Question about Sony VAIO Computers & Internet
I have a Sony vaio PCG 5K7P, and it's not getting started...when I switch it on...only the fan works and the lights on wifi and the charger are working....no display on the screen and no processor
No display
  • Sony Master
  • 5,660 Answers
Laptop on, shine a flashlight at the LCD screen at various angles.
If you see a faint image the problem is the Backlight, or screen Inverter.
90 PERCENT OF THE TIME the fault can be attributed to a bad screen Inverter.
(IF the laptop uses a screen Inverter.
CCFL backlighting uses a screen Inverter.
LED backlighting may, or may Not use a screen Inverter)
No faint images?
See if the problem is the graphics chipset, or Video Cable, or inside the Display Assembly.
Graphics chipset:
Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port, on the laptop.
This is an example of a VGA Cable, and VGA connector, (port),
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down a little for cable example.
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
Turn the monitor on. If a CRT type of monitor allow it to warm up.
Turn the laptop on.
By factory default settings, the display should show on the external VGA monitor.
IF not;
There are at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Hold the Fn key down, and at the same time tap once on the F8 key. (The F8 key is the Display Toggle-Over key)
Still no display on external VGA monitor?
Hold the Fn key down again, and tap once more on the F8 key.
No display on external monitor, suggests a problem with the graphics chipset.
Most of the time the graphics chipset itself isn't the problem.
It is due to inadequate cooling for the graphics chipset, and this causes a problem with the MOUNTING, of the graphics chipset TO motherboard. (BGA surface mount)
If this is found to be the problem I will go into more detail.
I don't believe that is your problem, but there is NO guessing here.
We are following a diagnostic flowchart.
Good graphics on the external VGA monitor, means there is a problem with the Video Cable, or inside the Display Assembly.
A) Video Cable connections can be loose.
Connection at motherboard side, or connection of small cable to screen Inverter from Video Cable, (IF it uses a screen Inverter), or connection at back of LCD screen.
A LOT of times a loose connection can cause what you are seeing.
Video Cable could be damaged. Wires inside stretched/broken.
Inside the Display Assembly:
Video Cable checks out after a continuity test, then the screen Inverter is next in the diagnosis. (IF a screen Inverter is used)
Screen Inverter proves to be good, the problem is the LCD screen.
NO screen Inverter is used, the problem is the LCD screen.
Sony drives me crazy with their model numbering system.
What is the other model number on the bottom of the laptop?
Start with a VGN?
Post back in a Comment.
Once I have a model number I can deal with, I will post back with step by step info, and additional manual information.
(Service Manual. Perhaps pictorial guides, and video/s)
Regards,
joecoolvette
[Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
The I.C., or chipset for graphics, is the graphics chipset; or more properly known as the G.P.U.
Graphics Processing Unit,
http://en.wikipedia.org/wiki/GPU
Posted on Jan 22, 2013
  • 44 Answers
SOURCE: Sony Vaio not Booting
Have you tried booting with a windows cd, and then running a disk check?
Posted on Dec 18, 2007
  • 238 Answers
SOURCE: Sony Vaio PCG-K86P laptop
hi, the problem seems with the RAM, remove and clean the contacts with an rubber/easer, this should fix ur problem,let me know
Posted on Dec 20, 2007
luis356
  • 53 Answers
SOURCE: DRIVERS
go to this URL:
http://esupport.sony.com/perl/select-system.pl?DIRECTOR=DRIVER&PRODTYPE=1,24,26,66,9,70,5,72&template_id=1&region_id=1
look for the driver you need by model number.
Posted on Jun 03, 2009
SOURCE: I want to Down DRIVERS for Sony VAIO Version PCG-7L1M
jshajhva
Posted on Jul 22, 2009
bob_computer
  • 3153 Answers
SOURCE: the fan of my sony vaio model pcg 3c2l stops
Only do this if you feel competent in doing so.
Pulling apart laptops is not for the faint of heart.
If you really must do it there are some
good guides here
An alternative is to get a can of compressed air used to clean computers. Put the nozzle on and spray it in every hole you can see without putting the nozzle itself inside the laptop.
Do this outside with glasses on.
You may also want to remove the hard drive and ROM drive.
Take a
peek here for more ideas of what is involved.
There are a few are tips for various things in there.
DON'T touch the CPU cooler unless you know what you are doing and have some thermal grease for CPUs to hand.
To make newer laptops last longer between cleaning a good 3 fan cooling pad is suggested.
never use a laptop on soft surfaces as the ventilation can act as a mini vacuum cleaner and encourage dirt build up.
Soft surfaces also block the vents causing fans to run more and burn out sooner.
Hope this gives you the information you need
Bob
Moderator
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
Posted on Dec 13, 2009
Stop one mac screen from becoming multiple screens
Mirroring displays the same image on each display.
  1. Make sure your additional display is properly connected and powered on.
  2. From the Apple (?) menu, choose System Preferences.
  3. From the View menu, choose Displays.
  4. Click the Arrangement tab.
  5. Enable (check) "Mirror Displays" in the bottom-left corner.
In the example below. the blue boxes represent each display that is connected. The white bar at the top of both boxes represents your menu bar and is shown on both displays when they are showing the same information.
When mirroring, your Mac attempts to match the closest resolution between the primary (or built-in) and secondary displays.
The usable resolution is the closest matching resolution for both the primary and secondary display. If you choose a resolution that is not supported on both displays, OS X reverts to using the closest matching resolution.
Extended desktop With extended desktop, your displays are treated as one, continuous desktop.
  1. Make sure each display is properly connected and powered on.
  5. Disable (uncheck) "Mirror Displays".
In the Displays pane of System Preferences, each blue box represents a display that is currently connected. The size of each box is relative to the current resolution of the display it represents. In the example pictured below, the larger box on the left represents an Apple 27" Thunderbolt Display, while the smaller box on the right is the built-in display of a 13" MacBook Air (Color LCD).
The white bar at the top of the left blue box represents the menu bar you see at the top of your display. Menu bar placement determines which display is treated as the primary display in OS X. To change your primary display, click and drag the white bar from one blue box to another.
You can also drag any of the blue boxes to change a display's represented location. Use this feature to make sure the connected displays match their real world location when navigating your desktop.
As shown below, each display retains its maximum resolution setting as they are operating as individual displays showing a continuous desktop.
lion_choose_max_resolution_.pngPress Command-F1 to toggle between video mirroring and extended desktop
Press Command-F2 to detect displays
May 01, 2014 | Apple 24" iMac Desktop
Tip
Here is how to connect your Windows 7 installed notebook to an external display
Most of the notebooks that were manufactured in the past two-three years come with a HDMI port along with the old VGA port to connect your computer to an external display. Connecting and activating an external display on a Windows 7 machine is pretty simple.
Here is how to connect your Windows 7 installed notebook to an external display:
1. Connect your Windows 7 laptop to the external display using VGA or HDMI cable.
2. Then, switch on your Windows 7 laptop and also the external display.
3. Once Windows 7 is up and running, type Mobility Center in Start menu search area and hit enter to open the same.
4. If you have connected your Windows 7 machine to the external display properly, you should now see Display connected text under External display section of Windows Mobility Center. To use the connected external display, click Connect Display button. You should now see your Windows 7 desktop in the external display as well.
5. Use disconnect button in the Windows Mobility Center to disconnect the external display. When the display is connected and active, use Windows + P keys to quickly switch between these displays
on Jun 18, 2010 | Computers & Internet
Tip
How to connect Laptop to an External Monitor?
5. Use disconnect button in the Windows Mobility Center to disconnect the external display. When the display is connected and active, use Windows + P keys to quickly switch between these displays.
on Jun 14, 2010 | Computers & Internet
Drivers sony pcgfr77g/b filehappo
Since this laptop is not a newer laptop, and it is a Japan laptop, it is not easy to locate the original driver.
http://www.vaio.sony.co.jp/Products/PCG-FR77G/lineup.html
If you can provide the details info of the VGA component, then we can locate the same component from other brand name laptop (probably driver from HP or Dell will work). You can do this to get the details info:
Control Panel, System, Device Manager, [Component Name], [VGA], [Right click], Properties, Details tab, Property pull down; chose Hardware Ids and write down the VEN and the DEV sections in the Value's box (including the VEN and the DEV words)
Feb 15, 2014 | Sony Vaio PCG-FR77G/B Laptop Charger...
Cooling fan stopped working
any 18-20 volt laptop charger should work only need correct power plug and that can be easily changed if necessary with soldering iron and volt meter. using old charger plug as replacement. volt meter is used to check out correct polarity of plug before and after you re solder plug on.generally outside is -ve and center is +ve ,alternatively go to ebay or google and type in Sony Vaio PCG 7Q1M charger,or type in part number ,or try 18-20v laptop charger, that is what I do when I need a replacement charger,cost around $10 delivered usually.
Jan 04, 2014 | Sony Vaio PCG 7Q1M Laptop Universal AC...
My Sony pcg-9c1l won't turn on!! When I press the
Could be your adapter, adapter socket - most common issues.
AC ADAPTER CHARGER POWER FOR SONY VAIO PCG 9C1L PCG 9D1L VPCCW14FX... Test your power adapter with a multi-meter. Example below
Hope this works to help you and your situation.
Mar 11, 2012 | Sony Computers & Internet
Samsung GT-e2152 Display white problem solution
Samsung E2152 display thik hai par graphics nahi aa raha hai. display white aa raha hai
Jan 23, 2012 | Samsung Cell Phones
Computers & Internet Logo
341 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
