Question about Dremel 225 Flex - Shaft
Replacing the spring in the Flex shaft attachment for Dremel Model 225
Getting broken spring out of the shaft. what to use to reach it??
    Top Expert:
  • 45,428 Answers
Use a piece of wire with a right angle hook on the end Push the wire down until it is inside the spring lever sideways and pull out.
Posted on Apr 25, 2013
4 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: I have lost instructions for dremel flex shaft attachment sue
There are no manuals I have found but I have a website and phone number for them the site is Dremel.com and the toll free number is 1-800-437-3635 you can use either one to get the manual you need.
Posted on Apr 18, 2009
roadtech7
  • 297 Answers
SOURCE: How do I attach the
You remove the bit you were using and connect using existing collet, just tighten and go.
Posted on Nov 04, 2010
  • 10 Answers
SOURCE: One end of the 225
To use the flex shaft, you need to remove the bit collet. Included in the kit is a nut looking item--mine is silver. It has a square end and screws on to the end of the dremel. It is simlar to the collet, but is slightly smaller. Then you place the square end of the flex shaft into the nut and screw the shaft on to the dremel.
Hope that helps
Posted on Jan 23, 2011
Victory Motorcycle won't shift up or down
Hi, Korethadon and the usual suspects are:
1. Clutch not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return springs weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Can shift gears
http://www.victoryforums.com/archive/index.php/t-3586.html
MediaFire
Motorcycle Service Parts Part Finder Victory Motorcycles Store
Owners Manuals Victory Motorcycle
Jun 18, 2017 | Victory Motorcycles
Why won't my Gamo big cat not **** when I fold barrel.
The three reasons that stop a springer cocking are
1 main spring has broken and stopping the piston reaching the trigger sear and engaging . remove spring to check
2 trigger is jammed and not allowing engagement of sear or trigger unit is broken (may be a spring broken easy fix )
3 piston engagement slot damaged broken ( replace piston)
If it is trigger wear problems think about getting it repaired or replaced depending on length of time owned
Apr 05, 2015 | Gamo Optics
Revs to high
The throttle plate is spring loaded to pull wide open, opposed by the governor which will pull the throttle closer to closed when the limited or specified rpms are reached. If the governor arm does is not connected to the throttle bell crank(linkage broken, off, or missing), it can't pull the throttle closed. If the arm does not move to close the throttle, the governor is likely broken inside the crankcase. or needs adjustment. The internals are a spool that moves based on rpm, pulled up by flyweights that has the external governor arm shaft 'trapped' in between the spool 'ends'. The spool will move the shaft and in turning, move the arm to pull the throttle closed. You adjust the arm on the shaft so the governor can pull the throttle completely closed with all the slack taken up.
Mar 14, 2014 | Garden
94 cbr1000F will not shift into 6th gear
Hi, Anonymous and the usual suspects are:
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Where is my 6th gear CBR Forum Enthusiast forums for Honda CBR Owners
6th gear blown
Honda CBR1000f Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CBR1000F Owner Manual
Dec 20, 2013 | 1994 Honda CBR 1000 F
Shifter Not returning to start postion after shifting gears.
If the shifter is not returning to it's "center" position, the shifter pawl spring is probably broken in the transmission. With the engine off and the bike on the kickstand with the transmission in neutral, gently depress the shifter lever down until just before it shifts. Then, let go of the shifter and see if it springs back up. Do the same thing lifting the shifter towards second gear. Make sure there is no binding in the linkage. If you don't feel the spring pressure on the shifter, this is an indication that the return spring is broken. Harley had a problem with this on their 5-speed transmissions. Fixing the problem is a major job. You have to disassemble the entire primary drive and pull the trapdoor with both transmission shafts out of the transmission to get the shifter pawl shaft out. I strongly recommend the purchase of a service manual if you plan on doing this job yourself.
Good Luck
Steve
May 20, 2011 | Harley Davidson XL 1200 C Sportster Custom...
The flash is spring loaded and does not fully open when the release button is pushed. Must be manually held in upper position in order for the flash to work. Help me fix it
The Spring mount breaks in the flash and loses tension.
Anyway if you are brave and handy you CAN fix this.
First remove the back of the camera - 3 screws in battery bay, 1 in the side above the memory card door, The two rear most on the bottom, two in the USB/video door, and the rear most on the left hand carry strap bracket.
Carefully prise the back rearward about 5 to 8 mm.
Now take a look at the two screw holes under the flash (when popped - or flopped out now that is broken) now go and bend a screwdriver of the type you used for the previous screws - you will need a 90 degree bend very close to the tip to fit in this gap and be able to turn the screws a few degrees at at time.
A little at a time lock the screwdriver into the screws and undo until the flash cover comes off.
You can then slide the shaft out of the flash to release the spring which will have the end that should fit into the broken bracket now sitting proud..
Make a suitable U shaped bracket that will slide over the broken plastic bracket and drill a tiny hole in the side where the spring will clip in.
make sure it fits really well and then epoxy into position.
Getting the spring back in is a fiddly job - I found the best way was to fit the end of the spring into the new bracket, slide the shaft just into the spring - the lever the other end of the spring down into the back of the flash body and then slide the shaft all the way into place.
I did have to file down the little plastic "blade" inside the lid which presumably is designed to assist the the (now broken) bracket from breaking....
reverse the dis-assembly and now you should have a working flash
Oct 25, 2010 | Fuji FinePix S700 Digital Camera
I have a broken rear spring on the strut. can i just replace the springs without replacing the strut?
yes, must not let the strut shaft turn or you can unscrew the shaft from the piston internally resulting in a failed strut. Depending on miles it is probally better idea to replace strut and mount as these are common failures along with broken spring.
Mar 01, 2010 | 2000 Ford Taurus
My 125dt dosent sart or kick sart,the gear inside have a bushing in shafting?or it was broken..
Common cause of kickstarter not engaging(I am guesing that this is your problem) is a broken spring on the kickstart mechanism,or that the kickstart idler gear cerclip has fallen off(this allows the idler gear to move forward on the shaft & thus won't allow the kickstart gear to transfer drive to the clutch hub).Remove clutch cover, put kickstart lever back on shaft spline,activate kickstart lever by hand(easier with sparkplug removed+in neautral)as kickstart lever moves down 90 degrees the gear on the kickstarter mechanism should move out to engage with gear next to it(kickstart idler gear).If the gear on the kickstarter mechanism dosn't move outward it has a broken spring on the kickstart mechanism.replace spring and all should work.(if the spring is broken you need to try find the broken piece with a magnetic pick-up tool as the broken part can cause further damage if not removed)To do this job I highly recommend you first purchase a workshop manual which will guide you through these processes.After all a manual is the most valuable tool in your tool kit.
Nov 17, 2009 | 2003 Yamaha YZ 125
Dremel 225 Flex - Shaft Logo
213 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
