Question about EnGenius ERB9250 300Mbps Wireless N Range Extender
How to open erb9250
I need to open the case of the erb9250 to find out what's rattleing around in it and fix it if possible.
  • Joe Baker Jan 22, 2013
    Thanks, I didn't see the screw hidden under the UPC lable!
    Genius:
  • 1,669 Answers
Just unscrew it from the bottom to take a look-see!
Posted on Jan 22, 2013
Lost setup disc download
You don't need a disk. You can set it up from your web browser, something like http://192.168.1.2/
http://www.engeniustech.com/resources/ERB9250%20Quick-Start%20Guide%20_Oct%207%202010%20release.pdf
Sep 15, 2013 | EnGenius ERB9250 300Mbps Wireless N Range...
Rattle when decelerating or sometimes in idle
you need to be very cautious as this culd very easily be mistaken for a loose rod insert...around 2200 rpm hold the idle steady and see if you here a rattle. Then do it again increase slightly then decrease slightly...if you still here it, its possible an insert has came loose from oil run too low or high mileage wear and tare on the crankshaft..if you love it fix it if you dont trade it quickly...GOD bless
Sep 18, 2017 | Nissan Cars & Trucks
My bobbin is rattling around in the case and making a terrible noise. I have cleaned the casing and made sure I've put it back correctly and I'm using the correct bobbin - help!
try a different bobbin
if changing the bobbin doesn't help then the hook and hook race
needs to be checked to see if there is a problem with them
Dec 16, 2012 | Sewing Machines
Clutch noise on cb750
Sounds like possibly the clutch pressure plate retaining bolts have loosened off. If that's the problem, then you'll have to open the case and re torque the pressure plate. May as well inspect the plates and discs while you're there.
Jan 13, 2012 | Honda CB 750 Motorcycles
My subwoofer distorts/rattles. the amp isnt the problem and the wiring was done correctly. maybe the sub is blown? can anyone help me? does anyone know how to fix it? if so can the walk me through it or...
If it distorts and rattles, chances are high that the woofer has blown, which usually means the wiring around the cone overheated or the cone itself hyper-extended. In either case, it would have caused irrepairable damage.
To my knowledge, it cannot be repaired. In this case, I hope I'm wrong...
Best of luck!
Jul 13, 2011 | Car Audio & Video
Ineed setting of EnGenius ERB9250 300Mbps Wireless N Range Extender
Hello, here is the manual for the ERB9250: http://www.engeniustech.com/resources/manual_ERB9250.pdf It will show you how to access all of the settings you need.
Mar 05, 2011 | EnGenius ERB9250 300Mbps Wireless N Range...
Transfer case making roaring rattling sound
it's possible you might need to just change the trans case fluid.... it's a pretty simple task, i usually do all the small minor work first before i take it to a dealer to fix.... if they said you need a new trans case, but didn't tell you why, more than likely there might be something you could do yourself to make it better... those service men have been working around vehicles long enough, they should be able to tell you exactly what's wrong!
i would also do a tranny fluid change to... some of the noise could be coming from there too -- when you change either fluid, add a little lucas transmission fluid stabilizer, it helps alot with seals and makes the fluid stick to the gears better...
Jan 15, 2009 | 1995 Chevrolet C1500
Open Questions:
See all EnGenius ERB9250 300Mbps Wireless N Range Extender Questions
EnGenius ERB9250 300Mbps Wireless N Range Extender Logo
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
