Question about Fagor LFA-073 IT Dishwasher
Where is the water valve in a fagor dishwasher
Fagor lfu-65it not getting water when it starts
Fill valve or float switch may be defective
Oct 17, 2016 | Fagor Dishwashers
Fagor dishwasher not completing cycle showing f6
The heater or thermostat is faulty and not allowing the dishwasher to complete cycle as water is not getting hot enough. Try to run a cold or short cycle and see if is completed.
see explanation of fault codes in this manual.
http://www.fagor.co.uk/documents/LFU-65iT.pdf
Sep 21, 2014 | Fagor Dishwashers
Fagor dishwasher showing f6
Please check fault codes on page 70 in this manual.
F6 would mean the water is not getting heated. I am not sure which model you have but if there is only a cold water inlet connection then either heater or thermostat is faulty. If you have both hot and cold water inlet then you may have to check if hot water is getting in at right temperature. Easiest way to confirm is to run dishwasher in cold cycle (short rinse) and see if it goes through. The heater would get used in warm/ hot wash cycles and drying.
Sep 19, 2014 | Fagor Dishwashers
My Fagor dishwasher won't fill.
Check the water in-let electrovalve, could have dirt or the coil damage
Apr 30, 2014 | Fagor Dishwashers
Fagor F1-48W dishwasher won't fill
this must be a water flow problem to machine , id look real carefull at valves under sink or under floor of machine to see that there open and there are no kinks in hose connecting to it , other than that the one only other reason that it would not add water is that it thinks there's water in it already
Dec 21, 2012 | Fagor Dishwashers
Fagor lf-017s
the water level float is stuck in the "UP" position
Dec 09, 2012 | Fagor Dishwashers
Dishwasher begins cycle then switches to rinse - no water seems to be entering the washer
Most possible that the inlet line is clogged at the filter or that the inlet valve is struck or faulty.
Please make sure with a voltage check if the inlet valve receives the voltage to it, if not the program controller is faulty.
Finally check the water line pressure at the inlet.
Feb 04, 2011 | Fagor LFA086XL Dishwasher
Indicator lights say there is no water entering the machine. The pipe sounds and feels like there is water flowing but it is not getting into the machine itself
If water is flowing, then you should see water enter the DW. You should also feel the water line becoming warm or hot, depending on if metal (copper), insulated metal (copper), or plastic.
If the water valve is partially restricted due to accumulation solids in the water line, then you will need to remove and clean the valve of solids.
Dec 17, 2009 | Fagor LFA-073 IT Dishwasher
Fagor Dishwasher
ok if you have a volt meter then remove the bottom kick-plate locate the water valve take the connector off the valve set the meter to ac volts plug the leads into the connector turn the timer to fill if your getting the proper volts to the connector then replace the valve if nor reply to me
Jun 11, 2008 | Frigidaire 24 in. FDB126RB Built-in...
Beeps eight times
Correct - lack of water pressure at the dishwasher, not the same as whether there is pressure from the line going to the dishwasher. There may be a clog or a valve that is closed.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Nov 21, 2007 | Fagor LFA-65 IT Dishwasher
Fagor LFA-073 IT Dishwasher Logo
53 people viewed this question
Top Fagor Dishwashers Experts
dannydoesita
ray gallant
Are you a Fagor Dishwasher Expert? Answer questions, earn points and help others
