Question about Toshiba 50HX81 50" Rear Projection Television
Toshiba 50HX81 projection 'tv- blinking red light
Red power LED light blinks off and on continously. The blinking is not intermittent or patterned. TV does not turn on, when plugged in makes a click in the rear of the tv, then the light starts blinking. TV is 7 years old.
  • 3 more comments
  • cvcduty Feb 11, 2009
    I have this same problem. It worked fine last night but this morning, I am faced with a blinking red light and nothing on the screen... What's going on?
  • Anonymous Feb 17, 2009
    i have the same problem no picture no sound. just blinking red light. it sounds normal when you turn it on but then nothing happens
  • Anonymous Mar 01, 2009
    Why hasn't anyone solved this issue yet?
  • Anonymous Mar 08, 2009
    same problem, blinking power button, no picture. Is it worth evenb trying to fix the TV or just donate it/junk it?
  • Anonymous Apr 18, 2009
    yep, I,m wachink a red blinking light instead of American Idol. What is wrong with this TV?
  • Toshiba Master
  • 19,396 Answers
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
Yellow blinking light on toshiba tv
http://aaaateva.com/tv-repair/tv-brands-serviced/toshiba-tv-repair/toshiba-tv-codes
the color and blink pattern of your tv led is a code that gives you the fault...check at the site above.
Jul 05, 2015 | Toshiba 65HM167 65" Projection Television
Green led indicator light is off on my 62" toshiba
when you turn it off your light blinks because your internal fans are still spinning allowing the inside of the chassis to cool off, hence the reason you dont watch a DLP TV and then unplug it. DLP's are JUNK
Dec 01, 2010 | Toshiba 62HMX84 62" Rear Projection HDTV
Toshiba 57h81 red light blinking
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 14, 2017 | Toshiba 57H81 57" Rear Projection...
Toshiba 50hx81 power light just blinks
Go to Powered Products List view all in my profile and read
Toshiba entries........Let me know how it is going.........T.
Mar 15, 2008 | Toshiba 50HX81 50" Rear Projection...
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
Toshiba 50
1) Blown fuse ( soldered in) = caused by bad solder connects.
2) For repair = pull chassis, solder connects,replace fuse
3) Replace convergence IC's ( possibly damaged)
4) Re-assemble,test
Oct 22, 2007 | Toshiba 50HX81 50" Rear Projection...
Red power light keeps blinking and wont come on
The first thing to try is to unplug the unit from the wall for about 15 minutes,if this does not work you will need the assistance of a servicer to diagnose the problem,if you are familiar with tv service you can check the horizontal output transistor for a short,sometimes it fails for no reason and other times it goes bad along with the horizontal output transformer also know as flyback.Be careful if you decide to check this yourself.
Oct 02, 2006 | Toshiba 50HX81 50" Rear Projection...
My TV will not come on but the power button blinks red!
Very interesting. I have a Toshiba 53 H71. Same issue. It occurred to me after a move.. No one has offered any help on it. Posted about a week ago. Guess no one knows anything about these TV's....
Sep 02, 2006 | Toshiba 50HX81 50" Rear Projection...
Toshiba 50HX81 50" Rear Projection Television Logo
2,194 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
