Question about Whirlpool WTW4950XW Washer
Loud knocking sound
Washer makes a loud knocking sound
5 Suggested Answers
JULIANFIX
  • 975 Answers
SOURCE: Off balance/loud knocking
check the inner tub with your hands , if tub is very loose? theres a screw loose or broken at the bottom of center mast, AJ
Posted on May 14, 2008
wheelshot
  • 102 Answers
SOURCE: Loud knocking sound
You have a bad drive block. This block is located under the inner tub. A special spanner wrench is required to remove the tub. You really need to call a service tech for this repair.
Posted on Apr 16, 2009
  • 152 Answers
SOURCE: loud knocking and a loose inside aluminum drum.
One or more of your tub supports is broken. Unfortunately there is no cheap fix but wiil be cheaper than a new machine.
Posted on Mar 05, 2010
caroldon
  • 17129 Answers
SOURCE: My Whirlpool Ultimate Care II
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Posted on Jun 17, 2011
Why is my washer making loud knocking sounds?
the bearings may need to be changed
Aug 18, 2014 | Washing Machines
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
My washer is making a loud knocking noise when spinning. It is not overloaded. There is also about six inches of water in the bottom that won't seem to drain.
Hello
Loud knocking sound while spinning is usually caused due to the bearings going bad and the inner tub should also be checked. The repair is not easy and requires some time to do the replacement. Please get back to me if you have any other questions.
Kevin
Nov 07, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer makes a very loud noise at the end of
the knocking noise im used to on the maytag is typicall coming from the idler pulley. i almost sounds metal on metal and is related to the transmission. if this is the case the problem is major and my cause a tear down just to find the problem. most techs will mark this out as scrap. i hope this isnt the case for you
Aug 01, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Loud knocking and a loose inside aluminum drum.
Mar 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Knocking noice in agitation cycle
Do you get same sound if you run through a wash cycle empty (no clothes?) using detergent? If so, then likely a basket support has come loose (check deep inside along top ring). If not, then you may be overloading washer (unless using different sized loads), or the agitator is not working like it should, and basket is torquing.
Sep 15, 2009 | GE WJSR2070B Top Load Washer
Making loud knocking/clunking sound in the wash cycle.
i have the same problem. the transmission/brake assembly is worn out. the stopping and starting problem... I have that too, that was a dry solder joint on the circuit board. i found it because if I pressed on the area of the panel to the left of the cycle select knob, it would shut off immediately. I soldered it back up and it's fine. Still working on fixing the transmission problem, the parts store wants 300 bucks for the part but looking at the GE website, the tranny might be under extended warranty.
May 03, 2009 | Washing Machines
New washer, Maytag title, but RCA unit--knocks and clanks
Thank you for your complaint. It will be forwarded.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Washing Machines
Washing machine knocks in cycle
if its a whirlpool top loading washer, sounds like a bad motor coupling.( the machines equivilent to a belt.)
Oct 25, 2008 | Washing Machines
My washer machine is making a knocking sound
Try balancing the clothes evenly,if that not the problem,the balancing ring at the very top is either broken or a snap ring or rings are off.
Jan 21, 2007 | Kenmore 15864/15862 Top Load Washer
Whirlpool WTW4950XW Washer Logo
13 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
