Question about Moore Medical Blood Pressure Kit W/ Sprauge Stethoscope Adult 22" Blue
Calibration of the sphygmomanometer
Several of our Moore BP sphygmomanometer's are no longer calibrated. Does anyone know how to calibrate these? Moore's customer service was unable to help.
  • 74 Answers
Unscrew the silver ring from around the dial face. Lift off the clear cover. Gently pull the needle off the pin. Re-align needle. Gently push the needle back on to the pin taking care not to push to hard or bend the needle. I hope this corrects your problem.
Posted on Feb 02, 2009
  • r321567499
    r321567499 Feb 02, 2009
    see previous info sent
  • JANETH PALIGAN Jan 23, 2013
    does your agency issue certificate of calibration if you will calibrate our sphygmomanometer? thank you
What? i thought one had to use calipers to turn the two pinholes where the rubber tubing attaches, the turn the thing it plugs into. been a long time, but i was told not to move the needle...
Posted on Jul 08, 2010
For Needles that won't come off. Use the same instructions as above until you get to the needle removal. Instead place small sharp object in center to stabilize it and gentle push/slide needle to zero. Tacks usually work as the small sharp object.
Posted on Mar 12, 2009
  • 1,886 Answers
The spring for recoil in a mechanical pointer will over time lose its force, therefore, the needle will no longer continue to identify in place by an overpressure generated offset, there is a deformation caused to the spring and across the board are going to give a different resultant force on mechanical progress, changing the pointer would only since can eliminate the evil, but keep in mind that the measurement at some points now may differ because of different operating point in the mechanics. but its in this case maybe negligible but beware on some medical meters its very important the mechanical indicators can vary greatly in repositioning of a needle pointer.
Posted on Oct 23, 2016
    New Friend:
To adjust needle to zero: If the adjustment screw cannot be found on the outside, remove the tubing from the meter. Insert a small screwdriver into the barb until you feel resistance. Gently turn the screwdriver until it meshes with the screw. Turn to adjust the needle back to zero
To check calibration/accuracy: Use a "T" connector to hook up a known accurate meter into the system and compare the readings. If they match, great. If not, the meter needs to be returned to the manufacturer.
Posted on Feb 23, 2014
Calibration tools are available. the cheapest i've seen online is $25...or, take it to your medical supply store. most will cvalibrate it for free or just a small fee.
Posted on Feb 26, 2012
Need Calibration services in Australia. Can anyone help?
Yes!
I know one of the best and reliable Calibration Services providers in Australia who is serving multiple industries since a long time.
They provide a large range of calibration facilities with on-site calibration service.
Their major services include dimensional, electric, and mechanical calibration at much cheaper rates.
Oct 11, 2017 | In Office Equipment & Supplies
How to set the date and time and calibrate monitor for 01-540
Google (brand)(01-540)(manual) without parens
Nov 08, 2016 | Health & Beauty
Eck troubleshooting i need person who can repair this.
Generally, the manufacturer of the BP Monitor offers repair service for their products. Best advice, contact their Customer Service Dept. The number should be in your Owner's Manual. If it's still under warranty, it should cost you nothing for the repair. You may only have to pay the shipping cost to the manufacturer Also, because the unit will need to be re-calibrated after any repairs or made, only the manufacture can do that. Because they have to certify the calibration is accurate.
Hope this helps you .
Jun 17, 2011 | Health & Beauty
Can not open sphygmomanometer to calibrate
Remove the tubing and insert a screwdriver into the barb.
Oct 27, 2010 | Moore Medical Blood Pressure Kit W/...
We need to recalabrate the sphygmomanometer...how do we do that?
Hi mindy_blu
thats the problem with sphygmomanometer, however you may try this. open the glass part then try to re align the hand of the manometer. this will then calibrate your manometer.
Thanks
banaple
Aug 30, 2010 | Mabis Aneroid Sphygmomanometer, Large...
Where do I get my omron bp monitor calibrated
I assume you mean checked for accuracy - something that you should do every two years. I assume you live in Canada or the US, if so please contact OMRON at the number below. They will be able to direct you to a service centre near you.
CONSUMER SUPPORT TOLL FREE NUMBER: 1-877-216-1333
Customer Service Representatives are available
Monday through Friday - 8:30am to 4:30pm CT
Apr 27, 2010 | Omron Automatic Blood Pressure Monitor w/...
Sphygmomanometer is settled at 190 and the pin wont calibrate no matter what i try.
It needs a service, but it would be better to throw it away and buy an electronic one. The one you have is notoriously inaccurate. The new electronic ones are cheap, very accurate and calibrate themselves.
Jan 03, 2010 | Moore Medical Blood Pressure Kit W/...
Blood pressure reading 150/76. Manual Blood pressure 130/72
A monitor using Hg is only a valid monitor reading. Most electronic devices produce approximate results and are mostly good for taking several readings daily and obtaining a mean daily BP. Device calibration appears to be not accessible to the the user.Also, depending on age & condition of your dad, sequential reading must take place after elapse of enough time for circulation to be at steady state in the arm again, or if you immediately after a measurement make another, even with the same monitor you will obtain a different result.
Mar 23, 2009 | Health & Beauty
Sphygmomanometer
most likely when you dropped it on the concrete floor the compact of it hitting the floor has either jarred something on the inside of it and has caused it to not work properly or find the papers to the machine and restart the directions for it. i hope that something i have said may work, good luck!
Jan 07, 2009 | Medline Industries Medline Manual Digital...
Moore Medical Blood Pressure Kit W/ Sprauge Stethoscope Adult 22" Blue Logo
7,184 people viewed this question
Top Moore Medical Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Moore Medical Health and Beauty Expert? Answer questions, earn points and help others
