Question about Olympus W-10 Digital Voice Recorder
Camera does not work
W-10 digital recorder ,s camera does not properly
Takes only 10 pictures then indicates that internal memory is full, has new sd cardbut no pictures will record. everything else works fine
You need to get rid of the pictures in the internal memory. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions. Then, your card should work properly.
Dec 06, 2010 | Emprex DSC5100Z Digital Camera
My flip video camera was working properly then after i recorded some footage it will not sync to the computer anymore. When i try to plug it in it asks if i want to scan and fix the camera but the camera...
The battery may be defective (corrupt). It is not uncommon for rechargeable batteries to go bad, even fairy new ones. You could try a camera reset:
Hold the power button down for 10 seconds
Check and see if the camera has unfrozen
Power the camera off and leave untouched for about 15 seconds.
Turn the camera back on and ensure that it is working properly.
If it is not, you must do a "hard reset."
Take a pin or the point of a thumbtack and press it into the tiny reset hole near the camera's tripod mount. This should reset the camera without affecting any of the video footage recorded with the camera.
If that still doesn't work, contact Flip (Pure Digital) Tech support or replace battery.
Regards,
Maxwell,
Jun 19, 2010 | Pure Digital Flip Video Ultra Camcorder
My FujiFilm Finepix JV100 isn't recording the amount of time it's suppose to. It's on HD mode and it stops around 40 seconds of recording. I tried the other options and they work just fine. Thank you for...
You only use the internal memory (24MB). Internal memory only records 41sec. Please check the settings. If HD records are recorded to internal memory.
Apr 15, 2010 | FUJIFILM FinePix JV100 Digital Camera
My Panasonic pv-gs180 doesn't record.
If you have Head Cleaning Cassette play it at 10 seconds or use new Cassette for 10 minutes play or record. Otherwise Video Head damage
Mar 10, 2010 | Panasonic PV-GS180 Mini DV Digital...
The video only records for about 10 seconds, although the "REC" is showing.
It happens with my digital camera when the battery is low. It doesn't let me record a movie more than a few seconds. I just charge or replace the batteries with a new ones and works fine.
Also, check the memory available on your camera.
Sep 08, 2009 | Sanyo Xacti VPC-S60 Digital Camera
Proper cleaning of old vinyl record albums
Get yourself a nice carbon fiber brush. Purchase some record cleaner or just get some isopropyl alcohol 90% (it has less impurities). Secure the arm of the turntable so you don't scratch the record and put the record on it. Put some of the cleaning solution on the brush..not the record. Put the brush on the record and turn the platter counter clockwise to work the dirt loose. Check the brush and clean it if need be and repeat. Take the record off and clean the turntable. Flip the record over and repeat the cleaning process. That should do it. Thanks for stopping by and come back if you need more help. If you don't mind, rate my answer appropriately. Thanks.
Jan 19, 2009 | Vivitar ViviCam 10 Digital Camera
Problem with sony dsc p92 - operation and battery life
try to switch to rechargeable Ni-MH batteries, i'm not sure it supposed to work properly with Alkaline, that's why Sony supplied battery charger and their Stamina batteries with this camera
Aug 16, 2007 | Sony Cyber-Shot DSC-P92 Digital Camera
Samsungscd23/blank viewscreen for photo memory stick
My advice is that you should by a DV cleaning cassette. Put this in the camera and run it for 10 to 20 seconds only. running the cleaning cassette for a long time may damage the head.
good luck!
Luwangula
Aug 01, 2007 | Samsung SC-D23 Mini DV Digital Camcorder
Olympus W-10 Digital Voice Recorder Logo
18 people viewed this question
Top Olympus Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
