a pen cap and it stopped working then it began smoking and the belt snapped??
Take the pen cap out of where it is stuck and replace the belt. Most likely the smoke was from the belt slipping around the gear and getting hot. Did the smoke smell like burning rubber?
Oct 01, 2009 | Bissell 3576 CleanView II Bagless Upright...
97 cad sls white smoke near windshield smell like rubber burning
If its in the engine compartment there is an antifreeze leak..If it inside the car like like near to the windshield, you have a bad heater core. Good Luck contact me if you need more help.
Dec 25, 2008 | 1997 Cadillac Eldorado
Burning smell
Unlock the sweeper brushes and take them out. on each end is a cup bearing and should be free of debris.
then check around and under the belt and likely there is debris wrapped around it.
the post is getting hot as your pulling too much of a load.
though if it continues the motor may have a bad set of motor brushes (inside the motor) or bad wiring (kinda unlikely).
Apr 01, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Maytag Neptune MAH5500B Front Load Washer Logo
255 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
