Question about Sunbeam SNR10TFPA Top Freezer Refrigerator
The fan in the freezer
It makes a lot of noise and it clunks when it shuts off
Freezer makes really loud noise
You need someone to check the fans and where the noise is coming from before the repair cost you a lot of money because of damage it can cause. The fan may be hitting ice in the freezer or out of balance because it is worn out. No one can hear what you hear and someone will need to be there to check these things out, Sea Breeze
Jun 10, 2013 | Frigidaire Freezers
Compressor is making very loud clunk when shutting off.
I think the wire was kinda expensive. If I were you I would try to save the fridge. I think you should unplug it for a couple hours, take everything out for a while and remove any ice. Once the fridge reached room temp, the refrigerant should have made its way back to the compressor. Plug it back in and see if it makes the noise again.
It might just be the fan in the freezer. I would try the unplug/deice for a few hour method first because it is free before you try to replace a fan that might be bumping ice. Good luck!
Mar 10, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
My Kenmore refrigerator is making a loud noise when running and when it shuts off it makes a loud clunking noise. Also, it is running about every 10 minutes. The refrigerator is 7 years old.
it sounds like the compressor insides are loose and you will be needing a new compressor, but just check and make sure the rubber mounting feet on the outer compressor base where its mounted to the refrigerator base are all tight and the rubber shocks are all good
Nov 17, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Kenmore top freezer fridge does not cool but freezer works
Turned refrigerator off for 8 hours, let the frost melt and the fan in the freezer worked again. The compressor now only has a soft clunk when it goes off.
Jan 30, 2009 | Kenmore 64823 Top Freezer Refrigerator
Freezer noise
clunk comes from the compressor - possibly dismounted or sometimes assembly inside hits casing on switch off or switch on. no cure except replace compressor
Jun 19, 2008 | Kenmore Freezers
Samsung american style fridge/freezer needs repairing
Spray a good quantity of WD-40 on the spindle of the fan motor where it enters the motor itself. This should get the fan working smoothly with no noise. This will probably solve the other problems, as the fan prevents various components from overheating and shutting down.
Apr 01, 2008 | Refrigerators
Hotpoint Fridge freezer FFA90 - Noisy fan top fridge
worthwhile checking closer. noisy fan can be due to fan blade hitting ice if there has been a build-up. otherwise needs replacing
May 07, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Amana bottom refrigerater
huthy, the fact that it's lasting 15 to 20 seconds leads me to believe that it could be one of the fan blades hitting. The valve springs on the compresser would make more of a clunk-clunk noise and wouldn't last that long. The evaporator fan in the freezer compartment has a grille that will snap on and off, clip on the bottom and tabs on the side. See if you can remove the grill and check to see if there is any ice build up around the evap. fan. The other fan, condensor is in back by the compressor, it could be hitting on the shroud upon start up or shut down. Check these things first and post back...Catriver
Mar 20, 2007 | Amana ABB1927DE Bottom Freezer...
Sunbeam SNR10TFPA Top Freezer Refrigerator Logo
14 people viewed this question
Top Sunbeam Refrigerators Experts
paul
paul
ray gallant
David Spradling
David Spradling
Are you a Sunbeam Refrigerator Expert? Answer questions, earn points and help others
