Question about Scotsman Ice Machine, Cuber, 1930 lb. Unit, Head Only
I have a cme506as-1f scotsman ice make and the bin full light come on after a few dumps of ice and the bin is not full. What is my problem?
    Novelist:
    Champion:
  • Scotsman Expert
  • 373 Answers
Bin full sensors need to be pulled out and cleaned or replaced.
Posted on Sep 23, 2014
  • 112 Answers
SOURCE: how do i get to the sensors for full bin to clean
These units have a real problem with the bin controls. I can't begin to tell you how bad. There are two - for lack of a better term - paddles - that are basically just pushed into the left and right side of the drop area that have small lenses in them with a low level beam that when broken indicates a full bin. You have to reach in from under the bin opening and feel to the left and right, pull the paddles toward the middle and there should be enough slack on the wires to get a good hold of them and clean the lenses with a Q-tip soaked in grapefruit juice. Pop them back in and try them - if that doesn't work (and sorry but most of the time it doesn't) then they will have to be replaced.
Posted on Dec 11, 2010
  • 112 Answers
SOURCE: Bin control not responding/out of adj.Mach. #
SOURCE: scotsman EC 105 - Bin full!
change the sensor ................
Posted on May 14, 2008
TheMobilian
  • 8220 Answers
SOURCE: scotsman 500 cm3 ice machine
Remove all molex connections and check for corrosion. Clean the connections and retry.
Posted on Mar 01, 2009
  • 112 Answers
SOURCE: Should a scotsman ice machine
Yes, all ice machines have a means of automatic shut down when the bin is full. What is the model number of your machine and your bin?
Posted on Jan 04, 2011
Scotsman cme 1656 bill full stay on after cleaning
Ok did you damage the bin thermostat cap tube? The bin thermostat is what tells the unit the bin is full if so replace it.
Nov 14, 2013 | Scotsman CSW45 15" Ice Maker with 26 lb....
Cme256 scotsman
Is it dumping water or is it pouring water back into the ice bin? if it is pouring water back into ice bin than check your water float to make sure it is not calling for water also make sure the water valve is not letting water seep buy you can cut power to machine and if you here water still entering sump tray then replace water valve. if not then turn machine back on check and see it the water full light is on if so and water is still entering sump tray then replace float switch. If water full light is not on and the sump tray is full of water than remove the water sensor and clean or replace it.
Jul 10, 2013 | Kitchen Appliances - Others
Does dump valve shut off after making ice
is your bin line and dump line tied together if so it could be just ice melting. If not can you here water filling up constantly while machine is off? if so is it running over sump tray into ice bin. if dump valve was stuck open then machine will not make ice.
Jun 25, 2013 | Scotsman Kitchen Appliances - Others
How do i get to the sensors for full bin to clean cme506as-1d
Remove front cover, remove ice deflector shield, remove the plastic grate in the sump tray that keeps ice from falling into it. Now just behind the water sump tray where ice falls into bin on the right and left side are the bin full sensors you can see where the wire runs through cabinet from controller to them. grab them and pull straight out to the left and right some times you have to wiggle them while pulling. There is plenty of wire on them so you can pull them out and clean.
Mar 24, 2013 | Scotsman Cooled Modular Contour Cuber Air...
Scotsman ice machin model cme506AS-1F BIN FULL AND UNT OFF
Pull and clean bin full sensors or replace them then power unit back up.
Jun 26, 2012 | Scotsman Cooled Modular Contour Cuber Air...
Scotsman ice maker cme1356 remain on harvest
Check bin full sensors make sure that the wires are making good contact on the board and make sure they are working run your hand between them you should see the bin full light come on the board if not replace the bin full sensors. If the light comes on then replace the board.
May 25, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
How do i get to the sensors for full bin to clean them?SCOTSMAN model#cme506as
Mar 06, 2010 | Scotsman Cooled Modular Contour Cuber Air...
Bin control not responding/out of adj.Mach. # CME506AE=1A, can you steer me to a manual & part #. the unit is Scotsman ice mach. THX
Feb 01, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman 500 cm3 ice machine
Jul 17, 2008 | Scotsman Ice Maker 600LB CM3 30inW...
Scotsman Ice Machine, Cuber, 1930 lb. Unit, Head Only Logo
484 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
