White brokenline on some programs top left of screen to middle
Panasonic th 42pz80ba
Try checking in the settings menu for overscan if you turn this on it will slightly zoom in to compensate.
Posted on Jan 27, 2009
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
TH-58PZ750U Panasonic Plasma TV, problem a black bar, from the top left side of the screen (one foot from the left side), approximately 3" wide extends from the top of the screen to the middle of the...
If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window. Faulty screen-shots to plasma TVs are given. You can compare it to that of your TVs' and make sure about the fault. Details too is there.
Oct 12, 2013 | Televison & Video
Right side of screen blurry with lines-TH-42PX75U
Check the site linked below, and compare the screen shots. It has many kind of defective screen-shots to plasma displays. Compare them to that of yours, and make sure about the faulty board or others. http://electronicshelponline.blogspot.com/
May 20, 2013 | Panasonic Televison & Video
I HAVE A 50" PANASONIC PLASMA TV TURN IT ON NOW I HAVE A 3" BLACK LINE IN THE MIDDLE OF THE SCREEN THE MODEL # IS TH-50PXU
Visit this site. You will vet more details about this fault. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1100 posts to different brand TVs now. Pull up older posts there.
Nov 02, 2012 | Televison & Video
I have Panasonic TH-50PZ700U and the viewing screen is small and never goes back to full screen. Tried checking all options and none make screen go back to full
Are you sure you have tried the aspect button, usually the one top left on remote, press it and select ( with arrow buttons from auto 14.9 16.9 4.3 zoom 1 2 3 etc this will fill out screen,
pete
Nov 15, 2010 | Panasonic (TH-50PZ700U) Television
Problem with TV image, sound is OK. My Panasonic Plasma TV is a TH-42PX6U starting from the middle of the screen, the left side does not have any image, it is divided in two, with half been white and...
if you ask me the panel its dead to lose the half of the screen means no addressing logic board dead or in the most of the cases panel :( i`m not sure but if you add some images :D with signal is it the same ?
Sep 22, 2010 | Panasonic TH-42PX60U Television
My Tv Panasonic TH-42PZ80BA switched into standby 2 days ago and i cannot get it to come back on again , the red standby lights blinks in a 7 flash cycle , ive tried leaving the power off for a while but...
Yep , I cannot remember offhand but one the the internal boards has failed. The flashing code is telling us which one , will have to check SM to tell you which board but it should be under warranty , get it repaired for free.
May 05, 2009 | Panasonic TH-42PZ80B 42 in. HD-Ready...
Panasonic code
The code is 0051
on your sky remote press the TV button then
the select and Red button at the same time , hold until the led on the remote blnks twice
then press TV and enter code 0051 then press select and the remote will blink twice again to acknowledge the code
if you still have your Sky box manual all these details are in there also
im a sky engineer by the way , goodluck
Feb 15, 2009 | Panasonic TH-42PZ80B 42 in. HD-Ready...
Remote control code
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Panasonic Code: 0051
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Televison & Video Logo
165 people viewed this question
Top Televison & Video Experts
Electro Med Services...
