My car optra 1.8 2004model there is a check symbol at meter
How drain rhe annfreeze or of 2004 chev optra radior
2004 Chevrolet Optra Coolanat Flush: Where Do I Find the Drain ...
https://www.2carpros.com/questions/2004-chevrolet-optra-coolanat-flush
  1. Cached
  2. Similar
Mar 10, 2014 - Where do i find the drain plug for the coolant flush. Reply 1: Its on the bottom of the radiator. If you cant reach or see it just take off the ...
drain rhe annfreeze or of 2004 chev optra Google Search
May 18, 2017 | Cars & Trucks
2004 Chevrolet Optra trouble code PO341. Changed the cam position sensor,New.Still getting same code.
Put GM P0341 into Google are watch a few films on it on Youtube. It seems to be common. The wiring connector may be your problem. You'll need a multi-function meter to see if that's it. Fluke makes good one for not much money.
Apr 10, 2015 | 2007 Chevrolet Optra 1.6
Optra is leaking fluid from somewhere and is overheating, how can it be fixed
Have you checked all the hoses? Next time it heats up, open the hood, or look underneath and see where its coming from!
May 17, 2014 | Chevrolet Chevy Cars & Trucks
Chevry optra. engine light comes on hard shifting into drive
Take it an have checked for DTC'S - diagnostic trouble codes . Do you know what they are ? Check Engine Light On
May 09, 2014 | 2009 Chevrolet Optra 1.6
Chevy Optra 2007, engine light flashing
flashing is a severe condition, most cases it is from random multiple misfires, i would get it checked soon.
Sep 23, 2012 | 2007 Chevrolet Optra 1.6
My chevrolet optra will not move when drive is selected
check transmission fluid and is the check engine light on
Sep 20, 2012 | 2007 Chevrolet Optra 1.8
I need a 2005 chevy optra timing belt diagram
2005 Chevrolet Optra has four available engines: 1.4L (DOHC), 1.6L (L91), 1.8L (L79) and 2.0L (L34 GMDAT).
If you would like a belt routing diagram, it would be helpful if you would mention which of these engines your Optra is equipped with.
Jul 08, 2011 | Chevrolet Chevy Cars & Trucks
! symbol poped up on the dash were the rpm meter
Could be tire pressure low. Put 35psi in them and drive for a few minutes to see if the light turned off.
Feb 04, 2010 | 2001 Lexus LS 430
2004 chev optra ls
hi,you mention your struts,try to replace and check also your suspension bushing,if not try to check your chassis alignment,ty
Apr 13, 2009 | 2007 Mercedes-Benz ML500
Lexmark Optra T610 prints distorted and broken text and images
try deleting the printer and drivers completely, then reinstall
Mar 11, 2009 | Lexmark Optra T610 Laser Printer
12 people viewed this question
k24674
jasbo
jasbo
