Question about Transmission & Drivetrain for Ford E-350 Super Duty Length XLT
Cable linkage needs adjusting
Does not line up with gear
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 45 Answers
It is the wrong cable or you put the bracket into the wrong set of holes on the transmission
Posted on Jun 01, 2014
How do i set up new gear linkage on renault traffic
After fitting the cables! You need to adjust the GATE cable as each gearbox has slightly different wear... One cable selects the gears.. The other is responsible for the smooth gear selection! Sounds like your out of line mate! Theres an adjustable thread on the GATE cable! Keep adjusting til it selects smoothly! JOB DONE SAAAAAAN!! :-)
Sep 27, 2016 | Renault Cars & Trucks
Seems like it engages in gear fine but will not go in 2 wheel drive. but does fine in 4. Could something be wrong with tranny or just a bad rear end?
check linkage or cable at transfer case, it may need adjusting. if not.its the transfer case that needs attention. check all lines to transfer case. God-Bless! The vacuum lines from engine if needed.
Apr 24, 2016 | Dodge Ramcharger Cars & Trucks
Transmission linkage adjustment
There is a linkage arm connected on the outside of the transmission that has a cable that runs up into the steering column and connects to the gear selector armature. The cable could be stretched, broke, or the gear selector actuator could be worn. You will need a good service manual to troubleshoot what may be the problem.
Jun 30, 2015 | Ford F-150 Cars & Trucks
No 1st gear
adjust the linkage from gear stick to your gear box .
Dec 18, 2013 | 1997 Ford Escort
1991 Ford F150 won't shift into park or reverse. Will go into neutral and drive, and the linkage at the transmission moves ok
The linkage may be out of adjustment preventing the shifter from moving into reverse or park.
One way to test this is to disconnect the linkage and manually move the lever on the transmision making sure that it can be set into park. Also try moving the lever counting each click from park to low gear to make sure it is clicking into each gear. If this works then the linkage is probably out of adjustment.
On the link cable there is typically a bolt in an oval shaped metal near the transmission shift lever.
1)Detach the shift cable from the transmission shift lever
2)Put the transmision shift lever in the park position, and also the shifter in the cab
3)Loosen the adjustment bolt
4)Reattach the cable to the lever
5)Tighten the adjustment bolt in place
6)Confirm that you can shift through all of the gears
Hope this helps
Dec 01, 2013 | 1993 Ford F150 SuperCab
Gear shifter cable
sounds like a stretched gear shift cable or the linkage on the tranny may need some adjusting i would start with the linkage first jack vehicle up and do a visual while some one goes through the gears make sure to use jack stands so that the power wheels are off the ground.....good luck
Nov 09, 2013 | Nissan 200SX Cars & Trucks
I have a 2003 dodge neon SE 2.0 liter L4 SFI SOHC 16V, 4 dr sedan. my problem is that the car will not go into gear or move at all. it still starts and runs great it just wont catch gears and move. Could...
if it was the neutral safety switch it more than likely wouldn`t start at all or start when without pushing on the clutch.it sounds more like the linkage could be damaged(think these are cable) or its out of adjustment and needs adjusting.does it feel like its going into gear(like it does when working) but not engaging if so it could be a problem with the transmission.first have the linkage checked out.
Aug 12, 2011 | 2003 Dodge Neon
I need to find out how to adjust my shifting linkage for a 1988 mercury mariner 60 hp. i don't have a diagram
Its not too bad to adjust, just takes patience and an assistant would be nice. You want to center the linkage in neutral so the throttle does not move immediately when you shift.
This can be adjusted with the motor off. You need to try it first by putting the Handshift in neutral and spinning the prop by hand. The prop should spin without locking into gear or making a "ticking noise" with the gears partially meshing. If there is a "ticking noise" you need to disconnect the shift cable; adjust it until the noise is gone. Then reattach it.
Now have your assistant move the Hand Throttle slightly forward, the gears should make a "ticking sound" before the throttle cable moves, and the gears should lock into forward before the throttle cable moves. If the Throttle cable moves too soon, you want to disconnect the Throttle cable and turn the knurled fitting to return the Throttle cable to a closed position. Easy does it with these adjustments.
If you go too far while adjusting the Forward gear it can show up on Reverse. But remember, you do not need much Throttle in the Reverse gear. Reverse is only for manuvering at slow speeds. You want low RPM for Trolling in Forward so you want a little slack in the Throttle in Forward gear.
Jul 17, 2010 | Boating
How do i ajust a ford mondeo gear linkage
if memory serves me right you cannot adjust the cables on these cars.
Sep 25, 2009 | 2000 Ford Focus
Transmission & Drivetrain for Ford E-350 Super Duty Length XLT Logo
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
