Question about Sony KDF-50E2000 50" HDTV
Tv turns off after 5to6 hr of use
When turned back on time that it stays on get shortre
Balboa filter circulation will not shut off. Temp OK. Not in continious mode.Contacts not stuck.
What model of balboa control do you have?
Will it come right back on after power down / power up?
Does it have a mechanical time clock?
Is temperature of water Hot?
when temp control is scaled down, will it turn off?
what do you mean - Temp ok?
If a mechanical time clock, pull the wires off of terminal 3 & 4,
isolate them! They will be HOT.
1 & 2 are for the timers internal 24 Hr. Motor.
but... First turn power off!
Turn power back on, if pump stays off, bad timer.
Apr 19, 2015 | Pool & Spa
My Olevia 37" LCD HDTV suddenly will not turn on.
power supply board is damaged,only working with standby power
Aug 15, 2011 | Olevia LT37HVS 37 in. LCD HDTV
Power doesn't turn on / don't stay on
if you think you can repair the complex of this tv you need to go back to school and learn your
abcs.ha haha
Jul 19, 2009 | Samsung LN-T4665F 46 in. LCD Television
Tv turns off randomly but turns on after 35 seconds.
How old is this TV and when did you replaced lamp last time?
Jun 09, 2009 | Panasonic Televison & Video
Shuts off after about 1 hr and then we have to power off
The TV might be on sleep mode, so it will stay on for an hour, then turn off again. You'll need to turn it off through the menu
Apr 03, 2009 | Hitachi 60SDX88B 60" Rear Projection...
Channel display for Sony WEGA KV32FS100 will not turn off
Most all Sony models use the same programming for the remotes. Borrow a Sony remote and push the display to turn it off.
Mar 23, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
TV shuts off
prob  erratic connection  on pc board finding same problem.
Nov 24, 2008 | Samsung HL-P6163W 61" TV
Clicking and buzzing when turned on takes 30min to 1 hr to come on
The fix to the black screen problem which is posted on Fixya has a pretty good chance to fix this too.If you have a soldering iron it costs less than $10 and will eventually have to be done anyway.The site has very good instructions,just follow them carefully.
Aug 27, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
TV Shuts Down
you may have vertical intermitance resold vertical ic or check connector to deflection yoke some time is intermiten..
Mar 23, 2008 | Mitsubishi VS-55707 TV
Sony KDF-50E2000 50" HDTV Logo
29 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
